- Posted on
Tue Oct 30, 2018 4:35 pm
7rdr7
offline
Hi Peter,
I finally got around to trying the variable to set the PIN codes. Works great! Eric's post/questions was also helpful.
You posted earlier:
"I was also going to say yes it can be done easily - I’ll intercept a blank pin in the setPin() routine in code, and redirect to clearPin() instead when it sees blank."
Did you decide to add that function? I ask as when I delete the code (variable entry) and execute the action, the code remains in the locks. Could be a Schlage thing..... but the redirect would be nice if you plan to dig back into the code.
Thank-you for a very useful Plugin.
