Aeotec multi sensor 6
Thu May 14, 2020 2:16 am
pocster offline
Hey
This works well . But there seems to be a delay on checking for motion and an event being triggered . Only 2 seconds or so .
Any indigo or sensor way to speed this up ?
The sensor is powered over poe so no ‘delay’ to reduce battery consumption.
The issue is when entering a room you literally have to walk in and then wait for the trigger to occur .
Any help appreciated
Thu May 14, 2020 10:11 am
Re: Aeotec multi sensor 6
Can you tell by looking at the Event Log when you walk into the room if Indigo is immediately logging the event then later activating the trigger or does Indigo not log the event until after the 2 second delay?
Thu May 14, 2020 1:12 pm
pocster offline
Thanks .
Will check tomorrow!
