Why Is It Some Triggers are just a problem
Sun Dec 13, 2020 7:54 pm
Sharek326 offline
So in General I have two separate triggers setup....
Trigger 1
When the Garage Door goes up at night turn go garage lights and turn on outside spot lights......Garage lights come on every time. Rear Spot is a constant problem.
Trigger 2
When back door opens at night turn or Rear spot lights......Spot lights come on every time with that trigger.....
So why is it one does with a device and the other is a problem?
Sun Dec 13, 2020 10:13 pm
Re: Why Is It Some Triggers are just a problem
What kind of devices are those? Maybe there's a collision if the commands are sent out too close together.
Mon Dec 14, 2020 12:21 am
Dual offline
I use a short delay between turning on each device. Might help.
Mon Dec 14, 2020 8:24 am
Sharek326 offline
Thanks guys I will try putting in a delay ....The devices are actually the same just a Basic Single Pole GE Wave Switch turning on both lights
Mon Dec 14, 2020 8:02 pm
Sharek326 offline
Adding a delay between the devices turning on didn't help....Garage light still comes on 100% and Outside spotlights won't
I did notice is I click the execute trigger it works correctly but if it actually executes when the door opens it doesn't
Tue Dec 15, 2020 8:02 am
What specifically does the Event Log show? Is there an error? Copy/paste both the working Trigger results and the Trigger that fails so we can see specifically what is being reported by Indigo.
