Controlling Indigo from Command Line (or .py files)
Wed Aug 24, 2011 4:39 pm
I've updated the Plugin Scripting Tutorial to show how you can now pass Indigo commands (and python source) to Indigo, and how you can execute Indigo python files. See the tutorial for the details on setting up an indigohost shell alias, but below are a few examples.
Get the current brightness of the device “office lamplinc”:
indigohost -e 'return indigo.devices["office lamplinc"].brightness'
Toggle the device “office lamplinc” three times:
indigohost -e '
Execute an Indigo python file:
indigohost -x /SomeFolder/indigo_script.py'
Note there is some overhead each time you call indigohost since it creates a new process and has to establish a connection to the Indigo Server.
Embedded python scripts inside Indigo actions (schedules, triggers, etc.) don't have this overhead because they all share a single indigohost (IPH) process, but because of this the Indigo Server only allows embedded python scripts 10 seconds to execute. If they take more than 10 seconds, then they should be broken out into a .py file which will create a new process (but have the overhead of having to establish a new Indigo Server connection).
Fri Jul 05, 2013 10:23 am
Perry The Cynic offline
Re: Controlling Indigo from Command Line (or .py files)
How do I pass command-line arguments to a Python script written for IndigoPluginHost? If I pass arguments to it, it says "multiple occurrences" (huh?).
How do I make a #! script for IndigoPluginHost?
What does the -f option do? It's in IndigoPluginHost's help message, but I can't find an explanation.
Cheers
-- perry
Sun Jul 07, 2013 1:43 pm
The plugin host that executes the python script doesn't currently accept additional (script) arguments.
shebangs cannot have spaces (escaping and quoting doesn't work), so you have to create a link to the IPH bundle:
sudo ln -s /Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app /usr/bin/indigohostapp
Then you can use a shebang like this:
#!/usr/bin/indigohostapp/Contents/MacOS/IndigoPluginHost -x
indigo.device.toggle(1221944241)
It is used internally by the Indigo Server when launching plugins, so should not be specified. It might someday be used to launch plugins on remote clients, but that isn't fully supported yet.
Mon Dec 23, 2013 3:54 pm
cec offline
I'm running Indigo 6.0.7 and want to work with Python to update Indigo variables. I followed the tutorial and put the alias in my .bashrc file, but when I try to either execute a .py script or just do the interactive test as shown on the website, I get immediately a 'connection closed' error followed by a 'received quit signal.'
here is a relevant screen trace (terminal on a Mac OS 10.8.5):
CeC$ cat .bashrc
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 5/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
CeC$ indigohost -i
2013-12-23 15:47:05.188 IndigoPluginHost[20689:707] connection to server was closed
2013-12-23 15:47:05.287 IndigoPluginHost[20689:707] Quiting Indigo Plugin - received quit signal
CeC$
I've looked at Indigo preferences and the start server screen but I don't see anything there that looks related to Python.
What am I doing wrong?
CeC
Mon Dec 23, 2013 7:23 pm
If you are running Indigo 6, then the alias should point to the Indigo 6 folder:
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
Note that line appends the alias to your .bashrc file, so you are probably going to need to open it in a text editor and delete the previous/old paths.
Does that fix the problem?
Mon Dec 23, 2013 10:30 pm
cec offline
Thanks Matt-
I was editing .bashrc but I also had a .bash_profile which had the alias to Indigo 5, thus changing .bashrc didn't fix things but changing .bash_profile did.
CeC
Wed Dec 25, 2013 10:00 am
nlagaros offline
How would I retrieve a plugin preference via the IndigoPluginHost command line?
Thu Dec 26, 2013 11:30 am
plugin = indigo.server.getPlugin("com.some.plugin.key.as.defined.in.its.plist")
prefVal = plugin.pluginPrefs["somePrefKey"]
return prefVal  # or maybe print(prefVal)
Thu Dec 26, 2013 11:41 am
nlagaros offline
I did try something similar. I think I'm missing something obvious so pardon my ignorance. Here is my result:
>>> sp = indigo.server.getPlugin("com.ssi.indigoplugin.Sonos")
>>> print sp
pluginDisplayName : Sonos
pluginId : com.ssi.indigoplugin.Sonos
pluginSupportURL : https://vulture.lagaros.com/wiki/projects/homeautomation/Home_Automation.html
pluginVersion : 0.6.9
>>> a = sp.pluginPrefs["rootZPIP"]
  File "<console>", line 1, in <module>
AttributeError: 'PluginInfo' object has no attribute 'pluginPrefs'
Thu Dec 26, 2013 11:49 am
Doh. You aren't missing anything. That plugin object returned from that lookup is just a thin shim that contains a few attributes (pluginId, pluginDisplayName, pluginVersion, isEnabled) and not the full instance. It will take some additional plumbing work on our end to expose the preferences dict.
If you really need access to the prefs, then you could read the file directly from:
/Library/Application Support/Perceptive Automation/Indigo 6/Preferences/Plugins/com.ssi.indigoplugin.Sonos
Thu Dec 26, 2013 11:56 am
nlagaros offline
Perfect - I can definitely go directly to the preferences file. Thanks.
Wed Jun 01, 2016 8:05 am
RedYuriPrime offline
I am trying to simplify, replacing an action group which starts a number of python code modules using the format 'execute linked script file 'Heating.py' etc. and initiating all these from a single python script, itself initiated by a trigger.
Reading this topic (and relying on the title of it), it seems to suggest using the format:
indigohost -x/path/pythonfile.py'
However I get the error that indigohost is not a known command.
I also tried using the route of importing the additional modules, but then modlues which otherwise run fine started throwing errors at the command 'return', which suggests they are not running in the correct environment
What command should I be using?
Z-wave system with 80+ devices, Indigo7 on a dedicated MacMini
Controlling lighting, heating, hotwater, security; but still a lot to learn ... :shock:
Wed Jun 01, 2016 9:17 am
If you're trying to do this from inside an Indigo trigger, that's the wrong thing to do. Any external round trip is going to be more complicated than just doing what you need to do in the trigger actions.
Why not just put those scripts in the action itself? Is there some reason they have to be external files? Or just put multiple actions on the trigger, each calling an external script like you're doing in the action group now?
Wed Jun 01, 2016 9:48 am
I agree with @FlyingDiver's questions - I think knowing a bit more about exactly what you're wanting to do may lead to a much simpler solution.
However, to answer your specific question, you need to provide the full path to the command that starts up the IndigoPluginHost process:
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -x /path/to/pythonfile.py
The command used in this thread assumes you've set up the alias as described in the Python Scripting Tutorial.
Wed Jun 01, 2016 11:31 am
Thanks for the immediate feedback - I haven't managed to try Jay's solution yet as TeamViewer is down across half the world, and my MAC runs headless. However, in response to the request for more info on the problem:
The problem:
On a reboot after a power failure, Indigo needs to resume all services. Services are provided by a series of python scripts (modules) that run in continuous loops - this makes managing variables somewhat easier than having to save and reload each time the modules are triggered by a schedule. There are several different modules because they provide very different functions -one runs heating, one runs security, etc. and it is easier to maintain them by separating the logical functions, which work on different timescales in any event.
Indigo can provides a trigger as it starts up, which I can use to trigger an initial python script to reset various indigo stored variables as required - I then want that same python script to start up the other python modules. At the moment I use the rather inelegant solution of having an Action Group with a series of actions each running the server action of running on of the python modules.
Hence, I am seeking the code to put in a python script which initiates another python script under exactly the same environment as it if was initiated by the server action in an Action Group.
Hope that clarifies.
