Hi, I am very new to home automation and INDIGO and your plug-in if I can get it to work has a lot of potential. I purchased INDIGO version 6.0 and had the plug-in reporting the location correctly, but after upgrading to v6.0.2 I get these errors:
oncurrentThread:
File "plugin.py", line 966, in runConcurrentThread
File "plugin.py", line 865, in run_search_for_idevices
File "plugin.py", line 712, in fetch_updated_MobileMe_Locations
File "plugin.py", line 785, in process_device
<type 'exceptions.KeyError'>: key id 1615036726 not found in database
Find My IDevices Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I did some troubleshooting and followed some steps outline on the forums here but, nothing has solved the issue.
