Collecting CPU temperature of the host running Indigo server
Sat Apr 19, 2014 9:10 am
AndersKn offline
I thought I could share how I gather information about the host that is running the Indigo server, since I could not find any previous examples in the Indigo forums.
Disclaimer: I am not a software engineer, so my code WILL LOOK UGLY. If You don´t like it please feel free to improve! :-)
My situation is that the computer is located in a closet where the temperature may exceed the operating limit of the MacBookPro currently running the software.
Thus I thought it would be wise to monitor the CPU temperature.
To gather the sensor values from a unix prompt the choice fell upon a small utility called "Temperature Monitor" found at http://www.bresink.com/osx/TemperatureMonitor.html.
(This was the only software I found that can be used from command-line.)
From this I created a small AppleScript to collect the data and get it into Indigo. ( I have enclosed it in this post).
I´m interested to learn if others have had similar problems and if so how You solved it.
Best regards
Anders K.
property return_f : false
try
   set the_result to (do shell script "/Applications/TemperatureMonitor.app/Contents/MacOS/tempmonitor -tv")
on error
   return "unknown"
end try
set alla_display to ""
# set thesensor to items 1 thru ((count of characters of the_result) - 5) of the_result
set thetemp1 to items 29 thru 30 of the_result
set thetemp2 to items 32 thru 33 of the_result
set thetemp1U to thetemp1 as Unicode text
set thetemp2U to thetemp2 as Unicode text
   -- This checks to see if a variable named "MyVar" exists, and creates it if it doesn't
   if not (variable "CPUtemp1" exists) then
      make new variable with properties {name:"CPUtemp1", value:"Value"}
   end if
   -- This line sets it
   set (value of variable "CPUtemp1") to thetemp1U
   if not (variable "CPUtemp2" exists) then
      make new variable with properties {name:"CPUtemp2", value:"Value"}
   end if
   set (value of variable "CPUtemp2") to thetemp2U
end tell
Sat Apr 19, 2014 9:47 am
gregjsmith offline
Re: Collecting CPU temperature of the host running Indigo se
I implemented your solution. Works great.
Sat Apr 19, 2014 10:47 am
BassMint offline
I recently set up hwmonitor to keep track of all the macs on the network.
I too am a novice as you, so the same things apply. The gurus are in vied to critique.
I tried it with AppleScript but found it to be better using Python grabbing from multiple hosts.
#!/usr/bin/python
#  stinky hwmonitor
import subprocess
# get data from hwmonitor
stinkyRawValues =subprocess.Popen('ssh bassmint@stinky.local & /sbin/hwmonitor -f -tv', shell=True, stdout=subprocess.PIPE, )
stinkyValues= stinkyRawValues.communicate()[0]
# split into list
stinkyValues = stinkyValues.split(",")
indigo.variable.updateValue(209304751,stinkyValues[0]) # DATE_AND_TIME
indigo.variable.updateValue(461413176,stinkyValues[1]) # CPU_Core_1
indigo.variable.updateValue(1111349866,stinkyValues[2]) # CPU_Core_2
indigo.variable.updateValue(1606312189,stinkyValues[3]) # CPU_A_DIODE
indigo.variable.updateValue(760454415,stinkyValues[4]) # GPU_1_CHIP
indigo.variable.updateValue(415445737,stinkyValues[5]) # GPU_1_HEAT_SINK
indigo.variable.updateValue(203993904,stinkyValues[6]) # MAIN_HEAT_SINK_1
indigo.variable.updateValue(986309664,stinkyValues[7]) # MAIN_HEAT_SINK_2
indigo.variable.updateValue(1179140198,stinkyValues[8]) # MEMORY_CONTROLLER
indigo.variable.updateValue(749927948,stinkyValues[9]) # MEMORY_SENSOR_1
indigo.variable.updateValue(996721786,stinkyValues[10]) # CPU_A1
indigo.variable.updateValue(705416417,stinkyValues[11]) # GPU_SUPPLY_1A
indigo.variable.updateValue(360272147,stinkyValues[12]) # POWER_SUPPLY_BATTERY_1
indigo.variable.updateValue(1887879561,stinkyValues[13]) # CPU_A2
indigo.variable.updateValue(631155128,stinkyValues[14]) # GPU_SUPPLY_1B
indigo.variable.updateValue(1007332997,stinkyValues[15]) # POWER_SUPPLY_BATTERY_2
indigo.variable.updateValue(156029000,stinkyValues[17]) # CPU_A3
indigo.variable.updateValue(1782911323,stinkyValues[18]) # GPU_SUPPLY_1C
indigo.variable.updateValue(886599771,stinkyValues[19]) # POWER_SUPPLY_BATTERY_3
#indigo.variable.updateValue(1568895371,stinkyValues[20]) # FAN_Left_side
#indigo.variable.updateValue(1403505489,stinkyValues[21]) # FAN_Right_side
#indigo.variable.updateValue(582037091,stinkyValues[22]) # AMBIENT_LIGHT_1
#indigo.variable.updateValue(1917550312,stinkyValues[23]) # AMBIENT_LIGHT_2
#indigo.variable.updateValue(1375742121,stinkyValues[24]) # GPU
#indigo.variable.updateValue(134427035,stinkyValues[25]) # CPU_Clock_Frequency
indigo.server.log("HWM Got Stinky Data")
Not knowing exactly what Im doing, the above taps out after the first 20. Thats why they are commented out. I haven't dug any deeper into it recently as it got put on the back burner to figure out later.
Wed Dec 28, 2016 7:17 pm
mclass offline
Like previous posters to this thread, I have located my Mac Mini running Inigo 7 on OSX 10.10.5 (Yosemite) in a comms locker.
During yesterday's heat (I'm in the southern hemisphere!) the temperature in the locker exceeded 30 degC, so I intend to install a fan that will operate when the temperature exceeds a certain level. Rather than install a separate temperature sensor, I thought it would be a good idea for Indigo to monitor CPU temperature and operate the fan as required.
However, the command line utility used in these examples is no longer available, and I have identified a Ruby gem - iStats [url](http://chris911.github.io/iStats)[/url].
As I have no experience with Ruby, I followed the provided install instructions with the following result:
Indigo-Sandpit:~ sandpitserver$ sudo gem install iStats
Password:
Fetching: sparkr-0.4.1.gem (100%)
Successfully installed sparkr-0.4.1
Fetching: parseconfig-1.0.8.gem (100%)
Successfully installed parseconfig-1.0.8
Fetching: iStats-1.4.0.gem (100%)
Building native extensions.  This could take a while...
ERROR:  Error installing iStats:
   ERROR: Failed to build gem native extension.
    /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/bin/ruby extconf.rb
mkmf.rb can't find header files for ruby at /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/include/ruby.h
Gem files will remain installed in /Library/Ruby/Gems/2.0.0/gems/iStats-1.4.0 for inspection.
Results logged to /Library/Ruby/Gems/2.0.0/gems/iStats-1.4.0/ext/osx_stats/gem_make.out
As instructed in the installation instructions "for older versions of OSX" I tried:
Indigo-Sandpit:~ sandpitserver$ sudo ARCHFLAGS=-Wno-error=unused-command-line-argument-hard-error-in-future gem install iStats
Are there any Ruby "practitioners" out there that can assist?
Alternatively, are there better ideas for controlling cupboard ventilation (other than an additional temperature sensor)?
mclass
Users browsing this forum: No registered users and 20 guests
