Camera Snapshot -> Copy image -> send one via email / text
Tue May 21, 2019 3:15 pm
whmoorejr offline
The bulk of my applescripts have something to do with images. And they are all embedded in actions. This one does a few things....
1) takes a snapshot from a camera (Curl) and saves it in a folder "IPCamRotate/R.jpg". <-- I have several control pages that look at that image... so when something changes that one image address can change from any camera or any other image. (The key to this is that the "R.jpg" is continually overwritten with updated images based on different events)
2) Uses some script to create a unique filename "set filename to "Backyard_" & the file & ".jpg as string"
3) Copies R.jpg to new jpg with the unique filename to be stored in a log folder on the server computer.
4) Sends the new logged jpg image file as an attachment. (in this script, I send the image via iMessage). I may have to modify to send via email to text or via pushover.
do shell script "curl -f 'http://10.0.6.185:8085/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=whmoorejr&pwd=donkey' -o ~/Desktop/IPCamRotate/R.jpg"
set TheYear to year of (current date) as string
set TheMonth to month of (current date) as integer
set TheDay to day of (current date) as string
set Today to TheYear & TheMonth & TheDay as string
set Myhour to get the (hours of (current date)) as string
set Myminutes to get the (minutes of (current date)) as string
set Myseconds to get the (seconds of (current date)) as string
set MyTime to Myhour & "-" & Myminutes & "-" & Myseconds
set thefile to Today & "_" & MyTime as string
--set filedate to (current date) as number
set filename to "BackYard_" & thefile & ".jpg" as string
set sourceFile to POSIX file "/Users/williammoore/Desktop/IPCamRotate/R.jpg"
set destFolder to POSIX file "/Users/williammoore/Desktop/IPCamLog"
tell application "Finder"
   set dupeFile to duplicate sourceFile to destFolder
   set dupeFile's name to filename
end tell
   set folderPath to folder "MacMini:Users:williammoore:Desktop:IPCamLog"
   set thefile to file filename in folderPath as alias
   set filename to name of thefile
end tell
set theAttachment1 to thefile
tell application "Messages"
   send theAttachment1 to buddy "bill.moore.jr@gmail.com" of (service 1 whose service type is iMessage)
   --   send theAttachment1 to buddy "msvikki04@gmail.com" of (service 1 whose service type is iMessage)
end tell
So far (from this part of the forum), I've got...
url = 'http://10.0.6.185:8085/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=whmoorejr&pwd=donkey'
# Make the request and get the reply
reply = requests.get(url)
# This will raise an exception if the request returned an error
reply.raise_for_status()
# Save the content to a file
with open('/Users/williammoore/Desktop/IPCamRotate/R.jpg', 'wb') as image_file:
    image_file.write(reply.content)
But the above died on the 2nd line "embedded script: global name 'requests' is not defined"
I also tried
import os
os.system("/usr/bin/curl -f 'http://10.0.6.185:8085/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=whmoorejr&pwd=donkey -o ~/Desktop/IPCamRotate/R.jpg")
No error... but didn't do anything either
Bill
My Plugin: My People
Tue May 21, 2019 10:44 pm
RogueProeliator online
Re: Camera Snapshot -> Copy image -> send one via email / te
At the top of your script, you need to tell it you are using requests:
import requests
Adam
Wed May 22, 2019 4:56 pm
whmoorejr offline
Okay. I'm 75% there. (Steps 1-3 are good). Stuck on #4. I'm not picky on how I send an image.. but I would like to figure out a way to script it so it's in one place... versus running the script then moving to another action that uses a plugin to send the file (iMessage, Pushover, Better Email, etc.).
So this is what I have... On #4, no error, but nothing happens. If I take out the variable theFile and replace with "hello world", it works. But I want a picture.
# Step 1 - Camera Snapshot to File
import requests
# Step 2 - Create Unique filename
import datetime
Time = "{date:%Y-%m-%d_%H-%M-%S}".format(date=datetime.datetime.now())
Title = "Backyard.jpg"
FileName = u"{}_{}".format(Time, Title)
# Step 3 - Copy Rotation Image to Log Image
from shutil import copyfile
copyfile('/Users/williammoore/Desktop/IPCamRotate/R.jpg','/Users/williammoore/Desktop/IPCamLog/'+ FileName)
# Step 4 - Send Image via ???
theFile = ‘/Users/williammoore/Desktop/IPCamLog/‘ + FileName
import os
cmd = """osascript<<END
send theFile to buddy "bill.moore.jr@gmail.com" of (service 1 whose service type is iMessage)
end tell
END"""
def send_Message():
     os.system(cmd)
send_Message()
I'm guessing I need to tell the Python genie that theFile is an image and guessing that the way I'm adding a variable into the send line is probably wrong. If it's easier to script a plugin to accomplish this, I'm game.
Bill
Wed May 22, 2019 5:18 pm
whmoorejr offline
Kinda answering myself....
send image via pushover... (as a fun added bit... I created a new token with the application name "Motion" to separate these pushover messages from my indigo plugin ones)
import requests
r = requests.post("https://api.pushover.net/1/messages.json", data = {
  "token": "my token number",
  "user": "my user number",
  "message": "hello world"
files = {
  "attachment": ("image.jpg", open("/Users/williammoore/Desktop/IPCamRotate/R.jpg", "rb"), "image/jpg")
print(r.text)
I'd still appreciate alternate ways... (my wife hates Pushover). Would prefer iMessage or even email to text with image.
Bill
Sat Jan 04, 2020 11:14 am
ryanbuckner offline
did you figure out the sending image via iMessage part? I'm trying to do it too. I had it working with AppleScript
Sat Jan 04, 2020 6:00 pm
ryanbuckner offline
I wound up using python to call an action group that executes an AppleScript file:
Call the action group
if (boolSuccess):
    indigo.actionGroup.execute(1116335381)
Applescript
   set targetBuddy to "ryanbuckner@gmail.com"
   set targetService to id of 1st service whose service type = iMessage
   set textMessage to POSIX file "/Users/ryanbuckner/Desktop/staffit.png"
   set theBuddy to buddy targetBuddy of service id targetService
   send textMessage to theBuddy
end tell
It's not great but it only runs once a week
Sun Jan 05, 2020 9:35 am
whmoorejr offline
working with Python.... No. Working without AppleScript, yes.
Like you, I can use a python script in my above code to call an action. Instead of having an AppleScript action, you can try the iMessage plugin to create a "Send iMsg Picture/File (iMessagePlugin Action)" to send the picture you want.
Bill
Tue Jan 07, 2020 3:18 pm
ryanbuckner offline
Ahh, Thx. I removed the iMessage plugin in favor of the Messages plugin after getting lots of errors. I'll try again.
