Water level
Mon Dec 11, 2023 11:00 am
MarcoGT offline
Water level
Hi all,
I need to monitor the water in a tank, and get a notification when is above a certain level. The tank must be always empty (in reality is not a tank, but the windows of my basement ) and I need a notification when too much water is in inside it.
Which is the best solution? Shelly 1? Any external wire needed?
Mon Dec 11, 2023 11:08 am
MarcoGT offline
Re: Water level
To be more precise, I do not need the water level, but an on/off signal which is triggered when the water is too high
Would this one work with a Shelly 1 Plus?
https://www.amazon.de/Wasserstandssenso ... euerung-Flüssigkeitsregler-Aquarienpumpe/dp/B097N7XF48/ref=asc_df_B097N7XF48/?tag=googshopde-21&linkCode=df0&hvadid=664223527374&hvpos=&hvnetw=g&hvrand=13209248895419380265&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9042581&hvtargid=pla-1416049285330&psc=1&mcid=3a71f7b5eace3c3cbbc8fa78b02278d0&th=1&psc=1#aw-udpv3-customer-reviews_feature_div
Mon Dec 11, 2023 11:24 am
MarcoGT offline
Re: Water level
Or maybe using the Shelly Addon connected to a Shelly Pkus and then a sensor which closes the contact when hit by water?
The question is if the Shelly addon is supported by the Shelly plugin
Mon Dec 11, 2023 11:50 am
Re: Water level
I use a float sensor connected to one of the X10 IO plugin units to monitor the drain pan under my main AC unit.
Mon Dec 11, 2023 1:17 pm
MarcoGT offline
Re: Water level
Ok float sensor came also to my mind, but I have z wave or zigbee available, no X10
Mon Dec 11, 2023 1:55 pm
Dual offline
Re: Water level
Can you use a water sensor such as:
HomeSeer HS-LS100+ Z-Wave Plus Leak Sensor.
It comes with a cable and probe.
MarcoGT offline
Re: Water level
But I think that it will last that long outdoor
Mon Dec 11, 2023 3:26 pm
Re: Water level
More than likely, the float is a simple switch, so any I/O input that works with switches should work.
Tue Dec 12, 2023 1:28 am
MarcoGT offline
Re: Water level
Yes then why not connect the floating sensor to a Shelly 1 Plus which is basically an open contact (no potential) which gets closed when the floating sensor is triggered?
Tue Dec 12, 2023 5:30 am
Re: Water level
Precisely.
My only gig on the Shelly is that it's WiFi and not Z-Wave, but it should be fine with one of the Shelly plugins.
Tue Dec 12, 2023 6:26 am
MarcoGT offline
Re: Water level
Yes, exactly, I bought one of those floating sensor, I will connect it to the SW pin of the Shelly and I am done
