Error on startup/reload
Fri Feb 23, 2018 10:59 am
Juggler offline
Running the latest version of Indigo and your plugin. I recently had to reboot my Mac and happened to check the Indigo logs. It seems your plugin is now casting several errors.
Is anyone else seeing this? Is there a problem with python?
   Started plugin "LIFX Bridge 7.0.3"
   LIFX Bridge                     Starting LIFX Bridge
   LIFX Bridge Debug               updateFrequency = 86400.0
   LIFX Bridge Debug               refreshDeviceList called
   LIFX Bridge Debug               found published device: 182XXXXX68 - office desk () - XX:XX:XX:XX:XX:XX
   LIFX Bridge Debug               1 devices published
   LIFX Bridge                     Checking for updates...
   LIFX Bridge Debug               Plugin version detected: 7.0.3
   LIFX Bridge Debug               Current version is: 7.0.3
   LIFX Bridge Debug               Getting latest release from FlyingDiver/Indigo-lifx-bridge...
   LIFX Bridge Debug               GET /repos/FlyingDiver/Indigo-lifx-bridge/releases/latest
   LIFX Bridge Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 90, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFXBridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFXBridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFXBridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFXBridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFXBridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
   LIFX Bridge Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Feb 23, 2018 11:04 am
Re: Error on startup/reload
Fri Feb 23, 2018 12:12 pm
Juggler offline
Thanks! Will you be updating with the new plugin in the near future?
Fri Feb 23, 2018 12:14 pm
Probably. I haven't decided what route to go on the permanent fix yet.
