- Code: Select all
Bond Home Debug udp_start() socket listener started
I wanted to see if you're getting ANY updates from the hub, which is why I asked you to try to change a device using the original remote or the Bond app.
Currently, the plugin uses those updates to set device states, not the commands it's sending out. That SHOULD be a more accurate representation of the device. But if you're not getting ANY updates, then there's something else going on.
I'll try to look into it this weekend.
