Davis WeatherLink Live plugin
Sun Sep 05, 2021 8:42 am
Re: Davis WeatherLink Live plugin
Sounds like the device is busy and just doesn't reply to that request. Or it might be a network congestion issue and the request doesn't get received.
Unless it's happening all the time, I'd ignore it.
Mon Sep 06, 2021 9:04 am
Gman34798 offline
Thank you Joe,
I was leaning toward network congestion myself. The message pops up regularly in my event log, but not at exact intervals....and I know it's updating the temperature, etc. when it does update.
Wed Oct 13, 2021 2:22 am
Eagleye offline
Joe,
I just recent bought that “Davis Airlink” that measures air quality. I have successfully connected the device to my WeatherLink app, so as both the WeatherLink and Airlink data is seen on the same interface. Do you know is it is possible to also capture the Airlink information in Indigo?
Wed Oct 13, 2021 4:10 am
Pre-release 0.3.0 does:
https://github.com/FlyingDiver/Indigo-W ... /tag/0.3.0
Fri Oct 15, 2021 4:09 pm
Eagleye offline
Thanks Joe,
When I try to open this release, my Mac tries to open the previous version of Indigo (7.5). Is there a way around this?
Fri Oct 15, 2021 4:19 pm
That's not a plugin issue, it's a generic MacOS issue. Right click on the plugin file and select which app to "Open with".
Fri Oct 15, 2021 4:57 pm
Eagleye offline
Thnaks Joe
Sun Jan 23, 2022 6:09 pm
Eagleye offline
Hi Joe,
HNY :D
I'm not sure if you can help with this but my Weatherlink plugin has been working find until this morning when I started to get a "HTTP Error" state message against the WeatherLinkLive device (Refer attached screenshoot), yet the WeatherLink app continuous to receive updated data. I have re-polled WeatherLink and disabled/reloaded the plugin with no effect. Are you able to suggest how I can correct this?
Screen Shot 2022-01-24 at 11.05.34 am.png (71.26 KiB) Viewed 3135 times
Sun Jan 23, 2022 6:58 pm
Eagleye wrote:
Hi Joe,
HNY :D
Enable debug logging so I can see what the actual error is.
