HassBridge plugin updated for Python3
Thu Aug 03, 2023 11:21 am
Re: HassBridge plugin updated for Python3
Moved thread to appropriate forum.
Thu Aug 03, 2023 11:35 am
Try https://github.com/FlyingDiver/Indigo-h ... g/2022.0.4
I think that gets rid of the warning.
Thu Aug 03, 2023 12:58 pm
Colly offline
Hi Joe,
Another one for you -tried latest version and get the following:
   HassBridge Error                Error in plugin execution InitializeMain:
  File "<string>", line 1, in <module>
  File "plugin.py", line 90, in __init__
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/__init__.py", line 53, in __init__
type: invalid literal for int() with base 10: ''
   Stopping plugin "HassBridge 2022.0.4" (pid 18415)
   Stopped plugin "HassBridge 2022.0.4"
Thu Aug 03, 2023 2:08 pm
What's in the "Insteon Battery No Comm Minutes" field in the plugin config?
Create Battery sensors needs to be enabled to see that field.
Thu Aug 03, 2023 3:19 pm
farberm offline
Yes this update got a rid of the warning. I will do some testing and see if anything else shows up.
Thanks again.
Great work - as usual.
Fri Mar 22, 2024 10:41 am
Venicenerd offline
Wow! You have no idea how grateful I am that this plugin was updated for python 3! Now that it’s been out for a while I wanted to check if it would be safe to update to the latest Indigo and this plugin update. Have the kinks been worked out?
Also, how do I update the plugin? Just manually overwrite it? I’m using two instances of this plugin. I assume that would continue to work with the update?
Thank you!
Fri Mar 22, 2024 10:44 am
There has been very little feedback on this plugin. All I can say is try it. The same method you previously used for multiple copies of the plugin should work again.
