Battery Charting Script
Thu Apr 07, 2016 8:51 pm
I have been playing around with matplotlib as a substitute for Gnuplot and wrote a quick script to create a chart that shows the health of all of my battery-powered devices. The script automatically picks up all the devices--when a new device is added to the system, it will automatically be added to the chart (implementations with a significantly different number of devices will require playing with the chart scaling parameters.)
When a battery drops below 10 percent, its bar will automatically turn yellow and below 5 percent it will turn red (many parameters can be easily adjusted in the script) The resulting image is placed in the appropriate Indigo directory to make it available in the control page editor. The script completes quickly, but I'd suggest running it as a linked script (rather than embedded), and I believe all components are available natively in OS X. Note: to make it look its best on a control page, you need to browse to the image to note it's dimensions.
I'm pretty happy with the results so far. Enjoy!
Dave
EDIT: Updated to include:
- Device names sorted alphabetically
- Error trapping for imports, device information gathering, data parsing
- Karl's data point labels (look for setting: show_data_labels [True/False])
EDIT 2: Updated to include:
- moved the data labels inside the ends of the bars,
- moved all bars up to keep them from crowding the x axis,
- moved the y axis labels slightly to actually be centered (for 2 line labels),
- picks up devices with battery level of zero,
- adds a 'fontname' value to specify a choice.
EDIT 3:
- coerces a battery level of zero when device reports an empty string for its battery level.
EDIT 4:
- fixes error where coercions were improperly created as strings.
Confirmed to work under:
Python 2.6.8
Matplotlib 1.1.1
Indigo Server 6.1.7
To download the Python 2 version, visit the link below and select the Python 2 fork.
EDIT 5:
- Updates script to Python 3 to work with Indigo 2022.1.
Python 3.10.2
Matplotlib 3.5.1
Indigo Server 2022.1
To download the Python 3 version, visit the link below and select the Master fork.
You can download the script on GitHub.
[EDIT] Move script to GitHub.
Fri Apr 08, 2016 12:21 am
Re: Low Battery Charting Script
Nice.
What devices are those - my Fibaro motion sensors are rubbish at reporting battery. Your post has given me the idea to extrapolate battery life out over say 30 days so I can see the average decline over the period.
(I did get my first ever notification from my battery-alert email last night - but that was my Nissan Leaf, not motion sensors!)
Fri Apr 08, 2016 2:43 am
Asconasny offline
Great
Worked right out of the box!
brilliant and thank you
regards
Asconasny
Fri Apr 08, 2016 3:20 am
Shutter offline
Dave,
Very nice and easy. Thanks for this.
As much as we all love Karl's INDIGOplotD, this was very simple to use and set up. Already modified a few settings - not that I know Python, but I can figure some things out.
Funny, just yesterday finished listening to the hometech.fm podcast, where they mention Indigo and others, and they had that mini rant about how lots of the DIY solutions love charts. There is a time and a place for a chart. This is one of them. :D
Simon
Fri Apr 08, 2016 4:05 am
howartp wrote:
Nice.
The motion sensors are Aeon units (the one in the attic is connected via USB to the mains, so it will always report 100%.)
Your post caused me to look at the chart with fresh eyes and now my OCD is forcing me to rename my devices so that they're more consistent.
Fri Apr 08, 2016 4:07 am
Asconasny wrote:
Great
regards
Asconasny
My pleasure. Glad to hear that it worked for you. Keep an eye out for enhancements as I'm loathe to leave well enough alone.
Dave
Fri Apr 08, 2016 4:08 am
Shutter wrote:
Dave,
Simon
You've got it brother, glad you like it.
I'm an analyst by trade and an economist by schooling and I can tell you this; there is ALWAYS room for a chart. :D
Dave
Fri Apr 08, 2016 7:16 am
ckeyes888 offline
Should this work with 10.6.8? I don't have Python 2.7 installed, which it appears to need.
Would it cause any issues with Indigo to install 2.7, Numby, Mathplotlib etc?
Carl
Fri Apr 08, 2016 7:51 am
Carl
Hi Carl - the script doesn't require Python 2.7 -- I'm running it under 2.6 within Indigo with no problems. I was under the impression Matplotlib and Numpy were available within the factory Python install that comes with OS X, but maybe they were added in later versions of the OS.
Try this:
From the Plugins menu within Indigo, open the Scripting Shell. At the prompt,
1. Type "import matplotlib" and hit enter.
2. Type "import numpy" and hit enter.
3. Type "exit()" and hit enter.
Then paste the results in a reply to this thread. You should get something that looks like the following (which will likely contain errors.)
Python 2.6.8 (unknown, Mar  9 2014, 22:16:00)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
Connected to Indigo Server v6.1.7, api v1.20 (localuds:1176)
>>> import matplotlib
>>> import numpy
>>> exit()
exit requested: interactive shell shutdown
logout
[Process completed]
Fri Apr 08, 2016 11:11 am
Re: Battery Charting Script
Matplotlib was added in OS X 10.8 I believe. You could install it yourself but then you run into problems with Python 2.5 which could be overcome by launching an external script. But then this gets really complicated.
Fri Apr 08, 2016 1:28 pm
just a little teaser: adding this to the code after
plt.barh(y_axis, x_values, align='center', color=bar_colors, alpha=1.0, height=0.5, zorder=3)
for ii in range(len(y_axis)):
   plt.annotate("%3d"%x_values[ii],xy=(x_values[ii],y_axis[ii]), xycoords='data',textcoords='data',color=font_color)
will add numbers at the end of the bars..
Matplotlib is VERY powerful!!
annotate has a lot of options and features:
http://matplotlib.org/users/annotations_intro.html
Screen Shot 2016-04-08 at 2.25.50 PM.png (61 KiB) Viewed 16344 times
Fri Apr 08, 2016 1:30 pm
ckeyes888 offline
Here ya go.
Python 2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
[GCC 4.2.1 (Apple Inc. build 5646)]
Connected to Indigo Server v6.1.4, api v1.19 (localuds:1176)
>>> import mathplotlib
  File "<console>", line 1, in <module>
ImportError: No module named mathplotlib
>>> import numphy
ImportError: No module named numphy
>>> exit()
logout
[Process completed]
Appreciate the help.
edit: Oops...had a typo..should have been numpy.
Carl
Fri Apr 08, 2016 1:55 pm
you need OS-X 10.9 - Mavericks,
or you need to install matplotlib and numpi yourself: https://pypi.python.org/pypi/matplotlib#downloads and that be difficult, a lot of dependencies on Py versions etc..
Fri Apr 08, 2016 2:19 pm
Thanks Karl!
That was on the to do list. Now I can check that one off!
ckeyes888 wrote:
Here ya go.
>>> import mathplotlib
>>> import numphy
>>> exit()
logout
[Process completed]
Carl
You might be sunk on this one Carl. Sorry!
Dave
