New version will not load
Sun Nov 26, 2023 6:27 am
MartynD offline
Hi
Just tried to install he latest version and get this error:
26 Nov 2023 at 12:17:14
Reloading plugin "iMessage Plugin 0.7.12" using API v3.0.0
Starting plugin "iMessage Plugin 0.7.12" (pid 14431)
iMessage Plugin Error Error in plugin execution InitializeMain:
File "plugin.py", line 26, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/iMessage.indigoPlugin/Contents/Server Plugin/openai/__init__.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/iMessage.indigoPlugin/Contents/Server Plugin/openai/api_resources/__init__.py", line 1, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/iMessage.indigoPlugin/Contents/Server Plugin/openai/api_resources/audio.py", line 4, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/iMessage.indigoPlugin/Contents/Server Plugin/openai/api_requestor.py", line 21, in <module>
type: No module named 'aiohttp'
Stopping plugin "iMessage Plugin 0.7.12" (pid 14431)
Stopped plugin "iMessage Plugin 0.7.12"
Any idea's ?
Martyn
Sun Nov 26, 2023 7:01 am
Re: New version will not load
pip3 install aiohttp
Sun Nov 26, 2023 9:34 am
MartynD offline
Thank you very much for your help, worked a treat.
Many thanks
Martyn
Sun Nov 26, 2023 2:06 pm
GlennNZ offline
Thanks for this.
Obviously aiohttp has become a dependency because of the openai library. I’ll make note of it.
These cascading dependencies are getting harder to keep track off (particularly when don’t flag on my system as installed because of another plugin)…
