Plot thermostat hours on per day vs temp
Sat Jul 15, 2017 4:22 pm
siclark offline
I have been trying various ways, and reading a lot, but can't see a way to do this. My thermostat devices have a variable of HeatisOn = True/False. I would like to ply the cumulative minutes and hours that the heating is on each day, and reset each midnight. Ie plot this as a histogram alongside the temp reading and the set point reading.
Cheers
Sat Jul 15, 2017 5:07 pm
1. count : will count how often it is 1(=true) testing once a minute, no reset, will continue to grow / bin (5 minutes/ 1 hour/ 1 day bins)
2. consumption (any type, they are just names), then set reset to 1/day and cost =1. that should do exactly what you want.
hope that helps
there are various other options = reset 1/week month/// and reset at specific point in time e.g. 6/15, 7/30 = you billing period.. but that requires some patience to setup.
and you could also use variable cost e.g. if consumption> 3 cost = 12 cents > 50: 50cents ..
and cost for daytime periods.
Screen Shot 2017-07-15 at 18.03.33.png (114.51 KiB) Viewed 1704 times
Screen Shot 2017-07-15 at 18.01.26.png (72.59 KiB) Viewed 1704 times
