Requires Indigo 2023.2 - Will not run on earlier versions!
Changes in this version:
- Improved python package handling provided by Indigo 2023.2
- Code improvements
Requirements installing, this may take a few seconds...
Error Requirements file for "Sonos 2024.0.3" failed to process correctly, contact the developer with the following information:
Error error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [4 lines of output]
<string>:67: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
Building lxml version 4.9.4.
Building without Cython.
Error: Please make sure the libxml2 and libxslt development packages are installed.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
mclass wrote:HiMany thanks for the update that I installed today (Indigo 2023.2) with the following error:
- Code: Select all
│ exit code: 1
[end of output]
│ exit code: 1
It appears that I may have some packages missing, but my lack of Python knowledge/skills suggests I should wait for some learned advice!!
Neil
mclass wrote:... It appears that I may have some packages missing, but my lack of Python knowledge/skills suggests I should wait for some learned advice!!
Sonos Error 'HTTP Error 403: Forbidden' in module 'request.py', method 'http_error_default [2024.0.4]'
Failing statement [line 643]: 'raise HTTPError(req.full_url, code, msg, hdrs, fp)'
