Switchboard (Formerly Indigo Security Script)
Mon Nov 19, 2012 3:45 pm
Ericbo offline
Re: Switchboard (Formerly Indigo Security Script)
bschollnick2 wrote:
Ericbo wrote:
bschollnick2 wrote:
Ericbo wrote:
Sorry to bother you Benjamin but i am not anymore able to find the Switchboard documentation (the link may have moved). Would you mind re-posting it ? Much appreciated ! ... Eric
Where are you looking? There hasn't been any moves to my knowledge...
Can you please post the URL(s) that you are trying, so that I can fix them?
- Ben
Ben, I usually use the link in your signature (http://www.schollnick.net/wordpress/hom ... ty-script/) but it says "Not Found Sorry, but you are looking for something that isn't here." .... Thank you for the help ! ... Eric
I just checked, and I couldn't duplicate this.... But I've revised my signature, and updated it...
Let me know if it works better for you....
It works, thanks a lot !! ... Regards, Eric
Tue Nov 20, 2012 10:30 am
bschollnick2 offline
Folks, v0.76 is now available.
It fixes issues with the devices not being properly updated, and Heartbeat Email issues.
This should fix all know issues with v0.74... Please let me know if you upgrade, and you are either seeing devices not update, or some other issue....
- Ben
Download from here - https://dl.dropbox.com/u/241415/Switchb ... 0v0.76.zip
for v5 - http://bit.ly/T6WBKu
Thu Nov 22, 2012 5:19 am
rvarela offline
- Ben
Hi Ben,
I upgraded. I am getting the following message each time I activate the remote (KR21) of the SafeGuard (SC9000)
Switchboard Error Error in plugin execution ServerSentBroadcast:
File "plugin.py", line 805, in x10CommandReceived
File "plugin.py", line 412, in trigger_zone
<type 'exceptions.KeyError'>: key ActionOnOpen not found in dict
Ramiro
Thu Nov 22, 2012 5:58 am
- Ben
Hi Ben,
Try opening the device, editing it and then saving it.
Then do the same for the Monitored Device Group for that device....
I missed adding that field to the Verify routines that I added in v0.76. It just means that you need to open the Monitored Device group, and resave it. That should solve the issue.
Please let me know what happens...
Thu Nov 22, 2012 3:48 pm
rvarela offline
- Ben
Hi Ben,
I did the device part but I was not aware the device group. I fully followed your advice this afternoon and everything is fine again. Thank you very much!!
Fri Nov 23, 2012 5:50 pm
Ericbo offline
- Ben
Thank you Benjamin !
I tried to put my KR10A's on "Turn Off Hearbeat Warnings" but I am still getting the log warnings ...
Let me know if you need details (checked on 0.76, these are not in a device group, opened/closed the KR10A's ...)
Thank you Eric
Fri Nov 23, 2012 8:08 pm
Thank you Eric
A small oversight on my part.... I should be able to get this fixed on Saturday or Sunday.
- Ben
Sun Nov 25, 2012 2:33 pm
Ericbo offline
Thank you Eric
- Ben
Much appreciated Ben !!
Sun Nov 25, 2012 7:32 pm
Ericbo offline
Having setup all sensors (doors, windows, outside and inside movement) and programed with Switchboard/Indigo, I am happily testing :) ... Thanks for all helping. One question regarding debugging, although one of my window DS10A is included in a monitored group, opening the window, seeing the log showing the alarm under the right ID, I do not see the monitored group being updated (so the number of triggered devices stays at 0) ... I am guessing it may have to do with the 0.76 upgrades (though I have opened/closed the monitored group... Any idea about debugging ? ps : i am trying not to delete and recreate as I have quite a number of triggers using that group ... Thank you all !! Eric
Sun Nov 25, 2012 9:10 pm
What does the Indigo log show around the time that you trigger that DS10a? The only known issue in v0.76 is that I made a mistake in the new ignore heatbeat switch for the device preferences. I added all the code and preferences, but during debugging I accidently commented out the if then statement for that switch.
Mon Nov 26, 2012 1:57 pm
Can you email me at Benjamin AT schollnick DOT net, and I'll send you the plugin directly. I would like you to test the revised version since your using the Ignore heartbeat option...
- Ben
Mon Nov 26, 2012 4:03 pm
Ericbo offline
- Ben
Email on its way Ben, thanks a lot !! ... Regards Eric
Mon Nov 26, 2012 4:43 pm
Ericbo offline
Ericbo wrote:
- Ben
Ben, thanks for the file, tested it (0.77) for the KR10A's and works perfectly ! (no more warning for missing hearbeat)
Much appreciated !! Let me know if I need to test more or provide you information .... Eric
Tue Nov 27, 2012 4:13 am
rvarela offline
Ericbo wrote:
Ericbo wrote:
- Ben
Ben, If you want I can also try here the 0.77 version for the KR21's.
Tue Nov 27, 2012 9:13 am
Folks,
I am releasing SwitchBoard v0.77.
Changes
⁃ v0.77 - 11/27 /2012 - Public Release
⁃ Fixed a oversight in the globalProps Verify code. Missed ActionOnClose & ActionOnOpen.
⁃ Fixed a bug in the Ignore Handshake option with the X10 devices.
https://dl.dropbox.com/u/241415/Switchb ... 0v0.77.zip
