iMessage Plugin & MAcOS 11 ?
Wed Sep 23, 2020 10:25 am
SearchCz offline
Having some trouble getting the iMessage app to work with Indigo 7.4 / MacOS 11.
Plugin is installed and seems to start successfully. But I get errors and such when I try to send a message.
Action Group iMessage Test
iMessage Plugin Debug sendImsg() method called.
iMessage Plugin Debug sendImsg() buddyHandle:myaddress@mydomain.com and theMessage:this is a test iMessage and use lastBuddy:False
iMessage Plugin Debug as_sendmessage() method called.
iMessage Plugin Debug Sending iMsg:this is a test iMessage to Buddy/User:myaddress@mydomain.com
iMessage Plugin Debug A error of type :ScriptError occured. The longer message is :Expected class name but found identifier.
iMessage Plugin Error An Error occured within the iMsg AppleScript component - ScriptError
iMessage Plugin Error The Error was :Expected class name but found identifier. (-2741) range=126-133
iMessage Plugin Error Caught Exception:
File "plugin.py", line 1184, in sendiMsg
self.as_sendmessage(buddyHandle, theMessage)
File "plugin.py", line 461, in as_sendmessage
my_ascript_from_string = applescript.AppleScript(source=ascript_string)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/applescript/__init__.py", line 49, in __init__
raise ScriptError(errorinfo)
ScriptError: Expected class name but found identifier. (-2741) range=126-133
I authorized full disk access in all the places where it is needed. If this is something I should expect to work, I'll keep trying. Anyone have any luck, advice or insight to send my way it would be most appreciated.
Sun Sep 27, 2020 9:34 pm
GlennNZ offline
Hi
It would seem that Big Sur OSX 11 does not allow iMessages access.
https://www.reddit.com/r/applescript/co ... n_big_sur/
But also
So may be back, but just changed...
https://www.reddit.com/r/applescript/co ... s_big_sur/
Probably changed... might be hard to troubleshoot though...
Also folders and sql database where messages saved changed and altered. Essentially this is a major breaking change which means the Plugin will not work on Big Sur. Seems to have lead to a number of messages related apps closing down... eg.
https://flexibits.com/chatology
Will keep looking and see if other options.
Glenn
Thu Nov 12, 2020 11:03 pm
GlennNZ offline
Re: iMessage Plugin & MAcOS 11 ?
Hi all,
Good news - further to this, have discovered can likely fix/update the Plugin to fully function in Big Sur.
Working on it now, should have a test release available sometime next week.
Glenn
Fri Nov 13, 2020 12:31 am
GlennNZ offline
Hi
Try version 0.4.7
Add compatibility for Big Sur released. Backward compatibility maintained.
Still needs Full disk access & potentially Matts fix here
for error 'Error "Not authorized to send Apple events to Messages"' if occurs
viewtopic.php?f=297&t=23619#p189420
- Involves creating a script file for iMessages, save and then run from within Indigo - OS shoudl prompt a window 'allow access' click yes, and plugin send messages should now also work
Here:
https://github.com/Ghawken/iMessagePlugin/tree/wit.ai
Working for me on Big Sur ....
Please test and let me know before release.
Sun Nov 29, 2020 1:47 pm
chase offline
Has anyone verified the fix for Big Sur? Updating my server now and I rely on this iMessage plugin !
Sun Nov 29, 2020 3:53 pm
GlennNZ offline
Mine is working fine(!)- wasn’t a huge fix, so hopefully you have the same experience
viewtopic.php?t=24585
Sun Nov 29, 2020 6:22 pm
chase offline
All updated..
Thanks GlennNZ... btw I had to do every step listed in the link... and everything seems to be working fine.
And thanks for this plugin (I installed the newest version on GitHub before upgrading to Big Sur). Our indigo sends iMessages all day long and it is the primary notification method for us. It would be miserable if the plugin went away.
Fri Dec 04, 2020 9:57 am
mundmc offline
This could be a nifty feature for using Messages with Amazon products: https://www.cnbc.com/2020/12/03/how-to- ... phone.html
