My plugin has quit working for some reason. Below is log text after restart:
28 21:32:05 logger enabled for THREADDEBUG
28 21:32:05 logger enabled for DEBUG
21:32:05 logger enabled for INFO
21:32:05 logger enabled for WARNING
2021-04-28 21:32:05.872 ERROR Plugin.__init__ logger enabled for ERROR
2021-04-28 21:32:05.872 CRITICAL Plugin.__init__ logger enabled for CRITICAL
21:32:05 -myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.minMax/plugin.log; debugLevel= [u'Sql', u'Setup']
21:32:05 Configuration:
21:32:05 Dev/Var-Name----- ID State ignoreLess ignoreGreater format tracking measures: -------
21:32:05 Front Door Sensor 18622376 onOffState -9876543210 9876543210 '%.1f' lastDay- Count1
thisDay- Count1
21:32:05 Ecobee Hallway Remote - Guest Bedroom 218001346 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Tool Room Multi - Temperature 644478552 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Patio Door Sensor 61344331 onOffState -9876543210 9876543210 '%.1f' lastDay- Count1
thisDay- Count1
21:32:05 Attic Temperature 442644910 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Pump Shed - Temperature 1692324660 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Ecobee Hallway Remote - Office 920894099 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Ecobee Hallway Remote - Living Room 212449776 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Ecobee Hallway Remote - Kitchen 1193883684 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Ecobee Hallway Remote - Master Bedroom 979009114 sensorValue -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 Ecobee Hallway 861920429temperatureInput1 -9876543210 9876543210 '%.1f' thisDay- Min Max Ave
21:32:05 PatioTemperature 1774580169 value -9876543210 9876543210 '%.1f' thisHour- Min Max Ave
lastHour- Min Max Ave
lastDay- DateMax Min Max DateMin Ave
21:32:05 Deck Door Sensor 364274916 onOffState -9876543210 9876543210 '%.1f' lastDay- Count1
thisDay- Count1
21:32:05 AmbientTemperature 729752752 value -9876543210 9876543210 '%.1f' thisHour- Min Max Ave
21:32:05 config parameters foldername >minMax<
21:32:05 config parameters refreshRate >180.0<
21:32:05 config parameters liteOrPsql >psql<
21:32:05 config parameters refreshRate >180.0<[secs]
21:32:05 config parameters liteOrPsqlString >/Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres<
21:32:05 config parameters postgresPassword ><
21:32:05 config parameters timeFormatDisplay >%Y-%m-%d-%H:%M:%S<
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), onOffState from device_history_18622376 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 data-out:
28 21:32:06 err-out: psql: error: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_218001346 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_644478552 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), onOffState from device_history_61344331 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_442644910 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_1692324660 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_920894099 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_212449776 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_1193883684 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), sensorValue from device_history_979009114 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), temperatureInput1 from device_history_861920429 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), value from variable_history_1774580169 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), onOffState from device_history_364274916 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
28 21:32:06 /Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history postgres -t -A -F ';' -c "SELECT to_char(ts,'YYYY-mm-dd-HH24:MI:ss'), value from variable_history_729752752 where to_char(ts,'YYYY-mm-dd-HH24:MI:ss') > '2021-02-28-00:32:06' ORDER by id ;"
21:32:26 subscribing to device changes
21:32:26 subscribing to variable changes
