New error Line 8019
Fri Apr 30, 2021 7:34 am
Re: New error Line 8019
In which logfile do you see the error message? Syslog?
Fri Apr 30, 2021 7:55 am
Turribeach offline
/var/log/messages
You can run "tail -f /var/log/messages" to follow the log live.
Fri Apr 30, 2021 8:34 am
farberm offline
Mine shows high CPU usage
Fri Apr 30, 2021 8:36 am
I think I can add that,
I am busy this weekend - my son is coning to visit and get his JJ single dose shot-
but Monday I should have something
Fri Apr 30, 2021 12:13 pm
farberm offline
the ap restart fixed thngs for now
Fri Apr 30, 2021 4:39 pm
Turribeach offline
So the same AP had the issue again. I then performed the same 3 steps in reverse order. While the log events seemed to say the reporter was restarted it didn't seem to work. I tried the same steps again but AP went unresponsive and rebooted itself, without me doing it! This is relly something bad on Ubiquiti's side, not sure the plugin can do much about it. I will try to to chase my post on the Ubiquiti forums, but I am not expecting much help...
Fri Apr 30, 2021 5:48 pm
I don’t understand why some ap with the same hardware have that issue and some not.
My ap that throws a Fit once a months has a very light load
Are your APs up to date?
Sat May 01, 2021 4:48 pm
Ramias offline
I am getting it too on 3 different devices -- .4, .5 and .6.
.4 and .5 are AP AC Pros. .6 is the Wifi Mesh AP. All are on version 4.3.28.11361. Uptime is 79 days. Memory usage is less than 50% on all; CPU varies in the low to mid 60%.
May 1, 2021 at 6:43:04 PM
   uniFiAP Error                   in Line 8019 has error=No JSON object could be decoded
   uniFiAP                         checkAndPrepDict JSON len:56; mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx1...
...  ed -e 's/^ *//' xxxThisIsTheEndTokenxxx1
   uniFiAP                         .... in receiving DICTs for APdict-192.168.0.5;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
   uniFiAP                         .... in receiving DICTs for APdict-192.168.0.6;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
   uniFiAP                         checkAndPrepDict JSON len:56; mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx2...
...  ed -e 's/^ *//' xxxThisIsTheEndTokenxxx2
   uniFiAP                         .... in receiving DICTs for APdict-192.168.0.4;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
May 1, 2021 at 6:43:57 PM
May 1, 2021 at 6:44:13 PM
   Hikvision                       [Sat May  1 18:44:20 2021] Camera: Garage Camera has fallen off the network.
   Hikvision                       [Sat May  1 18:44:20 2021] Camera: Yard Camera has fallen off the network.
Mon May 03, 2021 6:10 am
Turribeach offline
So did a search on all my Indigo Server logs. The "No JSON object could be decoded" is pretty common and I get it ocasionaly on most days but in most cases it seems to be a one off. Looking at my logs I can however that since 4-March I started to get these all the time on different APs which only a reboot fixed. All my 3 APs are running the latest AC-Pro firmware 4.3.28. Now I don't exacltly when my APs were upgraded to that firmware since my automatic email alerts from the Unifi controler weren't working properly due to Google disabling my app specific password on my Gmail Home Automaiton account due to not having 2 step verification. The event lots also don't go that far. But considering I have a monthly upgrade cycle configured and that 4.3.28 was released on 02-Feb then it makes sense the APs would have been upgraded around March. So I have now downgraded all APs to the previous firmware version (4.3.24). I will report back if this helps or not.
Mon May 03, 2021 2:40 pm
Turribeach offline
Also noticed this error from time to time:
  uniFiAP Error                   error in  Line# 5800 ;  error='key name Unifi_Camera_with_Event not found in database'
Mon May 03, 2021 5:14 pm
That bug was fix with the recent update
Mon May 03, 2021 5:27 pm
Turribeach offline
Is 7.39.364 the latest version? Because I just updated to v7.39.364 and I can still see the error:
   Upgrading plugin uniFiAP to newer version 7.39.364 (previous version moved to trash)
   Loading plugin "uniFiAP 7.39.364"
   Starting plugin "uniFiAP 7.39.364" (pid 31478)
   Error                           Unable to connect to IndigoDomo.com.
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         indigo                  /Library/Application Support/Perceptive Automation/
   uniFiAP                         installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.5/
   uniFiAP                         plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
   uniFiAP                         Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         check                   /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log  <<<<    for detailed logging
   uniFiAP                         Plugin short Name       UniFi
   uniFiAP                         my PID                  31478
   uniFiAP                         set params for indigo V 7.5
   Started plugin "uniFiAP 7.39.364"
   uniFiAP                         testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   uniFiAP                         myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log;  debugLevel= []
   uniFiAP                         MAP2Vendor initializing
   uniFiAP Error                   error in  Line# 5966 ;  error='key name Unifi_Camera_with_Event not found in database'
   uniFiAP                          start   runConcurrentThread, initializing loop settings and threads ..
   uniFiAP                         initialized ... looping
Mon May 03, 2021 7:44 pm
you are right, i did not publish the fixed version..
Mon May 03, 2021 8:04 pm
published v .265
could you check if this one is more stable?
changes in V7.39.365@ 2021-04-02
changed reading dicts and messages from unifi devices:
1. dict checks for single line w xxxThisIsTheEndTokenxxx255
2. tail messages check for ...state is locked...
3. changed time wait for dicts read to 63 secs from 58 secs
4. issue a unifi reboot command when encountering mca error, w option to switch off in config
5. fixed error in Line# 5966 ; error='key name Unifi_Camera_with_Ev ...
Tue May 04, 2021 3:25 am
MarcoGT offline
I had the same problem and I have just installed this update, I will keep an eye on it and report back
