Sonos issue with a ZONE Player
Wed Dec 13, 2023 10:26 pm
Brian Gaiser offline
What could this problem be? Seems my SUB woofer which is 192.168.11.21 is causing issues...
Sonos Plugin startup started.
Sonos [Wed Dec 13 23:22:26 2023] Processed plugin preferences.
Sonos Serving HTTP Streamer on 192.168.11.109 [0.0.0.0], port 8888
Sonos Loaded Apple Voices.. [144]
Sonos SSDP Listener Started...
Sonos Plugin startup ended.
Sonos Adding ZonePlayer: 192.168.11.23, RINCON_000E58FDA68E01400, Sonos Dining Room
Sonos Adding ZonePlayer: 192.168.11.20, RINCON_C4387553C80701400, Sonos First Level
Sonos Adding ZonePlayer: 192.168.11.134, RINCON_48A6B86C525901400, Sonos Lower Level
Sonos Adding ZonePlayer: 192.168.11.22, RINCON_48A6B86C663F01400, Sonos Outdoors
Sonos Adding ZonePlayer: 192.168.11.25, RINCON_48A6B86C51BA01400, Sonos Pool
Sonos Adding ZonePlayer: 192.168.11.24, RINCON_000E58FE8C5A01400, Sonos Porch
Sonos Adding ZonePlayer: 192.168.11.21, RINCON_542A1B1CFB9E01400, Sonos Sub
Sonos SoCo Reactor Ignition...
Sonos LineIn: RINCON_C4387553C80701400, Audio Component:First Level (LF,RF)
Sonos Error UPNP Error: 500
Sonos Error Offending Command -> zoneIP: 192.168.11.21, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Error Error Response:
Sonos Error Q_Save - ZP type is '<class 'str'>', value is ''
Sonos Loaded Playlists... [8]
Sonos Error copyStateFromMaster - Unable to split Group Name:
Sonos LineIn: RINCON_48A6B86C525901400, Audio Component:Lower Level
Sonos LineIn: RINCON_48A6B86C663F01400, Audio Component:Outdoors
Sonos Loaded Playlists... [9]
It keeps saying this. Also tried the latest beta.
Thu Dec 14, 2023 6:38 am
ryanbuckner offline
Re: Sonos issue with a ZONE Player
I had to remove all my HT surround (L & R) and sub from the plugin. It didn't like the groupings
Thu Dec 14, 2023 7:50 am
I do have SUB connected to "First Level" in my setup. So... I can NEVER have that? That's the point of Sub... no?
Thu Dec 14, 2023 8:17 am
rapamatic offline
The sub is always linked to another device. Even in the Sonos app you don't see the sub as a stand alone speaker.
I can't think of a reason to control the sub from Indigo....
Thu Dec 14, 2023 9:07 am
I didn't intend to. I only added it as a device because the plugin "found" the IP and I assumed the "null" zone player was because of it not being defined. I can undo that....
Thu Dec 14, 2023 9:10 am
That fixed it. Duh... don't know why I thought I had to add it. Thanks.
