Filling up my harddrive (cores folder)
Tue May 12, 2020 11:46 pm
Simon offline
I have been using the Fingscan plugin for years and thank you very much for your work :-)
Last night i installed the latest update and went to bed. This morning my servers harddrive was completely full and i tracked the problem down to the Cores folder. When i turn the Fingscan plugin off the drive immediately stops filling up.
Mac os x 10.14.6
Indigo 7.4.0
Fingscan 7.31.54
Simon
Wed May 13, 2020 4:03 am
Re: Filling up my harddrive (cores folder)
Where is the cores folder?. And what is in it? Log files?
Wed May 13, 2020 10:47 am
yassi offline
The /cores folder is used for dumps.
Had the issue too in the past.
Have a look here:
https://apple.stackexchange.com/questio ... t-of-space
Gesendet von iPhone mit Tapatalk
Wed May 13, 2020 12:14 pm
thanks for the /cores pointer,
mine is empty and fingscan is running w/o problems.
@simon:
is there anything in the /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log file -- besides the regular startup stuff?
