Unintended Insteon command
Sun Dec 31, 2023 2:33 pm
rafsel offline
I am getting a series of unintended Insteon commands, all on the same device. The latest one was early this morning:
Dec 31, 2023 at 12:55:03 AM
   Sent INSTEON                    "MBR Outlet (Lamp)" on to 30
The previous and subsequent entries in the log were at:
Dec 31, 2023 at 12:23:51 AM
Dec 31, 2023 at 1:00:00 AM
These are far enough away from the problem to not be relevant.
I'm trying to track down where this is coming from.
Is there some way to turn on additional debugging to see how the Insteon command was initiated?
Sun Dec 31, 2023 2:43 pm
ryanbuckner offline
Re: Unintended Insteon command
I don't think there is. Have you tried factory resetting the device? If that doesn't work it might be an indication that the device is failing.
Sun Dec 31, 2023 2:46 pm
rafsel offline
No, but I will reset it.
However, the log message seems to indicate that the Indigo server is sending the device the Insteon command. Am I reading this wrong?
Sun Dec 31, 2023 3:03 pm
ryanbuckner offline
You're reading it right. I think if someone presses a physical button you get "Received INSTEON" and if it's triggered by a control page , touch, or the client you see "Sent INSTEON"
If it was an Action , or Trigger, or Schedule you should see that in the log as well.
Sun Dec 31, 2023 3:38 pm
rafsel offline
Right. There is no indication in the log that it was caused by an Action, Schedule or Trigger. And it wasn’t manually turned on. So that leaves a control page . I wonder if it’s possible that a control page could send it spontaneously? This doesn’t seem likely.
ryanbuckner offline
Did you try to right click on the device and "Show Dependencies" to see where the device can be accessed?
Sun Dec 31, 2023 3:47 pm
rafsel offline
Yup, and its dependencies are Actions, Schedules and a Control Page. And since the log showed no evidence of it, being an action, nor a schedule, I’m assuming it was from a control page. I did verify that when the appropriate button is pressed on the control page. It generates a log entry similar to the one that happens early in the morning. So I’m assuming that somehow the control page is sending the command. I’ll add some debugging statements to prove that conjecture to try to get to the bottom of this.
Sun Dec 31, 2023 5:25 pm
ryanbuckner offline
The other possibility is that it's linked to another device? or thinks it is?
Mon Jan 01, 2024 12:50 pm
Note on the Action UI panel for Triggers and Schedules there is a checkbox that suppresses the logging of the trigger/schedule. In that case you won't see anything in the Event Log about the Trigger or Schedule, but any commands it sends out (like above) will be logged. It could also be from a script or plugin you have running.
Sat Jan 20, 2024 6:04 am
rafsel offline
Found it! I'm using the HomeKit Link plugin and somehow the HomeKit enabled my test Automations.
Don't I feel silly. :oops:
