jens wrote:is it possible and controlling Kodi on a Razzberry whith Indigo?
// Jens
Probably.
just put the Addon in the appropriate folder.
posting.php?mode=quote&f=5&p=102148#pr92934
// Jens
tenallero wrote:Hi,
Apologies to be so late.
This link points to the documentation about my Roomba plugin:
https://www.dropbox.com/s/9ghepfwbxdaw0 ... plugin.pdf
Inside you will find the link to download the code and setup instructions.
Some notes about it:
English is not my language. So, apologies about any linguistic incorrection.
I have publish it as a PDF file, because I have not found the correct way to do it as a readable forum entry (mainly about including pictures from my desktop)
The code is open. I will find the way to publish it on github or similar.
This plugin is my first Indigo's plugin and my first lines of python code. I would like to thank to Dan Noguerol (https://bitbucket.org/whizzosoftware/in ... ddy-plugin), because his work around "irrigation caddy plugin" give me inspiration and confidence to start coding a python plugin for Indigo.
Also congratulate Matt and Jay with the well done work with Indigo. It has been a nice experience to develop an Indigo plugin and collaborate with Matt testing some Fibaro's zwave devices.
Stoffergoffer, you opened the thread. Next point will be about XBMC and PiFace plugin.
Regards,
Ramon
tenallero wrote:Durosity,
I hope the link works now.
https://www.dropbox.com/s/lq17ebqadts1a ... n.pdf?dl=0
https://www.dropbox.com/s/z73ntc1w35jn6 ... n.zip?dl=0
I am sorry, but I promissed to upload the plugins to github. But, I did not find the time.
If somebody is interesed, I have abandoned Roowifi in favor of http://www.thinkingcleaner.com/
I have developed an Indigo plugin por think cleaner
yassi wrote:Hi all,
can one please repost the KODI (modified) Add-On?
The Dropbox link isn't working, 404 error.
Thx,
yassi
Korey wrote:yassi wrote:Hi all,
Thx,
yassi
Try this:
https://www.dropbox.com/s/0hmf507qw9exc ... 9.zip?dl=0
tenallero wrote:Hi,
I am in process of "normalize" my plugins.
So, I am publishing them on github
https://github.com/tenallero?tab=repositories
The work is done for XBMC, Ping and ThinkingCleaner plugins
The work will follow for the rest of plugins.
Every plugin will have its on wiki
XBMC Plugin:
I am trying to gather the modifications that other user has done to adapt it to their own systems and requeriments.
Like using json library instead of simplejson, add-on main loop for older XBMC (Eden on AppleTV?)
Can you help me in this "gathering" task?
If you want to try the "new" plugin, please make a previous backup of your Indigo system.
XBMC devices must be deleted and recreated
I would like to know if the new documentation format (github wiki) is ok.
The plugin is now at:
https://github.com/tenallero/Indigo-XBMC
And its documentation at:
https://github.com/tenallero/Indigo-XBMC/wiki
Thanks to all
Ramon
Korey wrote:
Hi Ramon,
The new plugin works fine on Kodi 16.0
Documentation looks good as well.
Thank you!
