Event resetting
Mon Oct 12, 2020 5:13 am
MartinG offline
Event resetting
I have a puzzling problem with an Event that keeps reverting to a prior version.
I'm using fingscan to trigger a number of energy efficiency measures, based on which mobile phones are active on the home network. There are 5 devices listed in the Event config, but every so often, 4 of them disappear. I can re-add them, click the confirm button to save them, and they appear to be stored correctly - when I revisit the Setup Events menu, they're all listed.
Yet at intervals (I can't tell how long), 4 of the devices disappear again.
These devices are running iOS14, but I have disabled the MAC randomisation on my network. They also appear consistently with the correct MAC/IP addresses elsewhere on the network.
Any ideas?
Versions are: Catalina 10.15.7, Indigo 7.4.1, Fing 2.2.1
Mon Oct 12, 2020 6:33 am
Re: Event resetting
when fingscan removes devices from events, you should see an entry in the fingscan.log file and in indigo log
with an entry like;
cleanupEVENTS removing device from EVENTS as indigo device does not exist: "MAC#"
This happens when the plugin tries to read an indigo device and indigo returns an error. Those things happen when there are timeouts
You should see this also in your logfile as red error
Just to confirm the devices just disappear from the event definitions, not from the IPdevices folder?
And could you check if those devices change their indigo device ID before/ aver they disappear?
Mon Oct 12, 2020 10:28 am
Re: Event resetting
just published a version (v7.31.57) that will NOT auto remove devices fro EVENTS when indigo returns an error for getting an event
it will instead show an error in the indigo log and fingscan.log file
please try that one
Tue Oct 13, 2020 5:31 am
MartinG offline
Re: Event resetting
Hi Karl,
Prior to installing your update, I did some digging and found this in the indigo log. It seems the plugin is resetting sometime shortly after midnight.
13 Oct 2020 at 00:19:03
   fingscan Error                  -->  setup config, save then a manual reload of plugin
   fingscan                        --> while loop break  stopping ...  quitNOW was: please setup config , waiting
   fingscan Error                  --> you have 2 minutes to fix config, before restart
   fingscan Error                  --> do a manual reload of plugin
   Reloading plugin "fingscan 7.31.54"
   Stopping plugin "fingscan 7.31.54" (pid 4681)
   fingscan Warning                stopConcurrentThread called 2
   fingscan                        runConcurrentThread stopping plugin due to:  ::::: no :::::
   Plugin restart request ignored (plugin is currently stopping or starting)
   fingscan                        killing 2
   Stopped plugin "fingscan 7.31.54"
   Starting plugin "fingscan 7.31.54" (pid 29104)
   fingscan                        =========================   initializing   ==============================================
   fingscan                        path To files:          ==================
   fingscan                        indigo                  /Library/Application Support/Perceptive Automation/
   fingscan                        installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.4/
   fingscan                        plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
   fingscan                        Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/
   fingscan                        !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
   fingscan Warning                !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
   fingscan Error                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
   fingscan Critical Error         !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
   fingscan                        check                   /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log  <<<<    for detailed logging
   fingscan                        Plugin short Name       fing
   fingscan                        my PID                  29104
   fingscan                        set params for indigo V 7.4
   Started plugin "fingscan 7.31.54"
   fingscan                        testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   fingscan                        myLogSet setting parameters -- logFileActive= standard; logFile= ;  debug plugin:[]
   fingscan                        FINGSCAN--   initializing     will take ~ 2 minutes...; sending logs to
   fingscan Warning                leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
   fingscan                        getting password
   fingscan                        get password done;  checking if FING is installed
   fingscan                        fing install check done
   fingscan                        loaded indigo data
   fingscan Warning                network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
   fingscan                        ifind plugin: com.corporatechameleon.iFindplugBeta
   fingscan                        MAP2Vendor initializing
   fingscan                        FING initializing parameters
   fingscan                        FING waiting for first data
13 Oct 2020 at 00:19:35
   fingscan                        FING initializing checking if output created, old timeStamp:1602544698.28; new timeStamp:1602544760.68
   fingscan                        FING initialized ..  created new data   waiting ~ 1 minute for stable operation
   fingscan Warning                  FING pids after step3 = ['29220']
   fingscan Warning                (re)started FING
   fingscan Warning                FING initialized
   fingscan
   fingscan                        switching off SQL logging for variables
 :ipDevsLastDevChangedIndigoName; ipDevsLastUpdate; ipDevsNewDeviceNo; ipDevsNewIPNumber; ipDevice88;
   fingscan                        switching off SQL logging for variables END
   fingscan
   fingscan                        switching off SQL logging for devices/state[lastfingup]
 :new-10-0A:C1:ED:90:69:4C;
   fingscan                        switching off SQL logging for devices END
13 Oct 2020 at 00:20:13
   fingscan                        FINGSCAN initialized
This is immediately followed by my 'presence' trigger firing:
13 Oct 2020 at 00:25:17
   Trigger                         Zero phones at home
This isn't accurate, because all our phones were at home.
I also found this, from the middle of yesterday afternoon:
12 Oct 2020 at 16:07:17
   fingscan Error                   updating ipDevice 88 does not exist , (re)creating
There are no other fingscan errors in the log
In answer to your specific questions:
"Just to confirm the devices just disappear from the event definitions, not from the IPdevices folder?"
Correct.
"And could you check if those devices change their indigo device ID before/ aver they disappear?"
Will do, though I'll have to wait for them to disappear again for this. What I do know is that the devices remain in the device subfolder I created for them. I expect Indigo uses the device ID to determine what belongs where, but I don't know that for certain.
Tue Oct 13, 2020 6:58 am
Re: Event resetting
here is what I do:
the devices get created in folder "newFingscan devices"
then I move them into "fingscanProduction" or "fingScanIgnore"
you only set "newFingscan devices" in config, once created they do not get moved to different folders
the other you have to setup yourself.
that makes it easy to handle devices, ie when you have guests and they connect. you can decide if you like them --> fingscanProduction or don't want to have them over again --> fingScanIgnore :evil:
Wed Oct 14, 2020 1:41 am
MartinG offline
Re: Event resetting
A few more details, this time from the latest release (7.31.57)
The Event definition had disappeared again this morning, and I found this in the plugin's log:
2020-10-14 00:19:03.532   ERROR          Plugin.dorunConcurrentThread     -->  setup config, save then a manual reload of plugin
2020-10-14 00:19:03 --> while loop break  stopping ...  quitNOW was: please setup config , waiting
2020-10-14 00:19:03.540   ERROR          Plugin.dorunConcurrentThread     --> you have 2 minutes to fix config, before restart
2020-10-14 00:19:03.541   ERROR          Plugin.dorunConcurrentThread     --> do a manual reload of plugin
Then about 30 seconds later, I see the following. Note that there's only one device I the list, whereas I created 5 in the event definition. This is the only phone that has not been updated to iOS14, so the issue may have been stimulated by iOS14's MAC randomisation (since disabled for these devices on this network). I can also confirm that the MAC address reported in Indigo does match that seen by the network equipment & my management tools.
2020-10-14 00:19:36
EVENT defs::::::::::::::::::
EVENT:-------------  1  --------------------------------------------------------------------------------------------------
dev#:  5 -- devNam:Phone - Rachel 8+         -- MAC#:58:E6:BA:59:63:3B -- ip#:192.168.1.149   -- status:up       -- WiFi:
currentStatusHome:    # 5:           HOME
currentStatusAway:    # 5:              0
time WhenLast DOWN:   # 5:       08:53:28
time WhenLast UP:     # 5:       12:13:25
seconds WhenLast UP:  # 5:          43573
seconds WhenLast DOWN:# 5:          50291
Time right now:          :    00:19:36
ALL Devices         Home :           1  -- reacts after minTimeNotHome
AtLeast ONE Device  Home :           1  -- reacts after minTimeNotHome
ALL Devices         Away :           0  -- reacts minTimeAway bf Trig
AtLeast ONE Device  Away :           0  -- reacts minTimeAway bf Trig
minTimeAway bf Trig      :         300
minTimeNotHome bf re-Trig:          60
Event enabled            :           1
dataFormat               :         3.0
I also checked the indigo device ID, and I can confirm that they have not changed since yesterday..
Wed Oct 14, 2020 9:27 pm
Re: Event resetting
there must be some (error) messages before
there should be more lines after startup:
========================= initializing =============================================="
set params for indigo V ...
please post all the lines
also from /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log
Fri Oct 16, 2020 2:09 pm
MartinG offline
Re: Event resetting
Not always... this is the start of the log on that day, and there's nothing in the tail end of the previous day.
However, there were some extra lines yesterday morning. Here's the whole log from yesterday. The first 5 lines don't appear in this morning's log.
2020-10-15 00:01:32.334   ERROR          Plugin.updateIndigoIpVariableFromDeviceData error in  Line# 6084 ;  error='NoneType' object has no attribute 'replace'
2020-10-15 00:01:32.344   ERROR          Plugin.updateIndigoIpVariableFromDeviceData MAC#                           9A:7B:A9:DB:A3:C9
2020-10-15 00:01:32.345   ERROR          Plugin.updateIndigoIpVariableFromDeviceData  indigoIpVariableData:     {'status': 'down', 'suppressChangeMSG': 'show', 'index': 110, 'nickName': 'iphonexyz', 'WiFi': '', 'deviceInfo': '', 'noOfChanges': 0, 'ipDevice': '90', 'WiFiSignal': '0', 'hardwareVendor': '', 'timeOfLastChange': '0', 'usePing': '', 'ipNumber': '0.0.0.0', 'variableName': ''}
2020-10-15 00:01:32.345   ERROR          Plugin.updateIndigoIpVariableFromDeviceData  allDeviceInfo:            {'status': 'up', 'suppressChangeMSG': 'show', 'lastFingUp': 1602716492.31709, 'devExists': 1, 'useWakeOnLanSecs': 0, 'deviceName': u'new-10-9A:7B:A9:DB:A3:C9', 'setWiFi': '', 'ipNumber': '192.168.1.153', 'WiFi': '', 'deviceInfo': '', 'noOfChanges': 1, 'fingLastUp': 0, 'usePing': 'usePingUP', 'WiFiSignal': '', 'timeOfLastChange': '2020-10-15 00:01:29', 'deviceId': 671073146, 'useWakeOnLanLast': 0, 'hardwareVendor': None, 'expirationTime': 0, 'nickName': 'new-10-9A:7B:A9:DB:A3:C9', 'variableName': ''}
2020-10-15 00:02:13.052   ERROR          Plugin.updateIndigoIpVariableFromDeviceData  updating ipDevice 90 does not exist , (re)creating
2020-10-15 00:19:02.966   ERROR          Plugin.dorunConcurrentThread     -->  setup config, save then a manual reload of plugin
2020-10-15 00:19:02 --> while loop break  stopping ...  quitNOW was: please setup config , waiting
2020-10-15 00:19:02.970   ERROR          Plugin.dorunConcurrentThread     --> you have 2 minutes to fix config, before restart
2020-10-15 00:19:02.970   ERROR          Plugin.dorunConcurrentThread     --> do a manual reload of plugin
2020-10-15 00:19:03 stopConcurrentThread called 2
2020-10-15 00:19:06 =========================   initializing   ==============================================
2020-10-15 00:19:06 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2020-10-15 00:19:06 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2020-10-15 00:19:06 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2020-10-15 00:19:06 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2020-10-15 00:19:06.762   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2020-10-15 00:19:06.763   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2020-10-15 00:19:07 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-10-15 00:19:07 indigo variables initialized
2020-10-15 00:19:07 getting password
2020-10-15 00:19:07 get password done;  checking if FING is installed
2020-10-15 00:19:09 fing install check done
2020-10-15 00:19:11 loaded indigo data
2020-10-15 00:19:11 network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
2020-10-15 00:19:12 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-10-15 00:19:12 MAP2Vendor initializing
2020-10-15 00:19:13 FING initializing parameters
startfing               L:237 Lv:20 ========= start   @ 2020-10-15 00:19:14.885497   ===========
2020-10-15 00:19:16 FING waiting for first data
startfing               L: 74 Lv:20 into doFingV5 with yearTag: 2020/10, netTag: 192., version: 5.4;  opsys: 10.15
startfing               L: 98 Lv:20 fing.bin launched
2020-10-15 00:19:36 FING initializing checking if output created, old timeStamp:1602717511.41; new timeStamp:1602717561.15
2020-10-15 00:19:36 FING initialized ..  created new data   waiting ~ 1 minute for stable operation
2020-10-15 00:19:36   FING pids after step3 = ['16261']
2020-10-15 00:19:36 (re)started FING
2020-10-15 00:19:36 settings:  iDevicesEnabled              False
2020-10-15 00:19:36 settings:  inbetweenPingType            parallel
2020-10-15 00:19:36 settings:  wifiRouter                   0
2020-10-15 00:19:36 settings:  wait seconds between cycles  5
2020-10-15 00:19:36 settings:  password entered             True
2020-10-15 00:19:36 settings:  debugLevel                   []
2020-10-15 00:19:36 settings:  FINGSCAN will scan Network   192.168.1....  # fixed bits in ip range:24
2020-10-15 00:19:36
2020-10-15 00:19:36
seconds WhenLast UP:  # 5:         129973
seconds WhenLast DOWN:# 5:         136691
Event enabled            :           1
dataFormat               :         3.0
2020-10-15 00:19:36
===      Unifi   devices  available  to fingscan    ===        START
--Device Name------        indigoID--    --Status  lastUpdate  used
AP_80:2a:a8:53:49:1f       482583843           up    00:19:12     0
AP_80:2a:a8:53:49:5c       1988362470          up    00:19:12     0
AP_e0:63:da:1d:8f:e6       1868084645          up    00:19:12     0
AP_f0:9f:c2:30:e5:89       291527006           up    00:19:12     0
Mower                      1919026994          up    00:19:12     0
SW_e0:63:da:85:3b:58       1171180688          up    00:19:12     0
UniFi_00:00:00:00:00:01    1089581110           0    00:19:12     0
UniFi_00:02:fc:62:00:00    1223647485           0    00:19:12     0
UniFi_00:04:20:f7:0a:5e    896271981           up    00:19:12     0
UniFi_00:0e:58:01:17:72    719957048            0    00:19:12     0
UniFi_00:0e:58:13:c4:84    25216429             0    00:19:12     0
UniFi_00:10:18:55:44:4b    1700651078           0    00:19:12     0
UniFi_00:1a:e9:95:7f:cc    1826334784          up    00:19:12     0
UniFi_00:1e:c0:9d:0d:b8    89459605            up    00:19:12     0
UniFi_00:24:e4:00:b3:7b    1617976990           0    00:19:12     0
UniFi_00:84:11:ff:fe:80    1286878093           0    00:19:12     0
UniFi_00:bb:3a:f7:e3:1f    1540337019           0    00:19:12     0
UniFi_00:d0:2d:a9:6a:03    416153058           up    00:19:12     0
UniFi_00:db:70:ac:79:f8    1924334844           0    00:19:12     0
UniFi_02:9f:c2:32:e5:89    80435621             0    00:19:12     0
UniFi_0a:0a:78:76:1b:70    11003511             0    00:19:12     0
UniFi_0a:dd:9a:77:81:c7    736334141            0    00:19:12     0
UniFi_0c:4d:e9:d2:b7:64    36574418            up    00:19:12     0
UniFi_0e:9a:ad:f3:74:20    447742663            0    00:19:12     0
UniFi_0e:ef:32:81:f5:9a    265733334            0    00:19:12     0
UniFi_10:4e:89:0d:8d:81    1725517553           0    00:19:12     0
UniFi_10:da:43:0f:31:e2    1763658368           0    00:19:12     0
UniFi_12:61:3e:de:f5:0d    1040032820           0    00:19:12     0
UniFi_14:c2:13:b7:ca:c2    1601524532           0    00:19:12     0
UniFi_14:c2:13:dc:91:7a    1085952496           0    00:19:12     0
UniFi_18:55:e3:56:d7:15    798084705            0    00:19:12     0
UniFi_18:83:bf:cb:58:7d    1766008024           0    00:19:12     0
UniFi_18:ee:69:10:ef:d6    85284353             0    00:19:12     0
UniFi_18:ee:69:10:ef:d7    761542723           up    00:19:12     0
UniFi_2c:6a:cb:22:67:5c    1330048034           0    00:19:12     0
UniFi_2e:3d:88:ff:5c:44    1369750709           0    00:19:12     0
UniFi_30:35:ad:d9:cf:7a    1134897847           0    00:19:12     0
UniFi_30:63:6b:d9:02:90    497593699            0    00:19:12     0
UniFi_38:71:de:aa:b0:42    1743483972           0    00:19:12     0
UniFi_38:f9:d3:5a:cd:d3    1383836837          up    00:19:12     0
UniFi_40:83:1d:13:1b:b2    284669610            0    00:19:12     0
UniFi_40:9c:28:54:6c:13    1294706274           0    00:19:12     0
UniFi_40:cb:c0:cf:97:37    1470380674          up    00:19:12     0
UniFi_42:77:02:2b:c7:e3    726913799            0    00:19:12     0
UniFi_44:18:fd:e5:05:75    547569445            0    00:19:12     0
UniFi_44:39:c4:7e:3d:e7    70691263            up    00:19:12     0
UniFi_48:a9:d2:f6:a0:5d    1307766238           0    00:19:12     0
UniFi_4c:17:44:d2:31:47    1739678282           0    00:19:12     0
UniFi_4c:57:ca:35:49:d8    157155717            0    00:19:12     0
UniFi_50:f5:da:86:c5:47    1473805058          up    00:19:12     0
UniFi_54:33:cb:ea:e8:47    925188667            0    00:19:12     0
UniFi_54:54:7d:e7:5f:3e    165091340            0    00:19:12     0
UniFi_56:54:ad:90:92:3e    683917187            0    00:19:12     0
UniFi_58:40:4e:a5:99:5d    1943410950          up    00:19:12     0
UniFi_58:e2:8f:a8:fc:26    273711717            0    00:19:12     0
UniFi_58:e6:ba:31:11:9e    1068736300           0    00:19:12     0
UniFi_58:e6:ba:59:63:3b    1418973220          up    00:19:12     0
UniFi_5a:a2:df:e0:1c:6c    695419029           up    00:19:12     0
UniFi_5a:c3:34:bc:20:5e    976769453            0    00:19:12     0
UniFi_5c:41:f5:33:ad:45    334832924            0    00:19:12     0
UniFi_5e:ac:ed:2b:1f:4d    80960037             0    00:19:12     0
UniFi_60:26:05:4b:dc:44    1422785122           0    00:19:12     0
UniFi_60:26:07:4f:ec:4c    779503522            0    00:19:12     0
UniFi_60:d9:c7:46:66:e2    440659180            0    00:19:12     0
UniFi_60:e4:df:82:c3:d8    109089272            0    00:19:12     0
UniFi_62:22:08:3c:cc:50    1980201030           0    00:19:12     0
UniFi_62:23:06:43:d0:54    1976732844           0    00:19:12     0
UniFi_62:24:05:48:d8:58    938546786            0    00:19:12     0
UniFi_64:1e:02:50:d0:38    843530747            0    00:19:12     0
UniFi_64:1f:02:50:d0:38    1994386504           0    00:19:12     0
UniFi_64:1f:02:50:d4:34    459631947            0    00:19:12     0
UniFi_66:9b:eb:97:26:fe    1836145079           0    00:19:12     0
UniFi_68:27:37:b2:94:8a    857089118           up    00:19:12     0
UniFi_68:5b:35:93:d0:b4    1372709196          up    00:19:12     0
UniFi_68:f7:28:d9:51:b6    1443405827          up    00:19:12     0
UniFi_6c:40:08:b1:49:b8    98337795            up    00:19:12     0
UniFi_6e:9a:62:8f:b4:d6    1214945195           0    00:19:12     0
UniFi_70:ee:50:1f:39:fa    291157588            0    00:19:12     0
UniFi_74:9e:af:26:81:c6    1614209814           0    00:19:12     0
UniFi_74:b5:87:7d:0c:f5    1920631746           0    00:19:12     0
UniFi_78:01:d2:5f:bf:81    161221874            0    00:19:12     0
UniFi_78:28:ca:0f:9f:62    1708181500           0    00:19:12     0
UniFi_7a:86:cc:e7:b6:41    1586379590           0    00:19:12     0
UniFi_80:01:24:30:45:30    1886259620           0    00:19:12     0
UniFi_80:1f:12:3f:63:07    908838658           up    00:19:12     0
UniFi_80:2a:a8:53:49:5c    602459266           up    00:19:12     0
UniFi_80:2a:a8:54:49:1f    828233709            0    00:19:12     0
UniFi_80:2a:a8:54:49:5c    1132304760           0    00:19:12     0
UniFi_80:82:23:51:81:5d    68026434             0    00:19:12     0
UniFi_82:2a:a8:54:49:1f    1911605477          up    00:19:12     0
UniFi_82:2a:a8:54:49:5c    658237672            0    00:19:12     0
UniFi_82:2a:a8:55:49:1f    505797360            0    00:19:12     0
UniFi_82:2a:a8:55:49:5c    1079051976           0    00:19:12     0
UniFi_82:ea:70:0c:82:ea    1651866499           0    00:19:12     0
UniFi_84:a1:34:07:08:ee    271143845            0    00:19:12     0
UniFi_88:1f:a1:18:a9:18    98305776             0    00:19:12     0
UniFi_88:40:3b:7a:8a:0a    936774703            0    00:19:12     0
UniFi_88:71:e5:3d:7f:d9    1386121816          up    00:19:12     0
UniFi_8a:7a:ec:5b:94:d2    260028562            0    00:19:12     0
UniFi_8c:c8:cd:67:97:dc    299059414            0    00:19:12     0
UniFi_92:26:92:c1:c8:7a    1136527964           0    00:19:12     0
UniFi_92:2a:a8:55:49:1f    283198646            0    00:19:12     0
UniFi_92:2a:a8:55:49:5c    560132473            0    00:19:12     0
UniFi_98:01:a7:a3:05:f1    1746566630          up    00:19:12     0
UniFi_9a:e5:2f:e3:94:22    437680667            0    00:19:12     0
UniFi_a0:d4:c5:60:52:e5    74144417             0    00:19:12     0
UniFi_a2:05:a5:24:91:aa    1041834872           0    00:19:12     0
UniFi_a4:08:01:da:04:81    1224016011          up    00:19:12     0
UniFi_a4:14:37:34:3d:b0    447291795           up    00:19:12     0
UniFi_a4:c9:72:f1:3e:c9    478259154            0    00:19:12     0
UniFi_a4:d1:8c:d7:29:48    1064733282           0    00:19:12     0
UniFi_a4:f1:e8:aa:6b:40    1420092118           0    00:19:12     0
UniFi_a6:cc:ad:59:da:82    1647377817           0    00:19:12     0
UniFi_a8:55:49:5c:58:e6    494690404            0    00:19:12     0
UniFi_aa:d8:9e:62:dc:8e    447365556            0    00:19:12     0
UniFi_b0:35:b5:a2:e0:4b    1516250936           0    00:19:12     0
UniFi_b0:35:b5:ad:22:f6    1168984339           0    00:19:12     0
UniFi_b0:e8:92:2f:e8:4c    304821718           up    00:19:12     0
UniFi_b2:12:56:82:ff:cf    1539471638           0    00:19:12     0
UniFi_b2:4c:d4:33:0f:8a    111645380           up    00:19:12     0
UniFi_b4:a5:ef:eb:ad:0a    150283853           up    00:19:12     0
UniFi_b8:27:eb:09:ae:c5    136707382           up    00:19:12     0
UniFi_b8:9a:2a:16:d8:20    1032727576           0    00:19:12     0
UniFi_c0:63:94:9c:73:62    392610452            0    00:19:12     0
UniFi_c8:e0:eb:43:cd:bd    1821039540           0    00:19:12     0
UniFi_cc:66:0a:3a:dc:49    1289748394           0    00:19:12     0
UniFi_cc:b8:a8:9e:83:26    494395237           up    00:19:12     0
UniFi_cc:d2:81:6b:25:4c    1357503015          up    00:19:12     0
UniFi_ce:66:b0:1c:4c:f7    1089953582           0    00:19:12     0
UniFi_d0:d2:b0:36:a0:2c    141030115            0    00:19:12     0
UniFi_d2:09:bd:cd:a3:6e    1218580798           0    00:19:12     0
UniFi_d2:47:2a:a1:e4:ae    886817487            0    00:19:12     0
UniFi_d2:bc:2e:93:2b:5b    1720978683           0    00:19:12     0
UniFi_d6:33:c8:4a:d3:17    1585387744           0    00:19:12     0
UniFi_da:ab:72:37:77:98    582652360            0    00:19:12     0
UniFi_de:79:12:d1:66:55    1411943058           0    00:19:12     0
UniFi_e0:63:da:1d:8f:e6    267576472           up    00:19:12     0
UniFi_e0:63:da:1e:8f:e6    1761987056           0    00:19:12     0
UniFi_e2:22:06:41:cc:40    467838419            0    00:19:12     0
UniFi_e2:22:08:3d:c8:54    1536386269           0    00:19:12     0
UniFi_e2:23:05:48:d8:40    547134352            0    00:19:12     0
UniFi_e2:23:06:47:d8:44    1245148598           0    00:19:12     0
UniFi_e2:23:06:49:d8:44    707585161            0    00:19:12     0
UniFi_e2:63:da:1e:8f:e6    144285817            0    00:19:12     0
UniFi_e2:63:da:1f:8f:e6    1162527143           0    00:19:12     0
UniFi_e4:1e:02:50:d0:38    203722803            0    00:19:12     0
UniFi_e4:1f:02:44:b8:3c    1403304084           0    00:19:12     0
UniFi_e4:1f:08:3c:c4:44    1987859841           0    00:19:12     0
UniFi_e4:b2:fb:ab:96:f7    121917301            0    00:19:12     0
UniFi_e4:e7:49:06:71:f6    1901318728          up    00:19:12     0
UniFi_e6:b5:08:66:3e:67    1491731279          up    00:19:12     0
UniFi_e6:b9:77:24:59:b7    1063746442           0    00:19:12     0
UniFi_e8:d3:f4:c0:97:a1    1973305162           0    00:19:12     0
UniFi_ea:a3:95:7f:2f:71    322440867            0    00:19:12     0
UniFi_ec:fa:bc:62:24:b4    891572516           up    00:19:12     0
UniFi_ee:97:bd:84:cb:cc    1041365053           0    00:19:12     0
UniFi_ee:b1:f3:fa:10:cb    1549459798           0    00:19:12     0
UniFi_ee:f0:16:09:e4:f5    1184344629           0    00:19:12     0
UniFi_f0:20:96:16:5b:16    506649762            0    00:19:12     0
UniFi_f0:81:73:74:ef:50    1335486410          up    00:19:12     0
UniFi_f0:99:19:08:90:ed    1363147931           0    00:19:12     0
UniFi_f0:9f:c2:30:e5:89    1110930239          up    00:19:12     0
UniFi_f0:9f:c2:31:e5:89    279986709            0    00:19:12     0
UniFi_f0:a3:5a:3f:b9:47    1365821340           0    00:19:12     0
UniFi_f2:63:da:1f:8f:e6    441945879            0    00:19:12     0
UniFi_f2:9f:c2:31:e5:89    75614724             0    00:19:12     0
UniFi_f2:9f:c2:32:e5:89    1243365444           0    00:19:12     0
UniFi_f4:db:e3:7d:8d:ab    1849466348           0    00:19:12     0
UniFi_f8:77:b8:a8:d2:d6    294596001            0    00:19:12     0
UniFi_f8:80:33:72:6b:68    1136993201           0    00:19:12     0
UniFi_f8:f2:5e:5f:29:ba    904188168            0    00:19:12     0
neighbor_20:2b:c1:7c:90:ed 543055813            0    00:19:12     0
neighbor_30:d3:2d:3e:cc:61 680510143           up    00:19:12     0
neighbor_48:a6:b8:17:e5:33 151576357           up    00:19:12     0
neighbor_50:d4:f7:ec:81:79 562912767            0    00:19:12     0
neighbor_60:38:e0:d4:fd:6b 1674345895           0    00:19:12     0
neighbor_70:0b:01:15:15:43 1302967376          up    00:19:12     0
neighbor_70:5a:0f:02:57:15 1701710208           0    00:19:12     0
neighbor_90:4d:4a:1a:a6:10 1757298163           0    00:19:12     0
neighbor_a0:1d:48:9f:38:cd 467853252            0    00:19:12     0
neighbor_a8:a7:95:07:c7:69 1081699542           0    00:19:12     0
neighbor_a8:d3:f7:d6:70:78 602267964           up    00:19:12     0
neighbor_b4:a5:ef:eb:ad:0b 1703556545           0    00:19:12     0
neighbor_fa:8f:ca:57:bc:5a 1324241541           0    00:19:12     0
===      unifi devices  available  to fingscan    ===        END
2020-10-15 00:19:36 getting vendor info
2020-10-15 00:19:37
2020-10-15 00:19:37 switching off SQL logging for variables
 :ipDevsLastDevChangedIndigoName; ipDevsLastUpdate; ipDevsNewDeviceNo; ipDevsNewIPNumber; ipDevice90;
2020-10-15 00:19:37 switching off SQL logging for variables END
2020-10-15 00:19:37
2020-10-15 00:19:37 switching off SQL logging for devices/state[lastfingup]
 :new-10-9A:7B:A9:DB:A3:C9;
2020-10-15 00:19:37 switching off SQL logging for devices END
2020-10-15 00:20:13 FINGSCAN initialized
That is the source of the lines above.
Fri Oct 16, 2020 4:55 pm
Re: Event resetting
that is the error, looks like the vendor field is not populated, will add an error check
Sat Oct 17, 2020 10:21 am
Re: Event resetting
@MartinG:
please try version .58. have added some checks for empty vendor field.
Mon Oct 19, 2020 5:43 am
MartinG offline
Re: Event resetting
Hi Karl,
I installed .58 as suggested and let it run overnight. Sadly, the problem has reoccurred - 4 out of 5 devices have vanished from the event as before.
Errors in "/Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log" are sparse, and there's nothing in the tail end of yesterday's log
2020-10-19 00:19:03.848   ERROR          Plugin.dorunConcurrentThread     -->  setup config, save, then a manual reload of plugin
2020-10-19 00:19:03 --> while loop break  stopping ...  quitNOW was: please setup config , waiting
2020-10-19 00:19:03.854   ERROR          Plugin.dorunConcurrentThread     --> you have 2 minutes to fix config, before restart
2020-10-19 00:19:03.855   ERROR          Plugin.dorunConcurrentThread     --> do a manual reload of plugin
2020-10-19 00:19:04 stopConcurrentThread called 2
2020-10-19 00:19:07 =========================   initializing   ==============================================
2020-10-19 00:19:07 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2020-10-19 00:19:07 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2020-10-19 00:19:07 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2020-10-19 00:19:07 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2020-10-19 00:19:07.610   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2020-10-19 00:19:07.610   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2020-10-19 00:19:08 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-10-19 00:19:08 indigo variables initialized
2020-10-19 00:19:08 getting password
2020-10-19 00:19:08 get password done;  checking if FING is installed
2020-10-19 00:19:10 fing install check done
2020-10-19 00:19:12 loaded indigo data
2020-10-19 00:19:12 network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
2020-10-19 00:19:12 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-10-19 00:19:12 MAP2Vendor initializing
2020-10-19 00:19:14 Initializing parameters for FING
startfing               L:237 Lv:20 ========= start   @ 2020-10-19 00:19:15.836899   ===========
2020-10-19 00:19:17 Waiting for first data from FING
2020-10-19 00:19:37 Checking if FING created output, old timeStamp:1603063093.45; new timeStamp:1603063162.1
2020-10-19 00:19:37 Initializing ..  FING created new data   waiting ~ 1 minute for stable operation
2020-10-19 00:19:37 FING Pids active after step3 = [u'216']
2020-10-19 00:19:37   (re)started FING, initialized
2020-10-19 00:19:37 settings:  iDevicesEnabled              False
2020-10-19 00:19:37 settings:  inbetweenPingType            parallel
2020-10-19 00:19:37 settings:  wifiRouter                   0
2020-10-19 00:19:37 settings:  wait seconds between cycles  5
2020-10-19 00:19:37 settings:  password entered             True
2020-10-19 00:19:37 settings:  debugLevel                   []
2020-10-19 00:19:37 settings:  FINGSCAN will scan Network   192.168.1....  # fixed bits in ip range:24
2020-10-19 00:19:37
2020-10-19 00:19:37
time WhenLast DOWN:   # 5:       02:42:24
time WhenLast UP:     # 5:       07:50:40
seconds WhenLast UP:  # 5:          59339
seconds WhenLast DOWN:# 5:          77835
Time right now:          :    00:19:37
AtLeast ONE Device  Home :           0  -- reacts after minTimeNotHome
Event enabled            :           1
dataFormat               :         3.0
Further down in the same log, the disappearing devices are identified as 'up':
UniFi_5a:a2:df:e0:1c:6c    695419029           up    00:19:13     0
UniFi_b2:4c:d4:33:0f:8a    111645380           up    00:19:13     0
UniFi_e6:b5:08:66:3e:67    1491731279          up    00:19:13     0
Any other suggestions/debug parameters I could try to gather more information?
Mon Oct 19, 2020 7:01 am
Re: Event resetting
When do the devices disappear from the events?
After restart of plugin or just when the plugin is running?
And they are not fing devices but devices linked to unifi?
Also this indicates a real problem:
The plugin does not start properly.
Tue Oct 20, 2020 3:13 am
MartinG offline
Re: Event resetting
Hi Karl,
In answer to your questions:
It looks like they disappear around 19 minutes after midnight. In the following (from plugin.log, with most of the debug options enabled) the devices are listed in the event definitions at 00:18:33, but are not listed in the event definitions a minute later after the restart at 00:19:40
2020-10-20 00:18:33
dev#:  1 -- devNam:Freya's iPhone SE         -- MAC#:E6:B5:08:66:3E:67 -- ip#:192.168.1.148   -- status:up       -- WiFi:
dev#:  2 -- devNam:Eloise's iPhone XR        -- MAC#:5A:A2:DF:E0:1C:6C -- ip#:192.168.1.153   -- status:down     -- WiFi:
dev#:  3 -- devNam:Sophie's iPhone XR        -- MAC#:D2:47:2A:A1:E4:AE -- ip#:192.168.1.154   -- status:expired  -- WiFi:
dev#:  4 -- devNam:Martin's iPhone X         -- MAC#:B2:4C:D4:33:0F:8A -- ip#:192.168.1.150   -- status:up       -- WiFi:
currentStatusHome:    # 1:           HOME  # 2:              0  # 3:              0  # 4:           HOME  # 5:           HOME
currentStatusAway:    # 1:              0  # 2:   startedTimer  # 3:           AWAY  # 4:              0  # 5:              0
time WhenLast DOWN:   # 1:       23:52:33  # 2:       00:17:36  # 3:       12:21:23  # 4:       19:52:33  # 5:       13:56:31
time WhenLast UP:     # 1:       00:18:33  # 2:       00:17:31  # 3:       13:31:24  # 4:       00:18:33  # 5:       00:18:33
seconds WhenLast UP:  # 1:              2  # 2:             64  # 3:          43002  # 4:              2  # 5:              2
seconds WhenLast DOWN:# 1:           1562  # 2:             59  # 3:          43002  # 4:          15962  # 5:          37324
Time right now:          :    00:18:33
ALL Devices         Home :           0  -- reacts after minTimeNotHome
AtLeast ONE Device  Away :           1  -- reacts minTimeAway bf Trig
Event enabled            :           1
dataFormat               :         3.0
2020-10-20 00:19:05.464   ERROR          Plugin.dorunConcurrentThread     -->  setup config, save, then a manual reload of plugin
2020-10-20 00:19:05 --> while loop break  stopping ...  quitNOW was: please setup config , waiting
2020-10-20 00:19:05.465   ERROR          Plugin.dorunConcurrentThread     --> you have 2 minutes to fix config, before restart
2020-10-20 00:19:05.465   ERROR          Plugin.dorunConcurrentThread     --> do a manual reload of plugin
2020-10-20 00:19:05 stopConcurrentThread called 2
2020-10-20 00:19:09 =========================   initializing   ==============================================
2020-10-20 00:19:09 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2020-10-20 00:19:09 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2020-10-20 00:19:09 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2020-10-20 00:19:09 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2020-10-20 00:19:09.231   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2020-10-20 00:19:09.231   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2020-10-20 00:19:10 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-10-20 00:19:10 indigo variables initialized
2020-10-20 00:19:10 getting password
2020-10-20 00:19:10 get password done;  checking if FING is installed
2020-10-20 00:19:12 fing install check done
2020-10-20 00:19:15 loaded indigo data
2020-10-20 00:19:15 network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
2020-10-20 00:19:15 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-10-20 00:19:15 MAP2Vendor initializing
2020-10-20 00:19:15 updating unifi:  devName UniFi_78:01:d2:5f:bf:81  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_78:01:d2:5f:bf:81  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:10:18:55:44:4b  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:10:18:55:44:4b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_c6:45:b3:fb:87:2b  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_c6:45:b3:fb:87:2b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_de:79:12:d1:66:55  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_de:79:12:d1:66:55  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_30:d3:2d:3e:cc:61  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_30:d3:2d:3e:cc:61  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:9f:c2:31:e5:89  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:9f:c2:31:e5:89  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:63:da:1f:8f:e6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:63:da:1f:8f:e6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:00:00:00:00:01  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:00:00:00:00:01  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b2:12:56:82:ff:cf  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_b2:12:56:82:ff:cf  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_42:77:02:2b:c7:e3  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_42:77:02:2b:c7:e3  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:54:49:5c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:54:49:5c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:83:bf:cb:58:7d  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:83:bf:cb:58:7d  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_02:9f:c2:32:e5:89  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_02:9f:c2:32:e5:89  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_38:71:de:aa:b0:42  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_38:71:de:aa:b0:42  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:24:e4:00:b3:7b  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:24:e4:00:b3:7b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:80:33:72:6b:68  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:80:33:72:6b:68  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName AP_e0:63:da:1d:8f:e6  Status up
2020-10-20 00:19:15 updating unifi:  devName AP_e0:63:da:1d:8f:e6  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_70:ee:50:1f:39:fa  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_70:ee:50:1f:39:fa  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:84:11:ff:fe:80  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:84:11:ff:fe:80  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_2e:3d:88:ff:5c:44  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_2e:3d:88:ff:5c:44  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_a8:a7:95:07:c7:69  Status up
2020-10-20 00:19:15 updating unifi:  devName neighbor_a8:a7:95:07:c7:69  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:54:49:1f  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:54:49:1f  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_0a:0a:78:76:1b:70  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_0a:0a:78:76:1b:70  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:1f:a1:18:a9:18  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:1f:a1:18:a9:18  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:35:b5:ad:22:f6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:35:b5:ad:22:f6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:d0:2d:a9:6a:03  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:d0:2d:a9:6a:03  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:06:47:d8:44  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:06:47:d8:44  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1e:02:50:d0:38  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1e:02:50:d0:38  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_30:63:6b:d9:02:90  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_30:63:6b:d9:02:90  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_a0:1d:48:9f:38:cd  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_a0:1d:48:9f:38:cd  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName AP_80:2a:a8:53:49:1f  Status up
2020-10-20 00:19:15 updating unifi:  devName AP_80:2a:a8:53:49:1f  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_12:61:3e:de:f5:0d  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_12:61:3e:de:f5:0d  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_a8:d3:f7:d6:70:78  Status up
2020-10-20 00:19:15 updating unifi:  devName neighbor_a8:d3:f7:d6:70:78  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_48:a6:b8:17:e5:33  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_48:a6:b8:17:e5:33  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_b4:a5:ef:eb:ad:0b  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_b4:a5:ef:eb:ad:0b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_66:9b:eb:97:26:fe  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_66:9b:eb:97:26:fe  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:09:bd:cd:a3:6e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:09:bd:cd:a3:6e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:c9:72:f1:3e:c9  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:c9:72:f1:3e:c9  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_56:54:ad:90:92:3e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_56:54:ad:90:92:3e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:40:3b:7a:8a:0a  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:40:3b:7a:8a:0a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName Mower  Status up
2020-10-20 00:19:15 updating unifi:  devName Mower  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_fa:8f:ca:57:bc:5a  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_fa:8f:ca:57:bc:5a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:b2:fb:ab:96:f7  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:b2:fb:ab:96:f7  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a2:05:a5:24:91:aa  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a2:05:a5:24:91:aa  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:d2:81:6b:25:4c  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:d2:81:6b:25:4c  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1f:02:50:d4:34  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1f:02:50:d4:34  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e2:8f:a8:fc:26  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e2:8f:a8:fc:26  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:02:fc:62:00:00  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:02:fc:62:00:00  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_4c:57:ca:35:49:d8  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_4c:57:ca:35:49:d8  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:81:73:74:ef:50  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:81:73:74:ef:50  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_c0:63:94:9c:73:62  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_c0:63:94:9c:73:62  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_9a:e5:2f:e3:94:22  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_9a:e5:2f:e3:94:22  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e8:d3:f4:c0:97:a1  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e8:d3:f4:c0:97:a1  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_0e:ef:32:81:f5:9a  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_0e:ef:32:81:f5:9a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:20:96:16:5b:16  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:20:96:16:5b:16  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:14:37:34:3d:b0  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:14:37:34:3d:b0  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:40:4e:a5:99:5d  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:40:4e:a5:99:5d  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1e:02:50:d0:38  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1e:02:50:d0:38  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b2:4c:d4:33:0f:8a  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_b2:4c:d4:33:0f:8a  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:26:05:4b:dc:44  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:26:05:4b:dc:44  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_50:d4:f7:ec:81:79  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_50:d4:f7:ec:81:79  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e6:b5:08:66:3e:67  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_e6:b5:08:66:3e:67  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:e8:92:2f:e8:4c  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:e8:92:2f:e8:4c  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:1f:12:3f:63:07  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:1f:12:3f:63:07  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName AP_80:2a:a8:53:49:5c  Status up
2020-10-20 00:19:15 updating unifi:  devName AP_80:2a:a8:53:49:5c  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:bb:3a:f7:e3:1f  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:bb:3a:f7:e3:1f  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:bc:2e:93:2b:5b  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:bc:2e:93:2b:5b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_90:4d:4a:1a:a6:10  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_90:4d:4a:1a:a6:10  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:54:49:5c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:54:49:5c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_54:54:7d:e7:5f:3e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_54:54:7d:e7:5f:3e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1f:02:50:d0:38  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_64:1f:02:50:d0:38  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_8a:7a:ec:5b:94:d2  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_8a:7a:ec:5b:94:d2  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:77:b8:a8:d2:d6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:77:b8:a8:d2:d6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_5a:c3:34:bc:20:5e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_5a:c3:34:bc:20:5e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:d1:8c:d7:29:48  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:d1:8c:d7:29:48  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:53:49:5c  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:2a:a8:53:49:5c  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:e4:df:82:c3:d8  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:e4:df:82:c3:d8  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e6:ba:31:11:9e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e6:ba:31:11:9e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_78:28:ca:0f:9f:62  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_78:28:ca:0f:9f:62  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1f:02:44:b8:3c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1f:02:44:b8:3c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:23:06:43:d0:54  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:23:06:43:d0:54  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_84:a1:34:07:08:ee  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_84:a1:34:07:08:ee  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:2a:a8:55:49:1f  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:2a:a8:55:49:1f  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e0:63:da:1d:8f:e6  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_e0:63:da:1d:8f:e6  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:08:01:da:04:81  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:08:01:da:04:81  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a0:d4:c5:60:52:e5  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a0:d4:c5:60:52:e5  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:cb:c0:cf:97:37  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:cb:c0:cf:97:37  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:5b:35:93:d0:b4  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:5b:35:93:d0:b4  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:9f:c2:31:e5:89  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:9f:c2:31:e5:89  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_48:a9:d2:f6:a0:5d  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_48:a9:d2:f6:a0:5d  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:9f:c2:32:e5:89  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f2:9f:c2:32:e5:89  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_14:c2:13:b7:ca:c2  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_14:c2:13:b7:ca:c2  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:f7:28:d9:51:b6  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:f7:28:d9:51:b6  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:22:06:41:cc:40  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:22:06:41:cc:40  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:f2:5e:5f:29:ba  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f8:f2:5e:5f:29:ba  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_6c:40:08:b1:49:b8  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_6c:40:08:b1:49:b8  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_c8:e0:eb:43:cd:bd  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_c8:e0:eb:43:cd:bd  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_5c:41:f5:33:ad:45  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_5c:41:f5:33:ad:45  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName SW_e0:63:da:85:3b:58  Status up
2020-10-20 00:19:15 updating unifi:  devName SW_e0:63:da:85:3b:58  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_d6:33:c8:4a:d3:17  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_d6:33:c8:4a:d3:17  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_0c:4d:e9:d2:b7:64  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_0c:4d:e9:d2:b7:64  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_da:ab:72:37:77:98  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_da:ab:72:37:77:98  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:66:0a:3a:dc:49  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:66:0a:3a:dc:49  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:99:19:08:90:ed  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:99:19:08:90:ed  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_8c:c8:cd:67:97:dc  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_8c:c8:cd:67:97:dc  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:54:49:1f  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:54:49:1f  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a6:cc:ad:59:da:82  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a6:cc:ad:59:da:82  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:9c:28:54:6c:13  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:9c:28:54:6c:13  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_aa:d8:9e:62:dc:8e  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_aa:d8:9e:62:dc:8e  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:55:49:5c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:55:49:5c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:ea:70:0c:82:ea  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:ea:70:0c:82:ea  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:ee:69:10:ef:d6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:ee:69:10:ef:d6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a8:55:49:5c:58:e6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a8:55:49:5c:58:e6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_44:18:fd:e5:05:75  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_44:18:fd:e5:05:75  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1f:08:3c:c4:44  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:1f:08:3c:c4:44  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_2c:6a:cb:22:67:5c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_2c:6a:cb:22:67:5c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ce:66:b0:1c:4c:f7  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_ce:66:b0:1c:4c:f7  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ec:fa:bc:62:24:b4  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_ec:fa:bc:62:24:b4  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e0:63:da:1e:8f:e6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e0:63:da:1e:8f:e6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_70:0b:01:15:15:43  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_70:0b:01:15:15:43  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:2a:a8:55:49:5c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:2a:a8:55:49:5c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_98:01:a7:a3:05:f1  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_98:01:a7:a3:05:f1  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:01:24:30:45:30  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:01:24:30:45:30  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b8:9a:2a:16:d8:20  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_b8:9a:2a:16:d8:20  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:26:07:4f:ec:4c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:26:07:4f:ec:4c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:f1:e8:aa:6b:40  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_a4:f1:e8:aa:6b:40  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_5e:ac:ed:2b:1f:4d  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_5e:ac:ed:2b:1f:4d  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:9f:c2:30:e5:89  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:9f:c2:30:e5:89  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:1e:c0:9d:0d:b8  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:1e:c0:9d:0d:b8  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_38:f9:d3:5a:cd:d3  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_38:f9:d3:5a:cd:d3  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_4c:17:44:d2:31:47  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_4c:17:44:d2:31:47  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:63:da:1e:8f:e6  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:63:da:1e:8f:e6  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:b8:a8:9e:83:26  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_cc:b8:a8:9e:83:26  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_50:f5:da:86:c5:47  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_50:f5:da:86:c5:47  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_44:39:c4:7e:3d:e7  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_44:39:c4:7e:3d:e7  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:24:05:48:d8:58  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:24:05:48:d8:58  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:0e:58:13:c4:84  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:0e:58:13:c4:84  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:55:49:1f  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_82:2a:a8:55:49:1f  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:f0:16:09:e4:f5  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:f0:16:09:e4:f5  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_5a:a2:df:e0:1c:6c  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_5a:a2:df:e0:1c:6c  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f4:db:e3:7d:8d:ab  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f4:db:e3:7d:8d:ab  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_30:35:ad:d9:cf:7a  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_30:35:ad:d9:cf:7a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName AP_f0:9f:c2:30:e5:89  Status up
2020-10-20 00:19:15 updating unifi:  devName AP_f0:9f:c2:30:e5:89  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:d9:c7:46:66:e2  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_60:d9:c7:46:66:e2  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:a3:5a:3f:b9:47  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_f0:a3:5a:3f:b9:47  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:83:1d:13:1b:b2  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_40:83:1d:13:1b:b2  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:63:da:1f:8f:e6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:63:da:1f:8f:e6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:22:08:3c:cc:50  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_62:22:08:3c:cc:50  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:55:e3:56:d7:15  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:55:e3:56:d7:15  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:27:37:b2:94:8a  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_68:27:37:b2:94:8a  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:1a:e9:95:7f:cc  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:1a:e9:95:7f:cc  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_6e:9a:62:8f:b4:d6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_6e:9a:62:8f:b4:d6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:26:92:c1:c8:7a  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_92:26:92:c1:c8:7a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:da:43:0f:31:e2  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:da:43:0f:31:e2  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_60:38:e0:d4:fd:6b  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_60:38:e0:d4:fd:6b  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b4:a5:ef:eb:ad:0a  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_b4:a5:ef:eb:ad:0a  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e6:b9:77:24:59:b7  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e6:b9:77:24:59:b7  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b8:27:eb:09:ae:c5  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_b8:27:eb:09:ae:c5  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:47:2a:a1:e4:ae  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_d2:47:2a:a1:e4:ae  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_d0:d2:b0:36:a0:2c  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_d0:d2:b0:36:a0:2c  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ea:a3:95:7f:2f:71  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_ea:a3:95:7f:2f:71  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:ee:69:10:ef:d7  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_18:ee:69:10:ef:d7  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_14:c2:13:dc:91:7a  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_14:c2:13:dc:91:7a  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e6:ba:59:63:3b  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_58:e6:ba:59:63:3b  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:22:08:3d:c8:54  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:22:08:3d:c8:54  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_54:33:cb:ea:e8:47  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_54:33:cb:ea:e8:47  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_20:2b:c1:7c:90:ed  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_20:2b:c1:7c:90:ed  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_0a:dd:9a:77:81:c7  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_0a:dd:9a:77:81:c7  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:e7:49:06:71:f6  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_e4:e7:49:06:71:f6  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:4e:89:0d:8d:81  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:4e:89:0d:8d:81  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_74:b5:87:7d:0c:f5  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_74:b5:87:7d:0c:f5  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:06:49:d8:44  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:06:49:d8:44  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:02:b5:90:0d:49  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_10:02:b5:90:0d:49  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:0e:58:01:17:72  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:0e:58:01:17:72  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:97:bd:84:cb:cc  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:97:bd:84:cb:cc  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_7a:86:cc:e7:b6:41  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_7a:86:cc:e7:b6:41  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:db:70:ac:79:f8  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:db:70:ac:79:f8  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:04:20:f7:0a:5e  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_00:04:20:f7:0a:5e  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:82:23:51:81:5d  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_80:82:23:51:81:5d  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_74:9e:af:26:81:c6  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_74:9e:af:26:81:c6  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:b1:f3:fa:10:cb  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_ee:b1:f3:fa:10:cb  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_0e:9a:ad:f3:74:20  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_0e:9a:ad:f3:74:20  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:05:48:d8:40  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_e2:23:05:48:d8:40  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName neighbor_70:5a:0f:02:57:15  Status expired
2020-10-20 00:19:15 updating unifi:  devName neighbor_70:5a:0f:02:57:15  Status expired not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:71:e5:3d:7f:d9  Status up
2020-10-20 00:19:15 updating unifi:  devName UniFi_88:71:e5:3d:7f:d9  Status up not ready
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:35:b5:a2:e0:4b  Status expired
2020-10-20 00:19:15 updating unifi:  devName UniFi_b0:35:b5:a2:e0:4b  Status expired not ready
2020-10-20 00:19:16 Initializing parameters for FING
2020-10-20 00:19:18 FING cmd= /usr/bin/python2.7 '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/startfing.py' '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/paramsForStart'  &
2020-10-20 00:19:18   waiting for FING to start and produce output pid
startfing               L:237 Lv:20 ========= start   @ 2020-10-20 00:19:18.505752   ===========
2020-10-20 00:19:19 Waiting for first data from FING
2020-10-20 00:19:39 Checking if FING created output, old timeStamp:1603149511.69; new timeStamp:1603149565.06
2020-10-20 00:19:39 Initializing ..  FING created new data   waiting ~ 1 minute for stable operation
2020-10-20 00:19:40 FING Pids active after step3 = [u'60081']
2020-10-20 00:19:40   (re)started FING, initialized
2020-10-20 00:19:40 settings:  iDevicesEnabled              False
2020-10-20 00:19:40 settings:  inbetweenPingType            parallel
2020-10-20 00:19:40 settings:  wifiRouter                   0
2020-10-20 00:19:40 settings:  wait seconds between cycles  5
2020-10-20 00:19:40 settings:  password entered             True
2020-10-20 00:19:40 settings:  debugLevel                   [u'Wifi', u'Events', u'Unifi', u'BC', u'Special']
2020-10-20 00:19:40 settings:  FINGSCAN will scan Network   192.168.1....  # fixed bits in ip range:24
2020-10-20 00:19:40
2020-10-20 00:19:40
currentStatusHome:    # 5:              0
currentStatusAway:    # 5:   startedTimer
time WhenLast DOWN:   # 5:       12:14:29
time WhenLast UP:     # 5:       12:14:29
seconds WhenLast UP:  # 5:          43513
seconds WhenLast DOWN:# 5:          43513
Time right now:          :    00:19:40
Event enabled            :           1
dataFormat               :         3.0
It looks like it happens around the restart of the plugin, though I can't pinpoint the exact timing, or which is cause and which is effect.
I don't really understand the question I'm afraid (what is a "fing device"?) so hopefully this answers it. They are all iPhones connected to a unifi wifi network, to which a fingbox is also connected. I have both the fingscan and unifiAP Indigo plugins installed, and I'm running the Fing app on the same machine that hosts indigo. I have no idea why the unifi prefix is added to their MAC addresses in the device list.
Tue Oct 20, 2020 7:33 am
Re: Event resetting
1. Unifi vs fing
the plugin can use several "things" for events:
1. devices create by fing plugin (name fing_ or new_..)
2. devices created by unifi plugin (normally unifi_..)
3. devices created by piBeacon plugin ...
they are handled differently
2. looking at the logfile: it seems that between first event log print and the second the plugin restarts
3 .the log entry :
"2020-10-20 00:19:05.464 ERROR Plugin.dorunConcurrentThread --> setup config, save, then a manual reload of plugin
2020-10-20 00:19:05.465 ERROR Plugin.dorunConcurrentThread --> do a manual reload of plugin"
indicates the the plugin is not happy. something is wrong:
>>> setup config, save, then a manual reload of plugin<<<
indicates the plugin is not setup correctly, something is missing
so could you send a screen copy of your config setup?
Tue Oct 20, 2020 9:47 am
Re: Event resetting
i just posted v .60 that saves the event defs immedeately any time there is a change, (indigo does that normally on a scheduled basis)
but there is still a problem that the plugin just restarts, reason unclear.
