Kwickset Zwave Lock error
Fri Mar 01, 2019 10:43 pm
roquej offline
Re: Kwickset Zwave Lock error
Matt,
Yes, it was working before, but I was getting random encryptions errors, which is why I when ahead and removed it. This is what I have done:
changed to another USB port - same error
use a USB hub and without - same error
rebooted the indigo machine - same error
I am going to buy another lock and see if that is the case. However, if I use the same lock hardware and the same UZB1 and it works in a raspberry pi with z-way, then the only thing left is something with my mac-mini or indigo.
Although I have two other locks working, another Kwikset and a Yale, is there a way to reset the encryption vault? Could that be corrupted and the original cause of the problem?
JP
Fri Mar 01, 2019 10:51 pm
roquej offline
Actually, just checked my other two locks, and when trying to re-sync, getting the same error for both:
Another Kwikset
Z-Wave Error encrypted command received from node ID 116 has invalid CBC-MAC value (ignoring)
Yale
Z-Wave Error encrypted command received from node ID 118 has invalid CBC-MAC value (ignoring)
I will venture to say, something got corrupted in myIndigo as all the locks were working before.
JP
Sat Mar 02, 2019 12:35 am
What is the firmware version of your UZB1 controller, and have you ever upgraded it?
Sat Mar 02, 2019 7:12 am
roquej offline
Current versions:
SDK Version: 6.71.01
Serial API Version: 05.27
Yes, I have upgraded it
JP
Sat Mar 02, 2019 12:06 pm
Did you last firmware upgrade coincide with the lock(s) starting to throw errors? I wonder if it's a bad firmware flash to your uzb...
Sat Mar 02, 2019 12:22 pm
Is that the firmware version for the UZB1 (not the lock)? It seems too high to be the UZB. I think you may be experiencing the same problem mentioned here.
Update: Looks like you are on firmware version 5.27. If you revert back to 5.07 (as mentioned on the other thread) I believe it will work. I don't know what UZB changed in the firmware that is causing the failures with Indigo. We'll investigate it, but at this time reverting the firmware should get it working.
Mon Mar 04, 2019 6:06 pm
roquej offline
Matt - traveling until Wed. When I get back, will downgrade and provide feedback.
Thank you for the prompt help!
JP
Tue Mar 05, 2019 4:40 pm
roquej offline
Matt,
I downgraded the firmware of the UZB1 to version 5.07. All is back working. Validated all devices and everything is working fine.
Included the lock with encryption. No errors, no issues:
Z-Wave controller included module: 061 - Keypad Door Lock
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
However, when I try to do the sync, it just doesn't work.
Z-Wave Syncing - started for "061 - Keypad Door Lock"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 17, 20, 22, 25, 27, 29, 31, 32, 34, 35, 36, 37, 38, 40, 41, 44, 45, 47, 50, 51, 52, 53, 54, 56, 59, 60, 65, 66, 67, 68, 69, 71, 72, 73, 74, 75, 76, 77, 78, 79, 82, 84, 85, 89, 94, 104, 121, 123, 124, 155, 157
Z-Wave Syncing - assigning return route to "061 - Keypad Door Lock"
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "061 - Keypad Door Lock". Module might be asleep, or is unreachable.
The lock is within 24" of the UBZ1
Suggestions?
JP
Tue Mar 05, 2019 8:15 pm
roquej offline
Matt - look a bit further, I realized that node 90, in the list of nodes doesn't exist.
Could that be the issue?
JP
Tue Mar 05, 2019 9:31 pm
roquej offline
Matt - Solved! Bad UZB1. Luckily, I had a spare UZB1 and a full backup. Downgraded it to 5.07, did a full restore, and ready to go.
Thank you for the suggestions. Looking forward to full support for the latest firmware (5.36)
JP
Mon Oct 28, 2019 3:39 pm
shapa offline
Matt, by any chance - finally to support newer FW? :)
I'll be happy to sponsor a dev environment - can actually either send the UZB to you (you can change z-wave frequency to any supported region) or enable remote access to my lab in the UK (mac mini +spare UZB).
Quite a few improvements in the latest FW, but anything higher than 5.07 is not working properly with Indigo :(
https://z-wave.me/support/uzbrazberry-firmwares/
5.37: Updated SDK to 6.81.01. Smart Start support. Fixed blink on sending. Reporting of incoming routes added in Z-Way Route Map.
5.32: Updated SDK to 6.81. Support of Z-Wave «SmartStart».
5.27: Added Bridge version and RF test mode.
To run the RF test mode mode do: sudo /etc/init.d/z-way-server stop && sudo apt-get install git && cd /tmp && rm -Rf uSAPI && git clone https://github.com/Z-Wave-Me/uSAPI && cd uSAPI && make && ./uSAPI -b "F7 01" -p /dev/ttyAMA0 -r 1 && ./uSAPI -b "08" -p /dev/ttyAMA0
5.27: Added radio jam detection feature.
5.26: Added forgotten new IMA functions.
5.25: Minor fixes.
5.23: Updated SDK to 6.71.01.
5.22: Frequency not resetted to EU anymore on upgrade.
5.16: Updated SDK to 6.70.00.
5.07: Updated SDK to 6.51.09 (for certification)
5.06: LED can be turned off:
Change it via IP:8083/JS/Run/zway.NVMExtWriteLongBuffer(0x6510,[XX]), where XX is:
0x00 LED used only for memory test when device powers up. Silent mode.
0x01 LED used during memory test and to indicate inclusion/exclusion mode.
0x03 LED used during memory test, to indicate inclusion/exclusion mode and it blinks when data is sending.
5.05: Fixed Bootloader upgrade response.
5.04: LED not turning off after some operations fixed.
Offset of User NVM made static.
5.03: Fixed bug with wrong UID returned after license apply.
p.s. it is a Russian company so I can actually try to talk with them natively in case of any questions.
Mon Oct 28, 2019 4:12 pm
I just posted on the other thread, but I do have a UZB with 5.27. It definitely has some differences that cause Indigo confusion. Haven't looked at the encryption/lock issue yet, but I will.
Mon Oct 28, 2019 5:19 pm
shapa offline
You can easily upgrade to the latest FW
Actually, I'm using VMware Fusion (Debian Linux in a VM) to connect UZB on the same mac Indigo server to make backups via razberry - works fine. They've got X86 build.
FW upgrade (and downgrade) could be done easily.
https://storage.z-wave.me/z-way-server/
Fri Feb 07, 2020 2:08 pm
Indigo 7.4.1 is now available and includes support for the USB Stick (ZME UZB1).
Fri Feb 07, 2020 8:42 pm
roquej offline
awsome. thank you!
JP
