Paramiko and Indigo 2023.2
Tue Apr 23, 2024 9:46 am
https://www.paramiko.org says it works in python 3.11. But the following script gets
 Script Error                    trigger "Motion in the Garden" embedded script error:
   Script Error                    No module named 'paramiko'
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 7, at top level
ModuleNotFoundError: No module named 'paramiko'
I'm running pip 24.0 from /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/pip (python 3.10)
But Indigo uses 3.11? I think my confusion here is the root of the problem. There's a "Important Note" about running the pip3 install again in the download docs, but apparently I'm in the wrong place for that upgrade. Do I need to run the pip3 install somewhere besides the regular Mac OS command line?
Here's the script that throws the error.
from datetime import datetime
from pathlib import Path
from PIL import Image, ImageDraw, ImageFont
import matplotlib.pyplot as plt
import numpy as np
import time
import paramiko
image_path = Path(indigo.server.getInstallFolderPath()) / "Web Assets" / "public"
target_image = "redact.jpg"
time.sleep(0.5)
with Image.open(image_path / target_image) as original:
    draw = ImageDraw.Draw(original)
    font = ImageFont.truetype("Arial", 55)
    draw.text((55, 23), datetime.now().strftime("%a %d %I:%M %p " + target_image.split(".")[0]), (255, 70, 90), font=font)
    plt.subplot(1, 2, 1)
    plt.title("white text")
    # plt.imshow(original)
    original.save(image_path / target_image, optimize=True, quality=45)
    original.save(image_path / "alert.jpg", optimize=True, quality=45)
# create SSH client
ssh = paramiko.SSHClient()
# add server's key to the list of known hosts
ssh.set_missing_host_key_policy(paramiko.AutoAddPolicy())
# connect to the server using password authentication
ssh.connect(hostname='192.redact', username='redact', password='redact')
# open SFTP session
sftp = ssh.open_sftp()
# upload the file
sftp.put(image_path / target_image, '/redactedjpg')
sftp.put(image_path / target_image, '/redacted/redactede.jpg')
# close SFTP session
sftp.close()
# close SSH connection
ssh.close()
Tue Apr 23, 2024 9:48 am
Re: Paramiko and Indigo 2023.2
If you're using Indigo 2023.2, which uses Python 3.11. then you should not have Python 3.10 installed at all. Delete /Library/Frameworks/Python.framework/Versions/3.10 completely, then re-run the Indigo installer to make sure Python 3.11 is installed correctly.
Tue Apr 23, 2024 9:53 am
anything I need to know before taking a command line machete to that directory? Is there a safer, python based method of deleting 3.10?
Found a couple of guides online that said rm -fr /Library/Frameworks/Python.framework/Versions/x.x would work fine. Looks like I'm ok.
Tue Apr 23, 2024 10:09 am
So I did all that, and after I get
 Script Error                    trigger "Vehicle or a deer in the driveway" embedded script error:
So I ran pip3 install paramiko and now it's working. Thanks!
That was all a lot.
