Cynical Security Not Functioning...
Tue Jan 02, 2024 6:18 pm
jenwill1 offline
This plugin has been bullet proof but I seemed to do something to blow it up. Running version 3.1.1 and Indigo 2023.1 on a Ventura 13.1 iMac.
I've tried reloading the plugin, re-installing, deleted server and cameras and recreating. Not sure what else to try... above my pay grade.
Anyone have an idea on a fix for the following errors ?? Thanks in advance for a response.
Loading plugin "Cynical SecuritySpy 3.1.1" using API v3.0.0
Starting plugin "Cynical SecuritySpy 3.1.1" (pid 20914)
Cynical SecuritySpy API version 3.3
Cynical SecuritySpy Python version 3.10.2.final.0
Started plugin "Cynical SecuritySpy 3.1.1"
Cynical SecuritySpy Error in run_concurrent_thread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 67, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 77, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 64, in run_concurrent_thread
self.run()
File ".../Server Plugin/asyn/inject.py", line 60, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 105, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 244, in _can_read
self._scan(input)
File ".../Server Plugin/asyn/scan.py", line 67, in _scan
if not self.scan.scan(self):
File ".../Server Plugin/asyn/scan.py", line 144, in scan
target.callout(ctx, *m.groups())
File ".../Server Plugin/asyn/core.py", line 163, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/core.py", line 163, in <listcomp>
File ".../Server Plugin/asyn/http.py", line 292, in incoming
self.callout('headers', self.h_reply)
File ".../Server Plugin/spy/core.py", line 140, in reply
server = arg["Server"]
KeyError: 'Server'
Thu Jan 04, 2024 3:20 pm
jenwill1 offline
Re: Cynical Security Not Functioning...
I'm trying to remove all files associated with Cynical SecuritySpy...
I disabled the plugin, deleted the server and associated cameras, went to Lib/application support/Perceptive Automation and deleted the plugin Cynical SecuritySpy.indigoPlugin, and org.cynic.indigo.securityspy in the preferences. Closed Indigo and restarted Indigo... When I reinstall the plugin the devices are back and the error above persists.
Here are the errors on the reinstall of the plugin. Note last line... looks like it's trying to find and old device ??
Jan 4, 2024 at 3:15:24 PM
Installing and enabling plugin Cynical SecuritySpy v3.1.1
Starting plugin "Cynical SecuritySpy 3.1.1" (pid 11103)
Reloading plugin "Web Server 2023.1.0" using API v3.3
Stopping plugin "Web Server 2023.1.0" (pid 11014)
Stopped plugin "Web Server 2023.1.0"
Starting plugin "Web Server 2023.1.0" (pid 11107)
Started plugin "Web Server 2023.1.0"
Web Server starting internal Web server on http://localhost:8176
Jan 4, 2024 at 3:16:50 PM ---- this is where I added a camera server and all hell breaks loose !
yield
self.run()
item._can_read()
self._scan(input)
KeyError: 'Server'
Cynical SecuritySpy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Cynical SecuritySpy Error new device unavailable: ('301', 'Moved Permanently')
Any other files I need to delete to get a fresh install of the plugin ??
Thu Jan 04, 2024 3:58 pm
Did you delete all the devices as well? The definitions for those are stored in the Indigo database, not in a plugin file.
Thu Jan 04, 2024 4:34 pm
jenwill1 offline
I did Flying Diver... and by the way you have great plugins !
I did it again and the devices did not reappear upon restarting Indigo. Plugin did not show errors until I added a new camera server. Same errors on the event log as posted.
Thu Jan 04, 2024 4:41 pm
Did you create the server device before you attempted to create a camera device?
If you did, then the next clue is that a 301 error is an http redirect error. Like maybe SecuritySpy is trying to force the http calls to https. I don't think the plugin does https, so you need to make sure that SS is allowing http calls from the LAN side. The settings for LAN and WAN are separate, as I recall.
Thu Jan 04, 2024 4:46 pm
jenwill1 offline
In SecuritySpy I had only the 8001 web server enabled, Opened 8000 and reloaded the plugin and the errors went away.
I think I turned off 8000 web server when I was trying to get the IOS SecuritySpy app running outside my LAN :o
Thanks for your help.
