How to install python modules in Indigo 7
Tue Nov 15, 2016 12:36 pm
lindehoff offline
Hi
For some reason python modules I install are not found within plugins after I upgraded to Indigo 7.
I know that Indigo 7 uses python 2.7 and I have reinstall the modules for 2.7.
I have tried multiple different ways and different modules, all with and without sudo:
pip install numpy
pip2.7 install numpy
sudo easy_install-2.7 pip numpy
I don't get any errors installing the modules and the are accessible within python:
python
Python 2.7.10 (default, Sep 23 2015, 04:34:14)
[GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.72)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy
Even if I run the Scripting Shell it works:
Python 2.7.10 (default, Jul 14 2015, 19:46:27)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
Connected to Indigo Server v7.0.1, api v2.0 (localhost:1176)
>>> import numpy
But when I try to start a plugin that uses that module I get:
   Hue Lights Error                Error in plugin execution InitializeMain:
  File "plugin.py", line 427, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Hue Lights-2.indigoPlugin/Contents/Server Plugin/colormath/color_objects.py", line 4, in <module>
ImportError: No module named numpy
   Stopping plugin "Hue Lights 1.4.4" (pid 461)
Tue Nov 15, 2016 8:15 pm
Re: How to install python modules in Indigo 7
During the beta of Indigo one of the plugin developers noticed on his Mac, somehow, he ended up with 2 different versions of Python 2.7: 2.7.10 and 2.7.12.
He would get 2.7.10 if he started python with just python:
$ python --version
Python 2.7.10
But would get 2.7.12 if started with python2.7:
$ python2.7 --version
Python 2.7.12
I wonder if that is what is happening here?
I am puzzled by the different results you see when trying to import the module from Indigo's plugin shell versus from the plugin. Under-the-hood those are started up exactly the same way.
Tue Nov 15, 2016 11:31 pm
srkinard offline
Maybe something in how the plugin calls other python scripts?
When I used SickRage they made some changes in certain modules that called python2 vs just python and my system didn't understand the python2 command.
The devs rolled back to previous behavior and changed the way it was called, but only after a lot of complaints...since it was cross-platform code that worked on the Mac with native 2.6 or 2.7 and failed on some Linux distros and Windows installs.
I have no idea if that's anything close to what's happening here, but based on Matt's post about the multiple versions, anything is possible.
Wed Nov 16, 2016 1:31 am
lindehoff offline
$ python --version
Python 2.7.10
Python 2.7.12
I saw that post but I don't have that problem:
$  python --version
Python 2.7.10
Python 2.7.10
I also tied to import in a simple script but it did not work:
Wed Nov 16, 2016 11:11 am
Look to see if numpy is in this directory:
/Library/Python/2.7/site-packages/
Wed Nov 16, 2016 11:24 am
lindehoff offline
No modules in the folder only a README file:
This directory exists so that 3rd party packages can be installed
here.  Read the source for site.py for more details.
Wed Nov 16, 2016 12:05 pm
I'm the one with the mystical python 2.7.12 that I believe either came along for the ride with a reinstall of XTOOLS or, upon further reflection, could have hitched a ride with Macports. I never asked to install 2.7.12 (I'm on El Capitan).
On my development environment, I did the following:
username$ python --version
Python 2.7.10
to ensure that my default Python was 2.7.10.
sudo pip install ipgetter
Launched a Python shell from within Indigo
Python 2.7.10 (default, Oct 23 2015, 19:19:21)
[GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.59.5)]
>>> import ipgetter
For the record, here's what happens if I do this:
username$ python2.7 --version
Python 2.7.12
Wed Nov 16, 2016 1:02 pm
Can you find where it got installed?
Wed Nov 16, 2016 1:32 pm
lindehoff offline
My module seems to be installed here
/usr/local/Cellar/python/2.7.10_2/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
I found that you can run
import site; site.getsitepackages()
to list the module dirs,
Here is my result in different environments
Terminal running python
$ python
['/usr/local/Cellar/python/2.7.10_2/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages', '/usr/local/Cellar/python/2.7.10_2/Frameworks/Python.framework/Versions/2.7/lib/site-python', '/Library/Python/2.7/site-packages']
Inside a script executed from Indigo
import site
indigo.server.log(str(site.getsitepackages()))
Result in Log:
16 Nov 2016, 20:28:22
Script                          ['/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/Library/Python/2.7/site-packages']
Indigos Scripting Shell
['/usr/local/bin/../Cellar/python/2.7.10_2/bin/../Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages', '/usr/local/bin/../Cellar/python/2.7.10_2/bin/../Frameworks/Python.framework/Versions/2.7/lib/site-python', '/Library/Python/2.7/site-packages']
Wed Nov 16, 2016 1:53 pm
That is because when launched from an interactive shell (terminal or Indigo's shell) it includes your .bash (or other) files that setup different folder paths.
I'd suggest you make a symbolic link from where it was installed into your /Library/Python/2.7/site-packages/ folder so Indigo can find it.
Wed Nov 16, 2016 1:55 pm
lindehoff offline
Yes I tried that and it worked perfectly. Thanks for all the help.
Wed Nov 16, 2016 3:03 pm
Did you/do you have Mac OS X server installed by any chance?
[EDIT] it looks like you (or perhaps something else) caused homebrew to install Python (the /Cellar/ in the path above gave it away). While we understand wanting to keep software current, we don't really recommend installing your own Python given how we have to interact with it. You may experience other odd issues that will be even harder to diagnose...
Sun May 23, 2021 11:11 am
Hackencrash offline
To answer the question: How to install python modules in Indigo 7
1. Open the Terminal app on your Mac running Indigo.
2. First, ensure Pip is installed by typing:
sudo /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python -m ensurepip --default-pip
3. Then, install your Python module(s) by typing:
sudo /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python -m pip install yourmodule
This will ensure the modules get correctly installed into:
