MacOS 10.15.7: Installation Error
Sat Jun 26, 2021 12:25 pm
bdubnm offline
As best as I can tell, Mac OS 10.15.7 is NOT supported? The code on line 80 appears to be determining the MacOS version. After that, unsure what is happening.
Jun 26, 2021 at 12:18:38 PM
   Installing and enabling plugin Ecobee 2 v2.3.4
   Loading plugin "Ecobee 2 2.3.4"
   Starting plugin "Ecobee 2 2.3.4" (pid 86501)
   Started plugin "Ecobee 2 2.3.4"
   Ecobee 2                        Starting Ecobee
   Ecobee 2 Error                  Error in plugin execution startup:
  File "plugin.py", line 80, in startup
ValueError: invalid literal for float(): 10.15.7
   Ecobee 2 Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 141, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'next_update'
   Ecobee 2 Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
When I attempt to add an Ecobee Account, and click Get Code, nothing happens...
Sat Jun 26, 2021 12:27 pm
Re: MacOS 10.15.7: Installation Error
Grrr. I'll have to redo the fix I made to correct an error on Big Sur. I'll have an update soon.
Sat Jun 26, 2021 12:38 pm
bdubnm offline
Thank you sir.
Sat Jun 26, 2021 12:48 pm
Sat Jun 26, 2021 1:17 pm
bdubnm offline
Perfect. Worked like a charm.
