Bond Home Plugin
Sun May 05, 2024 11:06 am
Re: Bond Home Plugin
Nah. I think it's an error caused by a plugin update somewhere along the line. First, just try editing and saving the Indigo device and see if that sets the property correctly. If not, try re-creating the device.
Sun May 05, 2024 11:21 am
t-star offline
looks like recreating them is the only way.
Before:
   Script                          address : 53913e1e
batteryLevel : None
buttonGroupCount : 0
configured : True
description : First floor office fan (53913e1e)
deviceTypeId : bondDevice
displayStateId :
displayStateImageSel : NoImage
displayStateValRaw : None
displayStateValUi :
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 445826354
     com.flyingdiver.indigoplugin.bondhome : (dict)
          address : 53913e1e (string)
          bond_type : CF (string)
          bridge : ZZDF76026 (string)
          off_command : TurnOff (string)
          on_command : TurnOn (string)
lastChanged : 2021-01-12 15:39:39
lastSuccessfulComm : 2021-01-12 15:39:39
model : Bond Generic Device
ownerProps : com.flyingdiver.indigoplugin.bondhome : (dict)
pluginId : com.flyingdiver.indigoplugin.bondhome
protocol : Plugin
remoteDisplay : False
states : States : (dict)
subModel : Ceiling Fan
subType : Ceiling Fan
supportsAllOff : False
supportsOnState : False
supportsStatusRequest : False
version : None
After
batteryLevel : None
buttonConfiguredCount : 0
configured : True
description :
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
errorState :
          off_parameter :  (string)
          on_parameter :  (string)
lastChanged : 2000-01-01 00:00:00
lastSuccessfulComm : 2000-01-01 00:00:00
ledStates : []
model : Bond Device
name : Office Fan 2
onState : False
protocol : Plugin
remoteDisplay : True
supportsOnState : True
version : None
Sun May 05, 2024 11:22 am
Yeah, I probably need to fix that. If I can.
Sun May 05, 2024 11:39 am
t-star offline
I will tell you one other thing that I think mattered. I had the on command configured to just turn on in the configuration. it wasn't until I changed the on to set speed and added a variable that it really made a difference and the icon next to the device started updating. that may be a hold over from just getting them set up in the early learning stages on my part.
I am glad that I didn't have to really recreate all my triggers. that would have been a royal pain.
Sun May 05, 2024 11:47 am
t-star offline
ok since I am in this, any thoughts on:
device "Bond Bridge" state key brightnessLevel not defined (ignoring update request)
Sun May 05, 2024 11:49 am
Similar issue. The older (nonPro) bridges have a brightness control for the blue light. The new Pro bridges (or any Smart by Bond device) do not. It's a mess.
Sun May 05, 2024 11:51 am
t-star offline
ok I have the older one with the control (which I love and have it off). I'll leave that one alone. it only shows when the plugin starts up.
Thanks for the help today.
Sun May 05, 2024 11:53 am
If you would, create issues in GitHub for both those issues so that next time I'm in the code for that plugin I'll remember to try to fix those.
