Make a facetime Call
Fri Mar 04, 2016 2:56 pm
artpics offline
i want to use the below code which i came across, so when my DSC alarm is triggered it makes a FaceTime call to me. everything seems to work but this line does not complete any help would make me happy. :D
thanks
just paste the code below into your script editor
-- simulate pressing the Enter key
tell application "System Events"
keystroke return
open location "facetime://12345678"
delay 5
    keystroke return
    -- Check to see if Facetime is active
    tell application "System Events" to set theCount to the count of (processes whose name is "Facetime")
    if theCount = 0 then
        do shell script "sleep 1"
    else
        tell application "FaceTime" to activate
        -- sets how long facetime will ring your phone (40 secs)
        do shell script "sleep 40"
        tell application "System Events" to tell process "FaceTime"
            if name of front window contains "with" then
                -- if call is active wait 60 seconds before rechecking
            else
                -- Check to see if call is still active
                    else
                        -- Quit Facetime if call is not active
                        if name of front window contains "facetime" then
                            tell application "FaceTime" to quit
                        end if
                    end if
                end tell
            end if
        end tell
    end if
end tell
Fri Mar 04, 2016 3:25 pm
peteinau offline
Re: Make a facetime Call
The return key won't actually connect the FaceTime call, you need the following code:
repeat while not (button "Call" of window 1 of application process "FaceTime" exists)
delay 1
end repeat
click button "Call" of window 1 of application process "FaceTime"
end tell
Which will click the actual call button. You will need to make sure that you have Accessibility turned on for the app you are running it from tho otherwise it will still fail.
Fri Mar 04, 2016 6:54 pm
artpics offline
thanks it rings :shock: will do some more testing later
Sat Mar 05, 2016 2:36 pm
artpics offline
EDIT:
for mac minis no camera you have to change the first line to this.
open location "facetime-audio://" & "change to your phone number" & "?audio=yes"
:D
Thu Jun 29, 2017 12:01 am
MarcoGT offline
delay 1
end repeat
end tell
I am trying to bring it inside Indigo, but I do not understand where this part of code goes into.
Into which "tell application "System Events" shall it go?
Would it be possible to have the complete code?
Marco
