Incorrect variable values for allAway
Mon Sep 12, 2022 3:57 pm
vtmikel offline
Hi there-
I have two events that are configured the same way, with the same devices.
the "nAway" variable for one of the events is 2, the other is 0. Again, they have the same devices configured, so they should be the same.
the "allAway" variable for both are 0, but they should be 1, since there is only 2 devices and both are away.
I watch carefully and I see the allAway variables updating sometimes, but they quickly go back to 0.
I tried to downgrade to past versions to identify when this stopped working, but could not trace back to when the issue started. I know it worked somewhat recently.
I've also reset the events, to no avail. Any suggestions?
Tue Sep 13, 2022 12:02 pm
Re: Incorrect variable values for allAway
I can check later this week.
All the kids at visiting.
Sorry indigo is second prio.
Tue Sep 13, 2022 1:18 pm
did a quick check with my 2 iPhones and it works correctly,
and duplicated the event and the 2 events are in sync
could you share your devices info and event setup? ie timings etc
Wed Sep 14, 2022 4:32 pm
vtmikel offline
Absolutely.
Here are some screen shots, showing the two groups, same devices. In this case, nAway is the same for both events, but allAway is incorrect for both groups.
Both of these devices haven't been on the network for some time, safely expired.
Mike
Screen Shot 2022-09-14 at 6.29.50 PM.png (265.05 KiB) Viewed 1207 times
Screen Shot 2022-09-14 at 6.29.37 PM.png (275.96 KiB) Viewed 1207 times
Screen Shot 2022-09-14 at 6.28.29 PM.png (384.39 KiB) Viewed 1207 times
Screen Shot 2022-09-14 at 6.29.22 PM.png (402.85 KiB) Viewed 1207 times
Screen Shot 2022-09-14 at 6.29.16 PM.png (401.47 KiB) Viewed 1207 times
Thu Sep 15, 2022 5:31 am
should be fixed in release ...88
was one deleted line in python code.
Thu Sep 15, 2022 5:54 am
vtmikel offline
Thank you!
