I'm running little snitch and I've pinged the following sites to trigger the approval / denial dialog for little snitch
Also running BitDefender and Malwarebytes
ping IndigoDomo.com
ping IndigoDomo.net
homeautomation-prete.indigodomo.net
homeautomation-prete.indigodomo.com
I've approved all network connections prompted by these pings.
I've restarted the app and the computer. Network connections have been tested. There is no proxy on this connection.
Stopped the local server, started the local server.
Two network interfaces are active ethernet and wi-fi via amplify router and a mesh network from the same.
Full log since reboot:
- Code: Select all
Aug 30, 2021 at 9:19:24 AM
Starting Indigo Server version 2021.1.1 on macOS Version 11.5.2 (Build 20G95)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Databases/GEN 7 Z-Wave Test Database.indiDb"
Loading disabled plugins
Found disabled interface "Virtual Devices 2021.1.0"
Found disabled plugin "Timers and Pesters 2021.1.0"
Found disabled plugin "Alexa 2021.1.1"
Found disabled plugin "Airfoil Pro 2021.1.0"
Found disabled plugin "NOAA Weather 2021.1.0"
Found disabled interface "INSTEON Commands 2021.1.0"
Found disabled plugin "EasyDAQ Relay Card 2021.1.1"
Found disabled plugin "iTunes 2021.1.0"
Loading internal plugins
Loading interface "Z-Wave 2021.1.1"
Starting interface "Z-Wave 2021.1.1" (pid 997)
Loading plugin "Web Server 2021.1.1"
Starting plugin "Web Server 2021.1.1" (pid 998)
Loading plugin "Action Collection 2021.1.0"
Starting plugin "Action Collection 2021.1.0" (pid 999)
Loading plugin "SQL Logger 2021.1.0"
Starting plugin "SQL Logger 2021.1.0" (pid 1000)
Loading plugin "Email+ 2021.1.1"
Starting plugin "Email+ 2021.1.1" (pid 1001)
Loading plugin "Global Property Manager 2021.1.0"
Starting plugin "Global Property Manager 2021.1.0" (pid 1002)
Started plugin "Global Property Manager 2021.1.0"
Started plugin "Email+ 2021.1.1"
Started plugin "SQL Logger 2021.1.0"
SQL Logger connected to /Library/Application Support/Perceptive Automation/Indigo 2021.1/Logs/indigo_history.sqlite
SQL Logger searching for unused variable tables
SQL Logger search complete (none found)
SQL Logger updating all device tables
SQL Logger updating all variable tables
SQL Logger update complete
Started plugin "Action Collection 2021.1.0"
Started plugin "Web Server 2021.1.1"
Web Server Starting Indigo Web Server...
Web Server client connected
Web Server started on port 8176 -- authentication enabled: oauth, digest
Bonjour registered "Indigo - GEN 7 Z-Wave Test Database"
Reflector starting reflector connection to https://homeautomation-prete.indigodomo.net
Started interface "Z-Wave 2021.1.1"
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 37 2E 31 31 00 07 97 (no inbound callback)
Z-Wave Debug . . getVersion: Z-Wave 7.11 bridge controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 E4 34 E8 0A 01 E5 (no inbound callback)
Z-Wave Debug . . getHomeID: E434E80A, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7 (no inbound callback)
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 07 00 00 00 00 04 00 04 F6 87 3E 88 CF 2B C0 4F FB D7 FD E0 07 00 00 80 00 80 86 80 BA 05 00 70 00 00 2E 00 00 00 00 00 A8 (no inbound callback)
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 05 06 07 08 09 0A 0B 10 12 13 14 15 16 1C 20 21 22 23 24 27 28 29 2A 2C 2E 37 38 39 3A 3B 3C 3F 41 42 44 45 46 47 48 49 4A 4B 4D 4F 50 51 53 54 55 56 57 58 5E 5F 60 61 62 63 80 90 92 93 98 A0 A2 A4 A5 A6 A8 A9 AB BD BE BF D2 D3 D4 D6
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 7.00, manufactureId 0000, productType 0004, productId 0004
Z-Wave Debug . . getInterfaceApiCapabilities: SDK6.60.00+ (expecting RSSI value and securityKeyType bytes)
Z-Wave Debug . . getInterfaceApiCapabilities: supportsGetClearNetworkStats
Z-Wave Debug . . getInterfaceApiCapabilities: supportsTransmissionMetrics
Z-Wave Debug SENT setApiSetup: 01 05 00 0B 02 01 F2
Z-Wave Debug RCVD setApiSetup: 01 05 01 0B 02 01 F3 (no inbound callback)
Z-Wave Debug . . setApiSetup: transmissionMetrics enabled
Z-Wave Debug . . getInterfaceApiCapabilities: supportsBackupRestore
Z-Wave Debug . . getInterfaceApiCapabilities: supportsS2
Z-Wave Debug . . getInterfaceApiCapabilities: supportsSmartStart
Z-Wave Debug . . getInterfaceApiCapabilities: SDK7.00.00+
Z-Wave connected to Z-Stick 7 (ZWA010) interface on /dev/cu.usbserial-14340 (firmware 7.00, minimum SDK 7.00.00)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 08 08 1D F1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 32 (no inbound callback)
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 5, 6, 7, 8]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 96 01 02 02 01 F3 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Notification Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave found module included in controller with no matching device (missing or disabled): 005 - Notification Sensor
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Notification Sensor
Waiting for internal plugins to initialize
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 0F 01 F2 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Basic Repeater Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Repeater Slave : Basic Repeater Slave (04 : 0F : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 03 01 FE (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: AV Control Point
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : AV Control Point : -- (04 : 03 : 01)
Z-Wave Debug overriding node 008 type from zwCustomType to zwSoundSwitchType
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Loading external plugins
Loading plugin "NOAA Weather Plus 1.1.19"
Starting plugin "NOAA Weather Plus 1.1.19" (pid 1023)
Loading plugin "utilities 1.18.32"
Starting plugin "utilities 1.18.32" (pid 1025)
Started plugin "NOAA Weather Plus 1.1.19"
Started plugin "utilities 1.18.32"
utilities no fname:/Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/Plugins/com.karlwachs.utilities/PLUGINSusedForCPUlimts.json
utilities testing if variable enableTimeTracking_utilities is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
utilities myLogSet setting parameters -- logFileActive= standard; logFile= ; debugLevel= []; maxFileSize= 5000000
utilities initialized
utilities Utilities plugin initialized, ==> select action from plugin menu
Waiting for external plugins to initialize
Starting triggers and schedules
Aug 30, 2021 at 9:20:38 AM
Error reflector connection not open
Warning reflector reconnection scheduled in 5 seconds
Reflector restarting reflector connection to https://homeautomation-prete.indigodomo.net
Aug 30, 2021 at 9:21:04 AM
Warning reflector reconnection scheduled in 2 minutes
Indigo Cocoa client connected
Aug 30, 2021 at 9:23:05 AM
Aug 30, 2021 at 9:23:25 AM
Warning reflector reconnection scheduled in 6 minutes
Aug 30, 2021 at 9:29:26 AM
Aug 30, 2021 at 9:29:47 AM
Warning reflector reconnection scheduled in 15 minutes
