JAB5150 wrote:I followed the instruction on the thread name "LWC Indigo Web Server (IWS) Plug-in" but the instruction it said to enter this URL "http://host:port/lwc/importData? ". I have tried port 1176 & 8176 but both fail.
What should I use as the port number?
Also, just to make sure the host is the Indigo Server address, correct?
Doh, sorry, I pointed you to the wrong forum thread. I'll try to move it, but yes, the port you want is the web server port (specified on the "Start Local Server" dialog, which defaults to 8176) on the Indigo Server machine. Also, when you start the server, make sure that you see the following lines in the Event Log:
- Code: Select all
WebServer client authenticated
WebServer started on port 8080 -- digest authentication enabled
WebServer enabled browser access to plugin path "plugins/lwc/css"
There may be other lines between the authentication stuff and the "plugins/lwc/css" line, but make sure it's there. If it isn't, then it's not installed properly - revisit the installation instructions.
A couple of other questions:
1) In LWC's Custom CGI On-Line preference (where you set up the url), what does the Current Status box say?
2) In a browser, what do you see when you go to "http://127.0.0.1:8080/lwc/"?
