I am in the process of creating a control page for each of my 12 thermostats.
So, I created the first one and after a bit of testing and fine tuning I proceeded to create the second one. I did this by duplicating the first control page. I then proceeded to select each of the Device State fields and selected the correct thermostat. Unfortunately, whenever i do this it overwrites the caption that I previously set-up with the name of the newly selected thermostat. I can understand that it is helpful to fill in the caption if it is empty but not if it is already filled and undoes all my work and painstaking field alignment
Is there a way round this, have I missed something or is this a "feature" of the current implementation
The only way I have thought to do it so far is to have separate fields for the captions but this seems somewhat counter intuitive and rather negates the purpose of having the caption field in this case.
Also, is it possible to dynamically change the colours of the text depending on the field contents or is it fixed according to what is selected in the Control Panel Editor
Thanks for any help
