Fantastic Weather Plugin Updates
Sun Nov 08, 2020 6:31 am
Re: Fantastic Weather Plugin Updates
Version 1.0.06 of the Fantastic Weather plugin has been released.
Do not apply this update--it contains a critical bug. Install v1.0.08 instead.
NOTE:: The Dark Sky service is no longer issuing new API keys and existing API keys will cease working in 2021.
v1.0.06
  • Code refinements.
v1.0.05
  • Further integrates DLFramework.
v1.0.04
  • Better integrates DLFramework.
v1.0.03
  • "Unable to reach..." error changed to warning.
You can download the latest release here.
You can view the plugin documentation here.
Mon Nov 09, 2020 7:01 am
Version 1.0.08 of the Fantastic Weather plugin has been released.
Users that updated to v1.0.06 should definitely apply this patch.
v1.0.08
  • Fixes critical bug in time formatting code.
Thu Nov 12, 2020 6:37 pm
Version 1.0.10 of the Fantastic Weather plugin has been released.
This is a minor release and users can update or feel free to ignore it. The update reduces the possibility of reporting connection timeouts as errors -- they will now be reported as warnings.
v1.0.10
  • Removes traceback logging for requests timeout.
v1.0.09
  • Additional trap for satellite image retrieval timeout.
Mon Feb 01, 2021 2:29 pm
Version 1.0.11 of the Fantastic Weather plugin has been released.
  • Better trapping of errors raised by r.requests.raise_for_status()
Fri Jun 18, 2021 2:55 pm
Version 1.0.13 of the Fantastic Weather plugin has been released.
  • Fixes bug in macOS audit logic.
  • Code refinements.
Sun Jun 27, 2021 5:17 am
Version 1.0.14 of the Fantastic Weather plugin has been released.
  • Includes deprecation warning in startup logging.
  • Improves macOS audit logic.
  • Code refinements.
Tue Jul 27, 2021 4:49 am
Version 1.0.17 of the Fantastic Weather plugin has been released.
This version includes all recent changes -- including fixes for known bugs. Users that currently using versions 1.0.15 or 1.0.16 do not need to update to v1.0.17.
v1.0.16, v1.0.17
  • Bumps version number to force releases sync.
v1.0.15
  • Fixes bug in Write to File menu item.
  • Logging refinements.
Wed Oct 06, 2021 2:38 pm
Version 1.0.18 of the Fantastic Weather plugin has been released.
  • Fixes bug where email forecast can send "Not available" for the precipitation type.
  • Addresses situation where Dark Sky does not provide the 'x-forecast-api-calls' payload key.
In instances where the Dark Sky payload does not include the payload key 'x-forecast-api-calls', the plugin sill substitute the value -1 for the number of daily API calls. When the payload provides the necessary key, the number of daily API calls will be updated.
Tue May 10, 2022 5:32 pm
Version 2022.0.1 of the Fantastic Weather plugin has been released.
Updates plugin for Indigo 2022.1 and Python 3. Note that this version of the plugin requires at least version 2022.1 of Indigo. It will not work on older versions. Also, the plugin documentation referenced below may not yet be updated to reflect all the changes in this release (the docs will be updated soon.)
Reminder: Apple will be shutting down the Dark Sky API (slated to be some time in 2022). At that time, this plugin will no longer function and will be deprecated.
  • Includes 'pytz' module (to support Python 3).
  • Standardizes Indigo method implementation.
Sat Apr 01, 2023 8:28 am
Version 2022.0.3 of the Fantastic Weather plugin has been released.
Support for the Dark Sky API has ended and the Fantastic Weather plugin is no longer supported.
This final update moves the plugin to the Pirate Weather API.
Tue Apr 25, 2023 4:38 am
Version 2022.0.4 of the Fantastic Weather plugin has been released.
  • Updates plugin_defaults.py to remove reference to Dark Sky API lookup.
  • Updates core API URL to reflect the new endpoint https://api.pirateweather.net.
Mon May 06, 2024 5:41 am
Version 2022.0.6 of the Fantastic Weather plugin has been released.
  • Minor edit to Config UI dialog.
  • Fixes minor bug that appended pressure units to UV index in forecast emails.
  • Improves handling of `precip_type` when payload returns `None`.
