Current location error with Indigo ...
Fri May 22, 2020 6:09 am
rlesperance offline
Hello,
Do you have any idea why the automatic current location in Indigo is erroneous. In OS X,s System Preferences, my location is Montréal,Québec at 45,7N - 73,2W while Indigo's automatic set returns 49,15N - 123,8W. Yesterday a scheduled event was executed at a strange time and made me realize this problem. It's the first time I am aware of that.
Do you have an idea what can be the cause ?
Regards.
Automatic currecnt location.jpg (56.99 KiB) Viewed 1901 times
Fri May 22, 2020 7:18 am
Re: Current location error with Indigo ...
I believe the macOS API, in more recent macOS versions, that Indigo is using either no longer works or isn't allowing Indigo permission to call it. Its been on my list to investigate but not a high priority since there is the simple workaround of selecting the Override system location checkbox and manually entering the longitude and latitude.
Fri May 22, 2020 7:30 am
rlesperance offline
Thanks.
