Wrong brightness when recalling a scene
Thu Sep 08, 2022 2:18 am
MarcoGT offline
I am recalling a preset scene, as brightness I set "5", but the lights are set at 56, I do not see any error in the logs.
Marco
Thu Sep 08, 2022 4:38 am
Re: Wrong brightness when recalling a scene
Marco,
I just tested a scene I have set on an iPhone.
1. created an action to recall that scene, saved
2. changed the light randomly
3. executed that scene
that worked fine.
Could you be more specific on how you have set it up/ what does the scene do
with debug setting "send commands to bridge" (5) in config
you can see what is end to the bridge:
eg for me that was in file: /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.nathansheldon.indigoplugin.HueLights/plugin.log :
2022-09-08 12:34:13 Sending URL request: http://192.168.1.204/api/VnooFGU-qdotmcLso8FIVCqfSsXLtyo2rFaFAJ1B/sensors
2022-09-08 12:34:13 Sending URL request: http://192.168.1.201/api/fWoFVL8fnJDkxnpyWMulIz8oKeT4rClbuv0p4esM/sensors
2022-09-08 12:34:14 Starting recallScene. action values:
com.nathansheldon.indigoplugin.HueLights : (dict)
     confirmHubNumberText : first select hue bridge and click confirm (string)
     description : recall hue scene Soho from Hue app on iPhone for the Office hue group (string)
     groupId : 1 (string)
     hubNumber : 2 (string)
     sceneId : IA-oKlrHOQRSRoc (string)
     sceneLights : (list)
     sceneLightsDisabler : false (bool)
     userId : all (string)
Device/Type ID:
None
2022-09-08 12:34:14 Starting doScene. groupId: 1, sceneId: IA-oKlrHOQRSRoc.
2022-09-08 12:34:14 Sending URL request: http://192.168.1.201/api/fWoFVL8fnJDkxnpyWMulIz8oKeT4rClbuv0p4esM/groups/1/action
2022-09-08 12:34:14 "Soho" scene from "Hue app on iPhone" recalled for "Office"
2022-09-08 12:34:14 Starting update sensors List.
with a lot of sensor update messages
could you be so kind and post that output ?
you can switch the debug off after you have executed that scene one.
Thu Sep 08, 2022 4:44 am
MarcoGT offline
This is what I have (see image)
Logs:
8. Sep 2022 at 12:42:49
   Hue Lights                      debug areas:['SendCommandsToBridge']
   Action Group                    Scala Notte OG
   Hue Lights                      Sent Hue Lights  "Scala 10"  to 56 using color temperature  2132K.  at ramp rate  0.5 sec.
   Hue Lights                      updateDeviceState: Updating device "Scala 10" state: "brightnessLevel". Old value = 0. New value = 56
   Hue Lights                      updateDeviceState: Updating device "Scala 10" state: "colorTemp". Old value = 2114. New value = 2132
But I do not see the debug logs as you (I checked the "log 5"
Screenshot 2022-09-08 alle 12.41.55.png (116.46 KiB) Viewed 1687 times
Thu Sep 08, 2022 11:47 pm
i can reproduce the error, thank you,
will check in the next days.
Fri Sep 09, 2022 3:18 am
That is actually not an error
The scene you selected defines these values
Brightness and color temp
Any selection for those 2 gets ignored.
Fri Sep 09, 2022 4:07 am
That’s actually what scenes are. They set these values. Brightness, rgb, Color temp, …
So the selection menu is wrong.
When you select a scene any other value is ignored.
Changing that is not trivial. The current method used is a very simple indigo short cut of doing it. There can not be any „if“ during selection only at execution time
Fri Sep 09, 2022 5:54 am
MarcoGT offline
Karl, thanks a lot.
It means, the brightness value shall be set inside the scene, not in Indigo, am I right?
Fri Sep 09, 2022 6:27 am
No. In the current version the plugin set the values to the fixed value.
It is just a name for brightness 56 and colortemp= xx
Fri Sep 09, 2022 7:02 am
here the hard wired scenes:
         # Configure presets
         if preset == "concentrate":
            brightness = 219
            temperature = 4292
         elif preset == "relax":
            brightness = 144
            temperature = 2132
         elif preset == "energize":
            brightness = 203
            temperature = 6410
         elif preset == "reading":
            brightness = 240
            temperature = 2890
for relax mod it is set to 144 /255*100 = 56.4705 = 56
ps
the levels are converted between scales 0-100 and 0-255 (indigo <-> hue <-> % )
