Capturing current humidity level as a variable
Fri Apr 30, 2021 9:45 pm
Eagleye offline
I have a multisensor 6 installed in my bathroom, which measures humidity. I would like to capture the set point humidity level before I turn the showers on and the humidity level starts to rise, so as I can create a trigger or schedule for the exhaust fan to turn off when it reaches this set point +2%.
I hope this makes sense.
In other words, is there a way I can capture the humidity level within the room at any given time as a variable? If so, can you please provide the script for this.
Sat May 01, 2021 1:30 pm
Re: Capturing current humidity level as a variable
Yes, just use the UI Action Variable Actions->Insert Device State into Variable.
Sat May 01, 2021 1:31 pm
whmoorejr offline
2 ways....
As an action, so hypothetically.... set a trigger to watch the bathroom light. Light turns on, then it sets a device state to a variable.
Screen Shot 2021-05-01 at 2.24.42 PM.png (261.84 KiB) Viewed 1457 times
As a script....
devValue = multi6_name.states['humidity'] # Substitue with actual device name and  whatever the state name is for the humidity value.
indigo.variable.updateValue(123456, value=str(devValue))  # Substitute 123456 with the variableID number
Bill
My Plugin: My People
