Gephi and Indigo
Thu Feb 02, 2017 5:29 pm
Gephi and Indigo
Continuing to play with Gephi. Here is a screenshot where the nodes have been arrayed like they are in our house. The green lines represent a gross approximation of our external walls, with the nodes placed (generally) where the devices are in the house. The blue nodes indicate battery operated devices, which I plan to adjust to show relative battery health. I'm not at all happy with the color scheme yet.
Screen Shot 2017-02-02 at 5.22.36 PM.png (250.83 KiB) Viewed 2864 times
Here is the (still evolving) script I'm using to generate the CSV files for Gephi import:
##### Script to generate CSV files for Gephi visualizations. #####
dev_address_list = []
edges_counter = 0
neighbors_dict = {}
##### nodes #####
node_file = open('/Users/username/Dropbox/Indigo Logs/zwave_nodes.csv', 'w')
node_file.write(u"Id,Label,Battery,Battery Health,Type\n")
node_file.write(u"1,Controller,0,100,Static Controller\n")
for dev in indigo.devices.itervalues('indigo.zwave'):
    if dev.address not in dev_address_list:
            class_name = dev.globalProps['com.perceptiveautomation.indigoplugin.zwave']['zwClassName']
            dev_address_list.append(dev.address)
            neighbors_dict[str(dev.address)] = dev.globalProps['com.perceptiveautomation.indigoplugin.zwave']['zwNodeNeighbors']
                if dev.globalProps['com.perceptiveautomation.indigoplugin.zwave']['SupportsBatteryLevel']:
                    battery = 1
                    battery_level = dev.batteryLevel
                    battery = 0
                    battery_level = 100
            except:
                battery = 0
            node_file.write(u"{0},{1},{2},{3},{4}\n".format(dev.address, dev.name, battery, battery_level, class_name))
        except:
            pass
node_file.close
##### Edges #####
edges_file = open('/Users/username/Dropbox/Indigo Logs/zwave_edges.csv', 'w')
edges_file.write(u"Source,Target,Type,Id,Weight,Average Degree\n")
for k, v in neighbors_dict.iteritems():
    for neighbor in v:
        edges_file.write(u"{0},{1},{2},{3},{4},{5}\n".format(k, neighbor, 'Undirected', edges_counter, 1.0, 1.0))
        edges_counter += 1
edges_file.close
Mon Feb 06, 2017 5:09 pm
Re: Gephi and Indigo
Relative battery health (lower right node showing low battery).
Screen Shot 2017-02-06 at 5.00.42 PM.png (214.03 KiB) Viewed 2784 times
Mon Feb 06, 2017 9:03 pm
Distribution by type of device ('zwClassName').
Screen Shot 2017-02-06 at 8.35.19 PM.png (395.41 KiB) Viewed 2766 times
