Convert to Python
Sat Aug 22, 2020 2:27 pm
ckeyes888 offline
Convert to Python
Hey,
Appreciate any help converting this one to Python.
   if value of variable "RecVolume" is greater than 40 then
      set theVolume to (value of variable "RecVolume") - 3
      dim device "Receiver Volume 1" to theVolume
   end if
end tell
Carl
Sat Aug 22, 2020 9:00 pm
Re: Convert to Python
theVolume = int(indigo.variables["RecVolume"].value)
if theVolume > 40:
    indigo.dimmer.setBrightness("Receiver Volume 1", value=theVolume-3)
this should do it .. if "Receiver Volume 1", is a dimmer device
you can replace "device name" with devId = the id of the device and the same for the variable and remove the "" when you use the devId
Sun Aug 23, 2020 9:35 pm
ckeyes888 offline
Excellent! Thanks!
Carl
