Error since 2023.2 update [Fixed was File Permissions]
Thu Jan 25, 2024 4:17 pm
racarter offline
I'm getting this error every few minutes since upgrading to Indigo 2023.2. Any ideas gratefully received. :)
iMessage Plugin Error           Error in plugin execution runConcurrentThread:
 File "plugin.py", line 371, in runConcurrentThread
 File "plugin.py", line 461, in sql_fetchmessages
type: 'Plugin' object has no attribute 'connection'
iMessage Plugin Error           plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thu Jan 25, 2024 4:19 pm
GlennNZ offline
Re: Error since 2023.2 update
I am not having a good update cycle here….
Can you post a debug log? And would check your buddy handles are correct? Did add some extra logging here as per github issue and possible something is up with that - should only happen when buddy handle fails though.
Edit:
Suggests that the sql connection to iMsg database has never been connected.
There should be messaging well before this.
2nd Thought:
It may relate to the File permissions - Indigo 2023.2 is a new version and new Files - so you may need to update security permissions.
This screen here the IndigoPluginHost and the IndigoServer need to be updated to the new 2023.2 Indigo files versions.
Indigo client not needed so do not need to update the Indigo 7.4 app here to Indigo 2023.2 app
Thu Jan 25, 2024 5:49 pm
GlennNZ offline
Pending the above, have released new version
0.7.27
Stops plugin if connection issue
Hardens up the runConcurrent thread somewhat
And changes messaging if there is some other reason that the sql connection has failed.
Thu Jan 25, 2024 7:23 pm
whmoorejr offline
Permissions? I did have a pop up with a permission that was blocked.... Oracle developer maybe? Don't remember... I approved it anyway. Since I was in the middle of updating indigo and about 12 plugins, I figured it had something to do with that and not russian spies. But.... I did not have any errors with your initial imessage update. (0.7.26) Just an FYI.
Bill
My Plugin: My People
Thu Jan 25, 2024 8:35 pm
GlennNZ offline
Jumping to this thread.
Thanks again - you may still need to enable Full Disk Access in the Security settings -- although given you are back on High Sierra that is perhaps why hasn't been an issue for you given the change in security that occurs with the later versions.
Regardless - as general rule would suggest Full Disk Access is granted as per these old photos. Even more important on newer versions of OSX
Glenn
Thu Jan 25, 2024 8:43 pm
whmoorejr offline
I suppose so, the last time I gave permissions to Indigo :roll: .....
Screenshot 2024-01-25 at 8.39.15 PM.png (47.47 KiB) Viewed 945 times
Bill
Thu Jan 25, 2024 8:53 pm
GlennNZ offline
Also need to put the IndigoServer.App and IndigoPluginHost.app in there....
Thu Jan 25, 2024 9:06 pm
whmoorejr offline
Done.
Questions:
On a newer mac, adjusting permissions is something that needs to be done everytime you upgrade Indigo? Or does that happen with pop-ups when during the install process?
My "IndigoPluginHost.app" is "IndigoPluginHost3.app" It looks like it switched in release 2022.1 where I have both host and host3. in 2021.2 I just have the host version. In 2023.1 Host went away and just Host3 from then on.
Bill
Thu Jan 25, 2024 9:19 pm
GlennNZ offline
whmoorejr wrote:
Done.
Questions:
Potentially with every Indigo upgrade - depends on how major version upgrade it is and whether file naming changes or not. The pop-ups can work - but don’t seem to do so always in my experience.
IndigoPluginHost3 is now the only one as earlier one was for python2 - hence for a short period was both IndigoPluginHost and IndigoPluginHost3.
Fri Jan 26, 2024 12:16 am
racarter offline
Thanks Glenn - it was the darn file permissions!
Fri Jan 26, 2024 12:19 am
GlennNZ offline
Great. Another one to cross of the list!
Still a bit odd to be that late - but may have had the error messages at the beginning and with server startup a lot of messaging so easy to miss
The new version stops plugin if same error
And if error occurs later will retry then re error message and stop
Hopefully making more noticeable !
Fri Jan 26, 2024 12:25 am
racarter offline
Sounds good. I checked the event log and couldn't find any error message when the plugin started; same when I restarted it - but the message in the plugin log was clear (if I'd thought to look). :roll:
Mon Apr 15, 2024 9:41 am
mgolden50 offline
Re: Error since 2023.2 update [Fixed was File Permissions]
Hi Glenn,
I'm suddenly getting this error message even though I updated sometime ago.
iMessage Plugin Debug An exception was caught with this applescript string
set sendThis to " Watering Session Complete"
tell application "Messages"
set myid to get id of first account
set theBuddy to participant "9283010136" of account id myid
send sendThis to theBuddy
end tell
File "plugin.py", line 598, in as_sendmessage
reply = my_ascript_from_string.run()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/applescript/__init__.py", line 90, in run
return self._unpackresult(*self._script.executeAndReturnError_(None))
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/applescript/__init__.py", line 65, in _unpackresult
raise ScriptError(errorinfo)
applescript.ScriptError: Not authorized to send Apple events to Messages. (-1743) app='Messages' range=153-155
iMessage Plugin Error An Error occurred sending this message: Error: Not authorized to send Apple events to Messages. (-1743) app='Messages' range=153-155
