not yet programmed z-wave messages in classes 66, 68, 69
Thu Aug 12, 2021 10:50 am
dduff617 offline
The plugin should decode a lot (most?) of the common Z-Wave Command Classes. If a Z-Wave Command Class / Command can't be interpreted, the plugin will indicate such. In that case, if you would like it to be decoded, post the log output in this sub-forum and I will look to add the decoding in for it into the plugin.
here are some i was wondering about. These come from thermostats.
  Z-Wave Interpreter Debug        2021-08-12 12:36:24.141 RCVD: '[ 01 09 00 04 00 6B 03 44 03 00 DD ]' from ' Thermostat 1RAD' [Node: 107]
                                   Logic not programmed for Z-Wave Command Class: '68 [0x44]'
  Z-Wave Interpreter Debug        2021-08-12 12:30:30.791 RCVD: '[ 01 09 00 04 00 6B 03 42 03 00 DB ]' from ' Thermostat 1RAD' [Node: 107]
                                   Logic not programmed for Z-Wave Command Class: '66 [0x42]'
   Z-Wave Interpreter Debug        2021-08-12 12:30:52.746 RCVD: '[ 01 09 00 04 00 6E 03 42 03 02 DC ]' from ' Thermostat 1FA ZWave' [Node: 110]
  Z-Wave Interpreter Debug        2021-08-12 12:36:07.464 SEND: 'OK', [ 01 09 00 13 6B 02 45 02 25 A5 4B ] (15ms) to ' Thermostat 1RAD' [Node: 107]
                                   Logic not programmed for Z-Wave Command Class: '69 [0x45]'
as background, I've been wondering for a while why I can't seem to get a z-wave thermostat to work the way i want it to - namely, where every state change of a sensor (temperature/humidity) is reported from the device to indigo and every state change of the equipment (fan on/off, heat or cool on/off, etc.) is also reported. i have one thermostat that seems to report hundreds of minuscule humidity changes but rarely if ever reports temperature changes. i have a thermostat that reports temperature and humidity but doesn't report when the system turns on/off. so i'm hoping the plugin will give me some leverage on getting this sorted.
Thu Aug 12, 2021 11:33 am
Re: not yet programmed z-wave messages in classes 66, 68, 69
I will investigate and add these interpretations to the plugin. :)
  • Command Class: '66 [0x42]: Thermostat Operating State
  • Command Class: '66 [0x44]: Thermostat Fan Mode
  • Command Class: '66 [0x45]: Thermostat Fan State
There are probably a few other associated Command Classes that I will investigate as well.
It will take a few days before I can schedule in time to look at it and as I can't test the resultant code changes myself, I will put a pre-release version up on Github for you to try. :)
Fri Aug 13, 2021 7:25 am
I managed to find some time. :)
I have uploaded a pre-release version to Github for you to try: Support Additional Command Classes
Add support for:
Let me know how it goes as I haven't been able test the changes as I don't have a fan device.
If it works, please post the logging output. Thanks. :)
Fri Aug 13, 2021 10:44 am
dduff617 offline
ok i am trying out the new version (0.4.4).
i haven't analyzed carefully, but i appear to still be getting "not programmed" messages for some commands in class 66. also seeing some new errors from Z-wave Interpreter.
Aug 13, 2021 at 12:30:18
Stopping plugin Z-Wave Interpreter (pid 43936)
Z-Wave Interpreter Debug shutdown called
Stopped plugin Z-Wave Interpreter
Upgrading plugin Z-Wave Interpreter to newer version 0.4.4 (previous version moved to trash)
Loading plugin "Z-Wave Interpreter 0.4.4"
Starting plugin "Z-Wave Interpreter 0.4.4" (pid 26645)
Z-Wave Interpreter
============================================= Initialising Z-Wave Interpreter Plugin =============================================
Plugin Name: Z-Wave Interpreter
Plugin Version: 0.4.4
Plugin ID: com.autologplugin.indigoplugin.zwaveinterpreter
Indigo Version: 2021.1.1
Indigo License: ActiveSubscription
Indigo API Version: 2.5
Python Version: 2.7.16 (default, Mar 25 2021, 03:11:28) [GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc-
Mac OS Version: 10.15.7
Z-Wave Interpreter Indigo Event Log set to 'Debugging'
Z-Wave Interpreter Plugin Log set to 'No Z-Wave Logging'
Started plugin "Z-Wave Interpreter 0.4.4"
Aug 13, 2021 at 12:31:18
Z-Wave Interpreter Debug 2021-08-13 12:31:18.080 SEND: 'OK', [ 01 09 00 13 6B 02 40 02 25 4B A0 ] (10ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Mode [v1]', Command: 'Get'
Z-Wave received " Thermostat 1RAD" mode is heat
Z-Wave Interpreter Debug 2021-08-13 12:31:18.207 RCVD: '[ 01 09 00 04 00 6B 03 40 03 01 D8 ]' from ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Mode [v1]', Command: 'Report', Mode: 'Heat'
Z-Wave Interpreter Debug 2021-08-13 12:31:18.218 SEND: 'OK', [ 01 09 00 13 6B 02 44 02 25 4C A3 ] (10ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Fan Mode [v1]', Command: 'Get'
Z-Wave received " Thermostat 1RAD" fan mode is auto
Z-Wave Interpreter Error Error detected in 'ZwaveThermostatFanMode' Class, '_interpret_report' method: Line 137 has error '30'
Z-Wave Interpreter Debug 2021-08-13 12:31:18.382 RCVD: '[ 01 09 00 04 00 6B 03 44 03 00 DD ]' from ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:18.400 SEND: 'OK', [ 01 09 00 13 6B 02 42 02 25 4D A4 ] (28ms) to ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:18.646 RCVD: '[ 01 09 00 04 00 6B 03 42 03 00 DB ]' from ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:18.654 SEND: 'OK', [ 01 09 00 13 6B 02 45 02 25 4E A0 ] (11ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Fan State [v1]', Command: 'Get'
Z-Wave Interpreter Error Error detected in 'ZwaveThermostatFanState' Class, '_interpret_report' method: Line 100 has error '30'
Z-Wave Interpreter Debug 2021-08-13 12:31:18.801 RCVD: '[ 01 09 00 04 00 6B 03 45 03 00 DC ]' from ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:18.808 SEND: 'OK', [ 01 0B 00 13 6B 04 31 04 05 00 25 4F D2 ] (15ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Multilevel Sensor [v5]', Command: 'Get'
Z-Wave Interpreter Debug 2021-08-13 12:31:18.971 RCVD: '[ 01 0B 00 04 00 6B 05 31 05 05 01 28 86 ]' from ' Thermostat 1RAD' [Node: 107]
Class: 'Multilevel Sensor [v5]', Command: 'Report', Sensor: 'Humidity', Value: '40%'
Z-Wave Interpreter Debug 2021-08-13 12:31:18.990 SEND: 'OK', [ 01 09 00 13 6B 02 31 04 25 50 CC ] (19ms) to ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:19.066 RCVD: '[ 01 0B 00 04 00 6B 05 31 05 05 01 28 86 ]' from ' Thermostat 1RAD' [Node: 107]
Z-Wave Interpreter Debug 2021-08-13 12:31:19.073 SEND: 'OK', [ 01 0A 00 13 6B 03 43 02 01 25 51 BA ] (9ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Setpoint [v1]', Command: 'Get', Setpoint Type: 'Heating'
Z-Wave received " Thermostat 1RAD" heat setpoint is 69 °F
Z-Wave Interpreter Debug 2021-08-13 12:31:19.302 RCVD: '[ 01 0B 00 04 00 6B 05 43 03 01 09 45 93 ]' from ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Setpoint [v1]', Command: 'Report', Setpoint Type: 'Heating', Value: '69º F'
Z-Wave Interpreter Debug 2021-08-13 12:31:19.310 SEND: 'OK', [ 01 0A 00 13 6B 03 43 02 02 25 52 BA ] (16ms) to ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Setpoint [v1]', Command: 'Get', Setpoint Type: 'Cooling'
Z-Wave received " Thermostat 1RAD" cool setpoint is 76 °F
Z-Wave Interpreter Debug 2021-08-13 12:31:19.359 RCVD: '[ 01 0B 00 04 00 6B 05 43 03 02 09 4C 99 ]' from ' Thermostat 1RAD' [Node: 107]
Class: 'Thermostat Setpoint [v1]', Command: 'Report', Setpoint Type: 'Cooling', Value: '76º F'
Z-Wave Interpreter Debug 2021-08-13 12:31:24.479 RCVD: '[ 01 09 00 04 00 6B 03 44 03 00 DD ]' from ' Thermostat 1RAD' [Node: 107]
Fri Aug 13, 2021 11:52 am
Corrections made and new pre-release loaded up on Github: V 0.4.5 :)
Mon Aug 23, 2021 10:45 am
dduff617 offline
just installed 0.4.5
looks like the "logic not programmed" reports are gone, however i'm still seeing similar errors as before in _interpret_report method.
   Z-Wave Interpreter Debug        2021-08-23 12:42:45.664 RCVD: '[ 01 09 00 04 00 6B 03 44 03 00 DD ]' from ' Thermostat 1RAD' [Node: 107]
   Z-Wave Interpreter Debug        2021-08-23 12:42:46.252 RCVD: '[ 01 09 00 04 00 6B 03 45 03 00 DC ]' from ' Thermostat 1RAD' [Node: 107]
Mon Aug 23, 2021 11:00 am
Correction made and new pre-release loaded up on Github: Version 0.4.6 :)
Mon Aug 23, 2021 11:14 am
dduff617 offline
previously reported issues seem to be cleared up with 0.4.6.
thanks again for the plugin and the fixes.
Mon Aug 23, 2021 11:25 am
Thanks for the update: Now released to the Indigo Plugin Store. :)
