Forum rules
- Posted on
Wed Feb 16, 2022 5:28 am
haakon
offline
Hi! Is there any chance this smoke detector will be supported?
And is there something I could do to get the needed information for Indigo support?
- Posted on
Wed Feb 16, 2022 4:28 pm
haakon
offline
- Posted on
Fri Feb 18, 2022 12:45 pm
matt (support)
offline
- Site Admin
There isn't a device definition for it, so it will probably work but you'll need to use the
Match Raw Packet type of trigger. If you get one then copy/paste the Event Log window sync results so we can work on adding a definition for it.
- Posted on
Sat Jun 25, 2022 2:36 pm
haakon
offline
Hi, I finally got around to ordering one of these. Are there any instructions for how the the Match Raw Packet trigger is used to help you add a definition? I am not sure what I should do here.
This device is a smoke detector with a built in motion detector. Will that affect the procedure?
- Posted on
Sun Jun 26, 2022 5:10 pm
matt (support)
offline
- Site Admin
Can you open the device settings dialog and press the button to write the details to the Event Log window, then copy/paste the contents of that into a reply for me? I'll look at getting a device definition added for it.
- Posted on
Fri Feb 24, 2023 3:52 pm
matt (support)
offline
- Site Admin
We've added support for the HeatIt Z-Smoke Z-Smoke Multisensor
in Indigo 2022.2.0, which is now available.
