Zigbee2mqtt Installation Help
Sun Mar 05, 2023 8:27 am
Please post requests for help and questions about the installation of Zigbee2mqtt in this thread where knowledgeable forum users can offer help and guidance. :)
Sun May 07, 2023 2:11 am
LSpad offline
Re: Zigbee2mqtt Installation Help
Hello - I’m trying to get set up with Zigbee2MQTT but I’m struggling with the initial setup
I've purchased the Sonoff Zigbee 3.0 USB Dongle Plus and I'm trying to set up Zigbee2MQTT in docker using the instructions provided by Zigbee2MQTT here: https://www.zigbee2mqtt.io/guide/instal ... updating-1
Everything is reasonably straightforwards - I've made a directory to keep my container, and I've created the two configuration files as instructed, substituting the path for my adapter in the relevant locations. When I come to start the stack I'm getting an error
error gathering device information while adding custom device "./dev/tty.usbmodem202303241146591": no such file or directory
I have confirmed that the path is correct as follows:
system_profiler SPUSBDataType
USB:
    USB 3.0 Bus:
       SONOFF Zigbee 3.0 USB Dongle Plus V2:
          Product ID: 0x55d4
          Vendor ID: 0x1a86
          Version: 4.42
          Serial Number: 20230324114659
          Speed: Up to 12 Mb/s
          Manufacturer: ITEAD
          Location ID: 0x14100000 / 15
          Current Available (mA): 500
          Current Required (mA): 132
          Extra Operating Current (mA): 0
ls -l /dev/tty.*
crw-rw-rw-  1 root  wheel  0x16000006  2 May 13:05 /dev/tty.Bluetooth-Incoming-Port
crw-rw-rw-  1 root  wheel  0x16000002  2 May 13:04 /dev/tty.usbmodem14601
crw-rw-rw-  1 root  wheel  0x16000008  6 May 17:32 /dev/tty.usbmodem147101
crw-rw-rw-  1 root  wheel  0x16000004  6 May 17:32 /dev/tty.usbmodem202303241146591
crw-rw-rw-  1 root  wheel  0x16000000  2 May 13:04 /dev/tty.usbserial-A118WGTK
ls -l /dev/tty.usbmodem202303241146591
and I've checked that I can write to the port:
test -w /dev/tty.usbmodem202303241146591 && echo success || echo failure
success
Perhaps this is something simple but I'm stumped - any advice on getting myself up and running?
Many thanks
Luke
Sun May 07, 2023 3:20 am
CliveS offline
Luke, I see you have the 'new' V2 Sonoff ZBDongle-E" (based on EFR32MG21), according to zigbee2mqtt this is still experimental but add the 2 lines below to your configuration.yaml
USB connected adapter with external antenna.
Note before buying that ITead slightly confusingly now sells both the "ZBDongle-E" (based on EFR32MG21) and "ZBDongle-P" (based on CC2652P).
This section is about the "ZBDongle-E
If Zigbee2MQTT fails to start, try adding the following to your configuration.yaml
serial:
  adapter: ezsp
CliveS
Mon May 08, 2023 12:28 pm
LSpad offline
Many thanks for the advice - I've added that to my config, and I'm able to get the services to start - unfortunately (after much experimentation) I'm still unable to get things up and running.
I wasn't aware there are two versions of the Sonoff stick - I do have the E version, which seems an unfortunate choice... I have however
- Installed the latest driver on my Mac and rebooted
- Updated the firmware on the stick to the latest available Coordinator version (using the Elelabs EzspFwUtility)
- identified my device (/dev/tty.wchusbserial202303241146591), and confirmed I have write permissions
My docker compose and configuration files area s follows:
Docker-compose.yml
version: '3.8'
services:
  mqtt:
    image: eclipse-mosquitto:2.0
    restart: unless-stopped
    volumes:
      - "./mosquitto-data:/mosquitto"
    ports:
      - "1883:1883"
      - "9001:9001"
    command: "mosquitto -c /mosquitto-no-auth.conf"
  zigbee2mqtt:
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt
    volumes:
      - ./zigbee2mqtt-data:/app/data
      - /run/udev:/run/udev:ro
    ports:
      - 8080:8080
    environment:
      - TZ=Europe/Berlin
    devices:
      # using the device name results in 'no such file or directory' - I'm just listing all ttys here which seems to work?
      - /dev/tty:ttywf
configuration.yaml
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://mqtt
serial:
  port: /dev/tty.wchusbserial202303241146591
  adapter: ezsp
frontend:
  port: 8080
advanced:
  # Optional: ZigBee pan ID (default: shown below)
  # Setting pan_id: GENERATE will make Zigbee2MQTT generate a new panID on next startup
  pan_id: GENERATE
  # Optional: Zigbee extended pan ID (default: shown below)
  # ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD]
  # Optional: ZigBee channel, changing requires re-pairing of all devices. (Note: use a ZLL channel: 11, 15, 20, or 25 to avoid Problems)
  # (default: 11)
  channel: 11
  # Optional: network encryption key, will improve security
  # Note: changing requires repairing of all devices (default: shown below)
  network_key: GENERATE
Am I doing anything obviously wrong here?
Thanks again for your help
Luke
Mon May 08, 2023 4:23 pm
CliveS offline
I don’t use Docker, in fact I run Zigbee2mqtt on a raspberry pi, but looking at your configuration.yaml the ‘server’ section should be
server: mqtt://<ip address of mqtt server>:1883
And the port seems to have changed
from
port: /dev/tty.usbmodem202303241146591
to
which maybe due to the firmware upgrade.
Also pan_id, channel and network _key are not required.
If you are still having problems then try the ‘Python Virtual Environment’ option instead of docker
CliveS
Thu May 11, 2023 1:05 pm
LSpad offline
Huge thanks Clive
So to those who want to get started from a zero base (like myself) I'll pop some instructions in here once I've completed the setup. Just to say I was unable to get Zigbee2MQTT to work at all in docker. Running it from a Python virtual environment is much easier even if it looks less friendly at first. I've successfully set up my Sonoff stick as a coordinator, run an MQTT broker courtesy of Joes great plugin, and linked everything together with Zigbee2MQTT in a virtual environment. I've more or less got my Aqara double rocker switch added to Indigo now.
Great work from all involved in developing these tools and plugins.
With best wishes
Luke
Sun May 14, 2023 8:49 am
CliveS offline
Well I finally recieved my shiny new Mac mini M2 and decided to pension off the Raspery Pi that has been running Mosquitto and zigbee2mqtt.
Mosquitto installed via brew is fine but looking at the python virtual environment install for zigbee2mqtt it is based around the Pi so I hit problem 1 at the
sudo chown -R pi:pi /opt/zigbee2mqtt
what is the Mac mini M2 equivalent to that?
Also autostart at boot looks like it will need some alternative to the Pi version.
Any guidance from those that have this installed on the M1/M2 Macs gratefully received.
CliveS
Sun May 14, 2023 1:31 pm
siclark offline
For auto start highly recommend PM2. I also use it for my node red setup too.
You also don't need to bother with virtual envs. Just follow the Linux instructions, they work fine. Ignore the systemctl bit and use PM2.
But to answer your question, it's
 sudo chown -R ${USER}: /opt/zigbee2mqtt
Wed Oct 25, 2023 3:55 pm
mundmc offline
I am SO CLOSE...
-Sonoff Zigbee 3.0 usb (CC2652P + CP2102N )
-indigo on immac
-imac virtual environment running zigbeee2mqtt
-gui enabled
-plugin installed
-contact switch added to zigbee
-new device showing in MQTT and in plugin
error messages as below, ONLY when connecting/ disconnecting:
   Zigbee2mqtt Bridge Error        MQTT topic 'zigbee2mqtt/0x282c02bfffe87858' is missing 'device' and|or 'ieeAddr' keys in JSON payload:
   Zigbee2mqtt Bridge Warning          {"battery":100,"battery_low":false,"contact":true,"linkquality":171,"tamper":false,"voltage":3100}
I suppose there is a setting somewhere that places the device name into the json payload, but i know not where.
Now for the screen shots:
coordinator settings
Screenshot 2023-10-25 at 5.27.56 PM.png (269.3 KiB) Viewed 1696 times
door sensor device
Screenshot 2023-10-25 at 5.26.59 PM.png (219.18 KiB) Viewed 1696 times
device in indigo
Screenshot 2023-10-25 at 5.25.51 PM.png (148.35 KiB) Viewed 1696 times
mqtt explorer info
Screenshot 2023-10-25 173145.png (26.85 KiB) Viewed 1696 times
Wed Oct 25, 2023 4:23 pm
mundmc offline
NEVER MIND!
I missed the line in the github instructions clearingly stating to check "Include Device Information" in the zigbee2mqtt frontend settings!
This rocks!
Thu Oct 26, 2023 3:05 am
siclark offline
mundmc wrote:
NEVER MIND!
This rocks!
It does indeed.
Warning to anyone tempted to play with Home Assistant as well. Don’t enable the HA connectivity in zigbee2mqtt as it changes the messages and breaks the indigo plugin.
It might be possible to run both but do some testing and look at the options rather than blindly turning it on like me and then getting complaints from users (aka my wife) that lights and switches didn’t work.
Wed Nov 01, 2023 8:04 pm
mundmc offline
I am so pleased, I have already purchased a discounted raspberry pi and a second dongle to deploy another repeater in my shop.
