Shelly Duo GU10
Mon Jan 24, 2022 7:31 am
MarcoGT offline
Shelly Duo GU10
I bought one of this (arriving tomorrow, 25.01):
https://www.amazon.de/dp/B09DL5FMT7/ref ... 91_TE_item
Will it work with the plugin?
Marco
Mon Jan 24, 2022 3:41 pm
aaronlionsheep offline
Re: Shelly Duo GU10
Marco
I'm not aware of anyone using that device specifically, but it should be identical to the Shelly Bulb RGBW (which is supported by the plugin). You will want to use that device type when adding it in Indigo.
Let us know what you find when it arrives!
Tue Jan 25, 2022 12:56 pm
MarcoGT offline
Re: Shelly Duo GU10
Unfortunately it does not fit in my LED spot, therefore no chance to test it.
But I assume it will work as it is a "Duo", like the standard one, just the socket is different.
