WeatherFlow Tempest Variables
Thu Apr 18, 2024 12:42 pm
CraigM offline
The WeatherFlow Plug-in creates a list of variables (see photo)
Does anyone know what is populating the data?
How can I use the data since these are not in the Indigo pull-down menus for schedules etc?
All my prefs are set to ºF, but these numbers are not
WeatherFlow Variables.png (330.15 KiB) Viewed 730 times
Thu Apr 18, 2024 3:03 pm
Re: WeatherFlow Tempest Variables
If you explain what you want to use the data for, we can explain how to do it.
Thu Apr 18, 2024 3:23 pm
CraigM offline
I want to place var data on a control page, but the data appears to be ºC
Where is this var data coming from and how do I get it into ºF? The plug-in's config is set to ºF
Thu Apr 18, 2024 4:28 pm
Taking a quick look at the code, it looks like the temp conversion is only done for the device states. Not the summary data in the variables.
I'm not sure but it looks like the variables are really there for debugging.
Thu Apr 18, 2024 10:31 pm
CraigM offline
Since this plugin is no longer being maintained, do you know anyone who would be willing to take ownership for the future? These are great weather stations, I highly recommend.
Is there a way, using a Python script, to take a variable ID containing ºC data and convert it into ºF, then insert it into another variable?
Fri Apr 19, 2024 5:33 am
Sat Apr 20, 2024 8:45 am
Dual offline
I use GhostXML plugin to get data from my Tempest weather stations. I prefer it over the Tempest plugin.
My station reports in degC. When the GhostXML device state changes I have a trigger that puts the Celsius temperature into a variable and a python script that converts to Fahrenheit and puts into a second variable. I display both variables on my control page. I also display the date and time it was last updated.
If you need more info let me know.
Cheers
John
Sat Apr 20, 2024 10:10 am
jalves offline
That sounds like a great idea. I'll have to do some playing around with mine.
Jeff
