Error installing plugin
Mon Feb 19, 2024 10:32 am
tsoulen offline
I am installing Indigo 2023.2 and Lutron Leap on Sonoma 14.1.2. I am getting an error message that I failed to create a reflector. I have gone to my licenses page but do not have a button to create a reflector. When I try to install the newest Lutron Leap plugin, I click Install and Enable, and nothing happens.
[MODERATOR NOTE]: this specific issue was resolved by resetting the reflector's activation.
Mon Feb 19, 2024 1:27 pm
tsoulen offline
Re: Error installing Indigo 7.4 on 10.15 Catalina
That worked to reset my reflector. Now when I try to install the new Lutron Leap, this is what the log says.
Installing and enabling plugin Lutron Leap v2023.2.0
   Error                           ReloadPlugin() caught exception: FileIOError -- rename/move of file or folder failed -- check file/folder permissions
   Reloading plugin "Web Server 2023.2.0" using API v3.3
   Stopping plugin "Web Server 2023.2.0" (pid 1530)
   Reflector                       shutdown reflector connection
   Stopped plugin "Web Server 2023.2.0"
   Starting plugin "Web Server 2023.2.0" (pid 1546)
   Started plugin "Web Server 2023.2.0"
   Web Server                      starting internal Web server on http://localhost:8176
   Bonjour registered "Indigo - My House ((v2022.2.2)"
   Reflector                       starting reflector connection to https://soulenreflector.indigodomo.net
Mon Feb 19, 2024 1:56 pm
Re: Error installing plugin
[MODERATOR NOTE]: Split this into a separate thread.
Rerun the Indigo 2023.2.0 installer and manually remove any existing Lutron Leap plugins, then try installing again.
Mon Feb 19, 2024 2:08 pm
tsoulen offline
Where would I find remaining Lutron Leap Plugins? I tried finding them through my finder and found none.
Mon Feb 19, 2024 2:34 pm
Either the plugins or the plugins (disabled) folders.
Also, delete the plugin from your downloads folder (or wherever it was when you attempted the install). Then re-download it.
Mon Feb 19, 2024 2:55 pm
tsoulen offline
Have done that twice. Same message.
Mon Feb 19, 2024 3:09 pm
Re-run the Indigo installer to fix any permissions issues. Then make sure you're downloading the new plugin as the same user that installed Indigo.
Mon Feb 19, 2024 3:10 pm
tsoulen offline
Restarted. Worked this time. Thanks for your help.
