The macOS 12.1 release introduced a change which prevents Indigo’s built-in Web server from being able to launch. If you are using Indigo 2021.1 on macOS 12.0 or earlier, then the recommended solution is to install Indigo 2021.2 (
now available) which is compatible with macOS 12.1 before you upgrade to macOS 12.1. If your Indigo Up-to-Date subscription has expired and you can only download and use Indigo 2021.1 (or you have already upgraded to 12.1 and need an immediate fix) then this patch will fix the Web server issue.
To install the patch:
- Launch Indigo 2021.1 (if it isn’t running).
- Download the patch zip file here.
- If your browser didn't automatically unzip the file, unzip it in the Finder by double-clicking on it. Open the patch folder.
- In the Finder, drag the Web Server.indigoPlugin file onto the Indigo 2021.1 application shown in your Dock. Indigo will prompt you to install the newer plugin and the Web server should start.
Note, if you see something like this:
- Screen Shot 2021-12-14 at 5.29.52 PM.png (65.29 KiB) Viewed 2609 times
you will need to click cancel, then open the Security & Privacy System Preference and allow the plugin to run.
- Screen Shot 2021-12-14 at 5.33.52 PM.png (134.85 KiB) Viewed 2609 times
You will also need to restart the Indigo Server to finish the installation once you get the message that it was installed from Indigo.
Warning: This patch should only be applied to Indigo 2021.1 installations. Indigo 2021.2, which is
now available, includes this fix and versions of Indigo older than 2021.1 are not compatible with this patch.
